Quadrature Encoder Reading Error
I wasn't sure where to post this but it seems to me like a programming issue so here it goes.
I have a quadrature incremental encoder wired to my Arduino Uno. I am reading my encoder based on code from Quadrature Encoder too Fast for Arduino (with Solution) – Dr Rainer Hessmer
The code works...kind of... It seems to be skipping pulses or the interrupt is cause issues when writing to the LCD. I'm not sure if the issue lies in the if statement where I only write to the LCD when the value changes? Thanks
Below is my entire program.
/* PINS
 * Rs:         Pin 4
 * EN:         Pin 5
 * D4:         Pin 6
 * D5:         Pin 7
 * D6:         Pin 8
 * D7:         Pin 9
 * EncoderA:   Pin 2
 * EncoderB:   Pin 12
 * Button:     Pin 3
 * LED:        Pin 11
 * Detector:   Pin A0
 //Include the LCD, Interrupt and digitalWriteFast Libraries
 #include "Arduino.h"
 #include <LiquidCrystal.h>
 #include <digitalWriteFast.h>
 //Set Pins/Interrupts
   //Initialize an LCD object
     LiquidCrystal lcd(4,5,6,7,8,9);
   //Encoder Pins
     #define c_EncoderInterrupt 0
     #define c_EncoderPinA 2
     #define c_EncoderPinB 12
   //IR Pins
     int infraredPin = 0; //Analog Pin 0
   //Button Pins
     #define zeroButtonInterrupt 1 //Digital Pin 3
   //LED Pins
     int ledPin = 11;
 //Create Custom Characters
 byte tare[8] = {
   B11111,
   B10001,
   B11011,
   B11011,
   B11011,
   B11011,
   B11011,
   B11111,
 byte notare[8] = {
   B11111,
   B11111,
   B11111,
   B11111,
   B11111,
   B11111,
   B11111,
   B11111,
 //Variable Initialization
   //Quadrature Encoder
     #define EncoderIsReversed
     volatile boolean _EncoderBSet;
     volatile long _EncoderTicks = 0;
   //Distance Variables
     double Distance = 0;
     double LastDistance = 0;
     float TicksPerInch = 10.0;
     volatile long ZeroTicks = 0;
   //IR Variables
     double infraredRead = 0;
     double ADCscale = 1.046875; //Reference Voltage/1024*1000 [mV]
   //Zero Variables
     volatile long ZeroIR = 0;
     volatile boolean zeroed = false;
   analogReference(INTERNAL); //Set AREF to 1.1 [Volts]
   //Attach Interrupts
     attachInterrupt(c_EncoderInterrupt, HandleMotorInterruptA, RISING);
     attachInterrupt(zeroButtonInterrupt, flip, RISING); //Attach Interrupt
   //Set LED Pin
     pinMode(ledPin, OUTPUT);
   // Quadrature Encoders Pin Initialization
     pinMode(c_EncoderPinA, INPUT);      // sets pin A as input
     digitalWrite(c_EncoderPinA, LOW);  // turn on pullup resistors
     pinMode(c_EncoderPinB, INPUT);      // sets pin B as input
     digitalWrite(c_EncoderPinB, LOW);  // turn on pullup resistors
   //Begin the LCD interface
     lcd.begin(16,2);
     lcd.createChar(0, tare);
     lcd.createChar(1, notare);
   //Print LCD constants
     lcd.setCursor(0,0);
     //lcd.setCursor(15,0);
     lcd.print("IR =        mV ");
     lcd.print((char)0); //Print Untorn Character
     lcd.setCursor(0,1);
     lcd.print("Dist =        in");
   Distance = (_EncoderTicks - ZeroTicks)/TicksPerInch; // Calculate Distance Traveled minus zero value
   if (Distance != LastDistance) // Only write distance to LCD if it has changed
     //Clear Distance output
     lcd.setCursor(7,1);
     lcd.print("       "); //Clear LCD Distance Output
     lcd.setCursor(7,1);
     lcd.print(Distance); //Print Distance to LCD
     LastDistance = Distance;
   infraredRead = analogRead(infraredPin); //Read Analog Pin0
   lcd.setCursor(5,0);
   lcd.print("       ");  //Clear LCD Voltage output
   lcd.setCursor(5,0);
   lcd.print((infraredRead - ZeroIR)*ADCscale); //Print IR output to LCD and convert to mV
   delay(200); //Delay LCD update so User can read output
 // Interrupt service routine for quadrature encoder
 void HandleMotorInterruptA()
   // Test transition; since the interrupt will only fire on 'rising' we don't need to read pin A
   _EncoderBSet = digitalReadFast(c_EncoderPinB);   // read the input pin
   // and adjust counter + if A leads B
   #ifdef EncoderIsReversed
     _EncoderTicks -= _EncoderBSet ? -1 : +1;
   #else
     _EncoderTicks += _EncoderBSet ? -1 : +1;
   #endif
 void flip()
   zeroed ^= 0x01; //flip button state
   if (zeroed) //Write zero character to LCD
     ZeroIR = analogRead(infraredPin);
     ZeroTicks = _EncoderTicks;
     digitalWrite(ledPin, HIGH);
     lcd.print((char)1);
     ZeroIR = 0;
     ZeroTicks = 0;
     digitalWrite(ledPin, LOW);
     lcd.print((char)0);
I can't see anything obviously wrong with your code. For example, I can't see where you are turning interrupts off, directly or indirectly (apart from digitalWrite, which would, briefly).
Can you quantify the rate at which the encoder would be sending pulses? ie. the time between one and the next, roughly?
It seems to be skipping pulses ...
How do you know this?
