Quadcopter ESCs noise causing Arduino to reset
Hi everyone,
I’m making a quadcopter with an Arduino 101 as the IMU, reciever as well as the flight controller.
I’ve been facing an issue since the last 4 days. The serial monitor seems to sometimes randomly ‘freeze’.
After attempting to look for the lines of code causing it, I was unable to find any problems (the problem doesn’t happen when I load one of the examples provided in the IDE). I’m not using the ‘String’ class anywhere. I also checked the heap and stack memory and it doesn’t seem to be related.
I noticed that the problem happens everytime I drive the motors (brushless) above a certain speed (although sometimes even when I’m simply looking at the IMU readings in the serial monitor stream and the motors are powered off). The motors are being driven by the ESCs via a 490 Hz PWM signal (not using the Servo library). The Arduino resets everytime the throttle reaches 30% of full scale. I probed one of the control signals with an oscilloscope, and found that the PWM signal had noise of amplitude proportional to the throttle position. At 30% throttle, the noise is quite significant and it causes the Arduino to reset/hang almost immediately (usually the code is still running as the PID control can be felt if I tilt the quad, but the serial monitor stops streaming and sent commands are ignored). I tried powering the arduino seperately through a 9v battery or a 9V 1A power adapter (with the grounds of the main battery and the Arduino supply connected and disconnected in each case) with no luck. It had no effect on the noise. Isn’t the ESC supposed to isolate the noise caused by the motor from the control signal? If not, what can I do? (1nF capacitors across the control signal and Arduino ground didn’t do the trick)
I will attach the code tonight in case needed. The circuit diagram is exactly like standard quadcopter circuits (Motor-ESC-LiPo Battery-Arduino).
#include "CurieIMU.h"
#include <MadgwickAHRS.h>
Madgwick filter;
#define motor1 6
#define motor2 9
#define motor3 3
#define motor4 5
int duty_percent = 0;
int duty_255  = 97;
int freq = 475;
int xOffset = 2;
char buff[2];
float elapsedTime, time, timePrev;
unsigned long microsPerReading, microsPrevious;
int aix, aiy, aiz, gix, giy, giz;
float ax, ay, az; //scaled accelerometer values
float gx, gy, gz; //scaled Gyro values
float Total_angle[2];
float xPID, yPID, xerror, previous_xerror, yerror, previous_yerror;
int pwm1, pwm2, pwm3, pwm4;
float xpid_p = 0;
float xpid_i = 0;
float xpid_d = 0;
float ypid_p = 0;
float ypid_i = 0;
float ypid_d = 0;
/////////////////PID CONSTANTS/////////////////
double kp = 1.0; //3.55
double ki = 0.0; //0.003
double kd = 1.0; //2.05
int throttle  = 97;
int max_throttle = 250;
float desired_xangle = 0;
float desired_yangle = 0;
  pinMode(motor1, OUTPUT); //pwm
  pinMode(motor2, OUTPUT); //pwm
  pinMode(motor3, OUTPUT); //pwm
  pinMode(motor4, OUTPUT); //pwm
  analogWriteFrequency(motor1, freq);
  analogWriteFrequency(motor2, freq);
  analogWriteFrequency(motor3, freq);
  analogWriteFrequency(motor4, freq);
  while (!Serial) {};
  Serial.println("Initializing IMU device...");
  CurieIMU.begin();
  CurieIMU.setGyroRate(25);
  CurieIMU.setAccelerometerRate(25);
  filter.begin(25);
  CurieIMU.setAccelerometerRange(2);
  CurieIMU.setGyroRange(250);
  CurieIMU.autoCalibrateAccelerometerOffset(X_AXIS, 0);
  CurieIMU.autoCalibrateAccelerometerOffset(Y_AXIS, 0);
  CurieIMU.autoCalibrateAccelerometerOffset(Z_AXIS, 1);
  CurieIMU.autoCalibrateGyroOffset();
  microsPerReading = 1000000 / 25;
  microsPrevious = micros();
  time = millis();
  Serial.println("Ready");
  if (Serial.available() > 0) {
    if (Serial.peek() == 'p') {
      Serial.readBytes(buff, 2);
      kp = Serial.readStringUntil('\n').toFloat();
      Serial.print("--------------------------");
      Serial.print("kp=");
      Serial.print(kp, 4);
      Serial.println("--------------------------");
    } else if (Serial.peek() == 'i') {
      ki = Serial.readStringUntil('\n').toFloat();
      Serial.print("ki=");
      Serial.print(ki, 4);
    } else if (Serial.peek() == 'd') {
      kd = Serial.readStringUntil('\n').toFloat();
      Serial.print("kd=");
      Serial.print(kd, 4);
      duty_percent = Serial.readStringUntil('\n').toInt();
      duty_255 = map(duty_percent, 0, 100, 97, 250);
      throttle = duty_255;
      Serial.print("==========================");
      Serial.print(duty_percent);
      Serial.print("% (throttle = ");
      Serial.print(throttle);
      Serial.println(")==========================");
  //  Serial.println(elapsedTime, 3);
  unsigned long microsNow;
  // check if it's time to read data and update the filter
  microsNow = micros();
  Serial.println(microsNow);
  if (microsNow - microsPrevious >= microsPerReading) {
    timePrev = time;  // the previous time is stored before the actual time read
    time = millis();  // actual time read
    elapsedTime = (time - timePrev);
    noInterrupts();
    CurieIMU.readMotionSensor(aix, aiy, aiz, gix, giy, giz);
    interrupts();
    ax = convertRawAcceleration(aix);
    ay = convertRawAcceleration(aiy);
    az = convertRawAcceleration(aiz);
    gx = convertRawGyro(gix);
    gy = convertRawGyro(giy);
    gz = convertRawGyro(giz);
    filter.updateIMU(gx, gy, gz, ax, ay, az);
    Total_angle[0] = filter.getPitch(); // X
    Total_angle[1] = filter.getRoll(); // Y
    Serial.print("X_angle:"); Serial.print(Total_angle[0]);
    Serial.print("\t");
    Serial.print("Y_angle:"); Serial.print(Total_angle[1]);
    Serial.print("\t");
    /* / / / / / / / / / / /  PID \ \ \ \ \ \ \ \ \ \ \ \*/
    xerror = Total_angle[0] - desired_xangle;
    Serial.print("err:");
    Serial.print(xerror);
    Serial.print("\t");
    /*P*/
    xpid_p = kp * xerror;
    /*I*/
    if ((-2 < xerror) && (xerror < 2))
      xpid_i = xpid_i + (ki * xerror);
    //  /*D*/
    xpid_d = kd * ((xerror - previous_xerror) / elapsedTime);
    xPID = xpid_p + xpid_i + xpid_d;
    xPID = xPID ;/// 15;
    Serial.print("xPID:"); Serial.print(xPID); Serial.print('\t');
    Serial.print(xpid_p); Serial.print('\t');
    Serial.print(xpid_i); Serial.print('\t');
    Serial.print(xpid_d);
    if (throttle > 105) {
      //    pwm1=throttle;pwm2=throttle;pwm3=throttle;pwm4=throttle;
      pwm1 = round(throttle - xPID) + xOffset;
      pwm2 = round(throttle - xPID) + xOffset;
      pwm3 = round(throttle + xPID) - xOffset;
      pwm4 = round(throttle + xPID) - xOffset;
    } else if (throttle == 97) {
      pwm1 = throttle;
      pwm2 = throttle;
      pwm3 = throttle;
      pwm4 = throttle;
    if (pwm1 < 97) {
      pwm1 = 97;
    } else if (pwm1 > max_throttle) {
      pwm1 = max_throttle;
    if (pwm2 < 97) {
      pwm2 = 97;
    } else if (pwm2 > max_throttle) {
      pwm2 = max_throttle;
    if (pwm3 < 97) {
      pwm3 = 97;
    } else if (pwm3 > max_throttle) {
      pwm3 = max_throttle;
    if (pwm4 < 97) {
      pwm4 = 97;
    } else if (pwm4 > max_throttle) {
      pwm4 = max_throttle;
    analogWrite(motor1 , pwm1);
    analogWrite(motor2 , pwm2);
    analogWrite(motor3 , pwm3);
    analogWrite(motor4 , pwm4);
    Serial.print("\tthrottle:"); Serial.print(throttle);
    Serial.print("\tpwm_front:"); Serial.print(pwm1);
    Serial.print("\tpwm_back:") ; Serial.print(pwm3);
    previous_xerror = xerror;
    microsPrevious = microsPrevious + microsPerReading;
float convertRawAcceleration(int aRaw) {
  // since we are using 2G range
  // -2g maps to a raw value of -32768
  // +2g maps to a raw value of 32767
  float a = (aRaw * 2.0) / 32768.0;
  return a;
float convertRawGyro(int gRaw) {
  // since we are using 250 degrees/seconds range
  // -250 maps to a raw value of -32768
  // +250 maps to a raw value of 32767
  float g = (gRaw * 250.0) / 32768.0;
  return g;
Seems like it was a hardware issue (poor ground contacts). After replacing all the wiring, the problem seems to have disappeared.
