Question regarding libraries and a CJMCU AS3935 Breakout Board
Good evening everybody,
Just a little question regarding a CJMCU AS3935 Breakout Board wired to an Arduino Nano.
I am currently trying to build a lightning detector using the AS3935 lightning detector chip on a CJMCU breakout board.
Will this board work with any AS3935 library such as the "SparkFun AS3935 Lightning Detector Library" or the "Austria Microsystems AS3935 Franklin Lightning Detector" or any other library written for the AS3935 chip?
Or ...
Is there a special library, exclusively written for the "CJMCU AS3935 Breakout Board" which I have not discovered yet....?
Thanks a lot for your help...
Cheers...
(I pay the beers)
Eric
(Link to a webpage showing the breakout board)
AMS AS3935 Franklin Lightning Sensor — ESPHome
HI,
Can you please post your code?
Tom.... :smiley: :+1: :coffee: :australia:
Quite likely.
Be aware that it's very sensitive for interferences.
Hello TomGeorgeJackson
For the moment, I just have the code for my project and a rather ugly drawing of the setup...
The hardware is going to arrive in the next few days...
First, I will try to make the screen work.
then ..... I will hook up the breakout board and see what is going on.
But here is the code... (which compiles correctly)
And below the drawing of what I want to build.
#include <EEPROM.h>
#define eeprom_dist 4   //Define eeprom memory location to store mile or km calculation
#define eeprom_level 5  //Define eeprom memory location to store mile or km calculation
#include <Adafruit_PCD8544.h>
 * AS3935 communicates with i2c in this sketch
 * and the Nokia 5110 uses SPI
Adafruit_PCD8544 display = Adafruit_PCD8544(8, 5, 4);
#include "I2C.h"
// include Playing With Fusion AXS3935 libraries
#include "PWFusion_AS3935_I2C.h"
// interrupt trigger global var
volatile int8_t AS3935_ISR_Trig = 0;
// define some values used by the panel and buttons
int adc_key_in = 0;
int z = 0;
int mi = 0;
#define btnLEFT 3
#define btnDOWN 2
#define btnUP 1
#define btnRIGHT 0
#define btnSELECT 4
#define btnNONE 5
// defines for hardware config
#define SI_PIN 9
#define IRQ_PIN 2               // digital pins 2 and 3 are available for interrupt capability
#define AS3935_ADD 0x03         // x03 - standard PWF SEN-39001-R01 config
#define AS3935_CAPACITANCE 104  // <-- SET THIS VALUE TO THE NUMBER LISTED ON YOUR BOARD
// defines for general chip settings
#define AS3935_INDOORS 0
#define AS3935_OUTDOORS 1
#define AS3935_DIST_DIS 1
#define AS3935_DIST_EN 0
int l = 0;
int n = 0;
int lsDist = 0;
int mapDist = 0;
int m = 0;
int dist = 0;
int tt = 0;
// prototypes
void AS3935_ISR();
//--- data that builds the onscreen icons
PWF_AS3935_I2C lightning0((uint8_t)IRQ_PIN, (uint8_t)SI_PIN, (uint8_t)AS3935_ADD);
const unsigned char PROGMEM lightning_bmp[32] = {
  0x01, 0xE0, 0x02, 0x20, 0x0C, 0x18, 0x12, 0x24, 0x21, 0x06, 0x10, 0x02, 0x1F, 0xFC, 0x01, 0xF0,
  0x01, 0xC0, 0x03, 0x80, 0x07, 0xF8, 0x00, 0xF0, 0x00, 0xC0, 0x01, 0x80, 0x01, 0x00, 0x01, 0x00
const unsigned char PROGMEM cloud[32] = {
  0x01, 0xE0, 0x02, 0x20, 0x0C, 0x18, 0x12, 0x24, 0x21, 0x06, 0x10, 0x02, 0x1F, 0xFC, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
const unsigned char PROGMEM lightning[32] = {
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF8, 0x01, 0xF0,
int read_buttons()
  adc_key_in = analogRead(0);  // read the value from Button Panel. Values returned if a button gets pressed and which one it was....
  if (adc_key_in > 1000) return btnNONE;
  if (adc_key_in == 0) return btnLEFT;
  if (adc_key_in > 310 and adc_key_in < 330) return btnDOWN;
  if (adc_key_in > 120 and adc_key_in < 145) return btnUP;
  if (adc_key_in > 480 and adc_key_in < 550) return btnRIGHT;
  if (adc_key_in > 700 and adc_key_in < 800) return btnSELECT;
  return btnNONE;  // when all others fail, return this...
//-----------the config menu
void menu()
  delay(400);
  while (read_buttons() != 4)
    display.clearDisplay();
    display.setCursor(0, 0);
    display.setTextSize(1);
    display.println("Enter=Return");
    display.setCursor(0, 8);
    display.println("Up = Mi");
    display.setCursor(0, 18);
    display.println("down = KM");
    display.setCursor(0, 28);
    display.println("Left=Indoors");
    display.setCursor(0, 38);
    display.println("Right=Outdoors ");
    display.display();
    if (read_buttons() == 1)
      mi = 0;
      EEPROM.write(eeprom_dist, 0);  //Write setting for (1)Mile/(0)Kilometer calculation to EEPROM for recall after power off
      display.println("Set to KM");
      display.display();
      menu();
    if (read_buttons() == 2)
      mi = 1;
      EEPROM.write(eeprom_dist, 1);  //Write setting for Mile/Kilometer calculation to EEPROM for recall after power off
      display.println("Set to Miles");
      display.display();
      menu();
    if (read_buttons() == 0)
      lightning0.AS3935_SetIndoors();
      dist = 0;
      EEPROM.write(eeprom_level, 0);  //Write setting for (0)Indoor/(1)Outdoor setting on AS3935 to EEPROM for recall after power off
      display.println("Indoor");
      display.setCursor(0, 20);
      display.println("Operation");
      display.display();
      menu();
    if (read_buttons() == 3)
      lightning0.AS3935_SetOutdoors();
      dist = 1;
      EEPROM.write(eeprom_level, 1);  //Write setting for (0)Indoor/(1)Outdoor setting on AS3935 to EEPROM for recall after power off
      display.println("Outdoor");
      display.display();
      menu();
  return;
  mi = EEPROM.read(eeprom_dist);     //Read Stored Settings from EEPROM
  dist = EEPROM.read(eeprom_level);  //Read Stored Settings from EEPROM
  pinMode(6, OUTPUT);
  display.begin();
  // init done
  // you can change the contrast around to adapt the display
  // for the best viewing!
  display.setContrast(25);
  display.display();  // show splashscreen
  display.println("Raht Lightning   Detector");
  display.drawBitmap(35, 22, lightning_bmp, 16, 16, 1);
  display.setTextColor(BLACK);
  display.display();
  flash();
  display.display();
  delay(3000);
  // setup for the the I2C library: (enable pullups, set speed to 400kHz)
  I2c.begin();
  I2c.pullup(true);
  I2c.setSpeed(1);
  delay(2);
  lightning0.AS3935_DefInit();  // set registers to default
  // now update sensor cal for your application and power up chip
  lightning0.AS3935_ManualCal(AS3935_CAPACITANCE, AS3935_OUTDOORS, AS3935_DIST_EN);
  // AS3935_ManualCal Parameters:
  //   --> capacitance, in pF (marked on package)
  //   --> indoors/outdoors (AS3935_INDOORS:0 / AS3935_OUTDOORS:1)
  //   --> disturbers (AS3935_DIST_EN:1 / AS3935_DIST_DIS:2)
  // function also powers up the chip
  // enable interrupt (hook IRQ pin to Arduino Uno/Mega interrupt input: 0 -> pin 2, 1 -> pin 3 )
  attachInterrupt(0, AS3935_ISR, RISING);
  lightning0.AS3935_PrintAllRegs();
  AS3935_ISR_Trig = 0;  // clear trigger
//------- this just gets played over and over..... and over...... and o......
  analogWrite(6, 60);  //---turn on the backlight
                       //----- build the screen
  display.println("LastStrike");
  display.println("Dist: " + String(lsDist));
  display.setCursor(50, 8);
  //--- if we pick miles, do this
  if (mi == 1) { display.println(" Mi"); }
  //otherwise assume we want to do this....
  else { display.println(" Km"); }
  display.setCursor(0, 17);
  display.println("0");
  display.setCursor(72, 17);
  //if miles--- 40 km = aaprox 25 miles
  if (mi == 1)
    display.println("25");
    //--- otherwise just scale it for 40 km
    display.println("40");
  display.setCursor(0, 39);
  display.println("Strikes: ");
  display.setCursor(48, 39);
  display.println(String(l));
  display.setCursor(64, 39);
  //-- place an indication that we're set to inside in the lower right corner of the display
  if (dist == 1) { display.println("Out"); }
    //-- or Show were set for outdoors
    display.println("In");
  //--draw the distance scale
  display.drawLine(0, 37, 84, 37, BLACK);
  display.drawLine(0, 25, 0, 37, BLACK);
  display.drawLine(21, 35, 21, 37, BLACK);
  display.drawLine(42, 35, 42, 37, BLACK);
  display.drawLine(63, 35, 63, 37, BLACK);
  display.drawLine(83, 25, 83, 37, BLACK);
  //display.fillCircle(mapDist,35,2,BLACK);
  if (l == 0)
    //-- we begin with no strikes detected
    display.setCursor(9, 24);
  display.println("No Strikes");
  if (l > 0)
    //-if theres a strike. place a little zap at the distance it is...
    display.drawBitmap(mapDist, 22, lightning, 16, 16, 1);
  if (mapDist > 20)
    display.println("Far Ligntning");
  display.display();
  if (0 == AS3935_ISR_Trig)
    //   Serial.println(read_buttons());
    animateCloud();
    //Serial.println(read_buttons());
    if (read_buttons() != 5)
      menu();
    // reset interrupt flag
    // now get interrupt source
    uint8_t int_src = lightning0.AS3935_GetInterruptSrc();
    if (0 == int_src)
      display.setCursor(72, 0);
      display.println("?");
      display.display();
      //delay(1000);
      display.println(" ");
    else if (1 == int_src)
      flash();
      uint8_t lightning_dist_km = lightning0.AS3935_GetLightningDistKm();
      l++;
      display.println("  Lightning!!");
      if (mi == 1)
        lsDist = (lightning_dist_km * 0.62137);
        lsDist = (lightning_dist_km);
      display.println((lsDist));
      mapDist = map(lsDist, 0, 25, 0, 83);
      display.println(" Miles");
      display.display();
      flash();
    else if (2 == int_src)
      //display.clearDisplay();
      display.println("N");
      //  n++;
      display.display();
    else if (3 == int_src)
      display.println("Noise level too high");
      display.display();
    //  lightning0.AS3935_PrintAllRegs(); // for debug...
// this is irq handler for AS3935 interrupts, has to return void and take no arguments
// always make code in interrupt handlers fast and short
void AS3935_ISR()
  AS3935_ISR_Trig = 1;
//---flash the display routine
void flash()
  for (int y = 1; y < 5; y++)
    digitalWrite(6, LOW);
    display.invertDisplay(true);
    delay(100);
    digitalWrite(6, HIGH);
    display.invertDisplay(false);
    delay(100);
//--make that cloud go baby!!
void animateCloud()
  display.drawBitmap(m, 15, cloud, 16, 16, 1);
  display.display();
  if (m >= 80) { m = 0; }
  m++;
  delay(200);
On my ugly drawing, I have a "?" next to the breakout board...
I am still trying to figure out how to connect these pins. (if they have to be connected and to what shall they be connected to.)
If you have an idea, I'll pay for the beer AND a coffee...
Thanks for your help,
Eric
@ kmin
I can imagine that I will certainly pick up every spark in the vicinity...
But I have time to get things working... (I am retired, ha ha ha)
I mean, keep it in mind with your wiring, power supply etc.
It's not something you build with spaghetti wiring on breadboard powered from $0.99 aliexpress charger.
@kmin...
That is for sure...
I am thinking to use a battery as a power supply... to avoid any contact with a standard 220V plug (especially when there is a thunderstorm and electricity gets cut for a few seconds or so...)
That's the way and without any switching converter.
@ kmin
and the end product will be soldered on a vero board (or how they call these things)
Just to make sure that everything is correctly connected.
