The TX pin is the transmitter pin, so why is there this dioid(1n4148). As I know dioids are blocking current from one side, so Current can flow from the anode end to the cathode, but not the other direction. How does this work?
The serial databus connection is halfduplex. So if I’m writing something with serial.write() I should block the RX pin. How can I do that since the serial library gives me no option for that?
The TX pin of the Arduino is HIGH when not transmitting; the diode and resistor prevent conflict with the incoming data from the M365.
2a)
You can use Serial.flush after Serial.write to make sure the message goes out before reading a reply.
2b)
The RX will see the data that you transmit.
If there is a sufficient delay between the transmit by the Arduino and the reply from the M365, you can try to Serial.read the data and ignore it. Next you can read the actual reply.
You can also disable the receive functionality while the transmit from the Arduino is in progress. Never tried so below might be incorrect.
The first line comes from the core function HardwareSerial.end() and I think that it will be sufficient; the second line does the opposite (and is used in HardwareSerial::begin()).
Ok I got it for the second point. In the code that you have linked, it seems like he just disables the RX pin while writing than enable the RX pin again by changing value of the UCSR0B register.
The first point still gives me headaches. How can we have high while not transmitting? If we have high while not transmitting, do we not corrupt the RX pin receiving data?
In addition, should the diode not look in the opposite way?
Moreover, if we are transmitting, what logical state do we have than, since high is used while not transmitting?
