Hi Guys,
Can I just ask you some questions about the TIP122 ST Trans Darlington Transistor please. I just learned how the transistor works, basically after receiving a HIGH signal, Arduino sends a signal to the Base Pin of the transistor through a resistor, and then the transistor will connect its Collector Pin and Emitter Pin to finish the circuit.
Got a simple question here though, why the current from solenoid or from the connected Emitter Pin of transistor (e.g. at 120mA) will not flow to the GND on Arduino which will then damage Arduino, but will flow to the cathode of the power source, please refer to my attached picture. I guess I am really asking how does the negative common ground or buses on the breadboard work. The digital Pin on Arduino also requires a complete circuit to work right ? For example, it goes like from the digital Pin to a resistor then to the Base Pin of transistor and exits from the Emitter pin and back to the GND on Arduino ?
I am using the TIP122 transistor and have listed its specifications as below. I think it's switched by current, so I have to supply the correct current to its Base Pin, but I can not find what is this correct current from its information below. And can you tell me if I understand those information correctly ?
DARLINGTON TRANSISTOR
Transistor Polarity:NPN ---------- not sure what NPN differs from PNP
Collector Emitter Voltage V(br)ceo:100V -------------- the maximum voltage that can flow through the transistor ?
Power Dissipation Pd:2W
DC Collector Current:5A -------------- the maximum current that can flow through the transistor ?
DC Current Gain hFE:1000 -------------- really no idea
Transistor Case Style:TO-220
No. of Pins:3
SVHC:No SVHC (15-Dec-2010)
Av Current Ic:5A -------------- average current 5A ? no idea
Collector Emitter Voltage Vces:2V ----------- how does this differ from the 100V ?
Continuous Collector Current Ic Max:5A --------- what does the term 'Ic' mean....
Current Ic Continuous a Max:5A ---------- no idea
Current Ic hFE:3A -------------- no idea
Device Marking:TIP122
Full Power Rating Temperature:25°C
Hfe Min:1000
No. of Transistors:1
Package / Case:TO-220
Power Dissipation Ptot Max:65W
Termination Type:Through Hole
Transistor Type:Darlington
Voltage Vcbo:100V ransistor
So how do I know what is the correct current I should send to its Base Pin from Arduino ? And it seems I need to connect a resistor between the Base Pin and Arduino digital Pin, how do I work out the resistor ?
Thank you very much guys for helping a learning noob here ![]()
Regards, Jeff
