Quadcopter Obstacle Avoidance using Sharp IR sensors [HELP!! - I'll pay for it!]
I was looking for a code for a quadcopter obstacle avoidance with IR sensors and I found this diagram on flitetest:
I've followed this diagram and the following code:
   Code Written By Cyril Anthony
   Not for commercial use
#include <ServoIn.h>
#include <ServoOut.h>
#include <Timer1.h>
#define CHANNELS 2
int setpoint=60,Kp=3;
uint16_t g_values[CHANNELS];
uint16_t Obuff[CHANNELS];
uint8_t  g_workIn[SERVOIN_WORK_SIZE(CHANNELS)];
uint8_t  g_pinsOut[CHANNELS] = {8, 9};
uint8_t  g_work[SERVOOUT_WORK_SIZE(CHANNELS)];
rc::ServoIn g_ServoIn(g_values, g_workIn, CHANNELS);
rc::ServoOut g_ServoOut(g_pinsOut, Obuff, g_work, CHANNELS);
  rc::Timer1::init();
  pinMode(2, INPUT);
  pinMode(3, INPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  digitalWrite(8,LOW);
  digitalWrite(9,LOW);
  PCMSK0 = (1 << PCINT18) | (1 << PCINT19);
  PCICR = (1 << PCIE0);
  g_ServoIn.start();
  setpoint=map(setpoint,20,150,0,1024);
  g_ServoIn.update();
  int left,front,right,back;
  int temp,temp1,temp2,temp3;
  int e1,e2,e3,e4;
  int op1,op2,op3,op4,opx,opy;
  int d1,d2,d3,d4;
  int x1=4;
  temp=0;
  temp1=0;
  temp2=0;
  temp3=0;
  for(int i=0;i<=x1;i++)
    left = analogRead(A0);
    delay(2);
    temp=temp+left;
  d1=temp/x1;
    right = analogRead(A2);
    delay(2);
    temp1=temp1+right;
   d3=temp1/x1;
    front = analogRead(A1);
    delay(2);
    temp2=temp2+front;
  d2=temp2/x1;
    back = analogRead(A3);
    delay(2);
    temp3=temp3+back;
  d4=temp3/x1;
  e1=d1-setpoint;
  e2=d2-setpoint;
  e3=d3-setpoint;
  e4=d4-setpoint;
  op1=e1*Kp;
  op2=e2*Kp;
  op3=e3*Kp;
  op4=e4*Kp;
  Obuff[1]=g_values[1]-op3+op1;
  Obuff[2]=g_values[2]-op4+op2;
  g_ServoOut.update();
  Serial.print(g_values[1]);
  Serial.print(",");
  Serial.print(g_values[2]);
  Serial.print(",");
  Serial.print(d1);
  Serial.print(",");
  Serial.print(d2);
  Serial.print(",");
  Serial.print(d3);
  Serial.print(",");
  Serial.println(d4);
static uint8_t lastB = 0;
ISR(PCINT18_vect)
  uint8_t newB = PINB;
  uint8_t chgB = newB ^ lastB;
  lastB = newB;
  if (chgB)
    if (chgB & _BV(0))
      g_ServoIn.pinChanged(0, newB & _BV(0));
    if (chgB & _BV(1))
      g_ServoIn.pinChanged(1, newB & _BV(1));
I've uploaded this code to my Arduino Uno and in the "Serial Plotter" I can see the Analog Signals from the IR Sensors, however nothing happens when I touch the channels 1 and 2 on my transmitter.
Seems to me that the Arduino is not "reading" the input of this channels. On the KK board I've checked the "Receiver Test" and there's showing "No Signal" for Channels 1 and 2.
I'm a newbie, so I was hoping that someone could tell me if there's something wrong with this code (and tell me how it should be) or tell me if I'm doing something wrong (I've checked and double checked the connections and channel inputs and outputs).
Please help me with this. I'm willing to give a Paypal Donation to the person that can help me discovering the problem and make this thing to work.
After reading multiple posts, I think that the problem of this code might be the PIN Interrupts... However this is still way above my skills... If someone could help me would be great! I just don't know what to do from here...
You should consider making your own code. It's hard at the beginning, but you'll get there, trust me. Because you have already stumbled upon the biggest problem when using someone else's code. Getting it to work. And you'll probably spend more time figuring this out then you would by making it yourself. Plus you'll learn a lot from it.
