Hi all,
I'm looking at this tutorial:
And I've moreorless got it working, except I seem to be getting an issue somewhere between the board and the thingspeak api - I can manually post into the url and it works, just the get command isn't working within the code.
This is the part it seems to be failing - can anyone explain what the Serial.find(">") is actually doing as I don't understand it. I'm not sure where that bracket would come from in the code??
//Use AT commands to send data
Serial.print("AT+CIPSEND=");
Serial.println(cmd.length());
** if(Serial.find(">")){**
//send through command to update values
Serial.print(cmd);
}else{
Serial.println("AT+CIPCLOSE");
if(Serial.find("OK")){
//success! Your most recent values should be online.
return true;
}else{
return false;
alphabeta279:
The ESP-01 sends it, it's an AT command acknowledgement.
Hmm ok, scratching my head then - the API string is being generated as per the tutorial, it just doesn't seem to return this ">" so it fails.
So this is the area I guess it's failing:
cmd += "\r\n";
Serial.println(cmd);
if (Serial.find(">")) {
Serial.print(cmd);
Which in Serial Monitor is generating:
AT+CIPSEND=60
AT+CIPCLOSE
Any ideas how to debug this??
I think your problem happens earlier on in the code that you should have shown us, and didn't. The symptoms suggest that you have failed to make a wifi connection.
#include<stdlib.h>
#include "DHT.h"
#define SSID ""//your network name
#define PASS ""//your network password
#define IP "" // thingspeak.com
#define DHTPIN 7 // what pin the DHT sensor is connected to
#define DHTTYPE DHT11 // Change to DHT22 if that's what you have
#define Baud_Rate 115200 //Another common value is 9600
#define GREEN_LED 3 //optional LED's for debugging
#define RED_LED 4 //optional LED's for debugging
#define DELAY_TIME 60000 //time in ms between posting data to ThingSpeak
//Can use a post also
String GET = "GET /update?key=N7BMROH65LC8OBH8&field1=";
String FIELD2 = "&field2=";
//if you want to add more fields this is how
//String FIELD3 = "&field3=";
bool updated;
DHT dht(DHTPIN, DHTTYPE);
//this runs once
Serial.begin(Baud_Rate);
Serial.println("AT");
delay(5000);
//connect to your wifi netowork
bool connected = connectWiFi();
if(!connected){
//failure, need to check your values and try again
Error();
}else{
Error();
//initalize DHT sensor
dht.begin();
//this runs over and over
void loop(){
float h = dht.readHumidity();
// Read temperature as Fahrenheit (isFahrenheit = true)
float f = dht.readTemperature(true);
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(f)) {
LightRed();
return;
//update ThingSpeak channel with new values
updated = updateTemp(String(f), String(h));
//if update succeeded light up green LED, else light up red LED
if(updated){
LightGreen();
}else{
LightRed();
//wait for delay time before attempting to post again
delay(DELAY_TIME);
bool updateTemp(String tenmpF, String humid){
//initialize your AT command string
String cmd = "AT+CIPSTART=\"TCP\",\"";
//add IP address and port
cmd += IP;
cmd += "\",80";
//connect
delay(2000);
if(Serial.find("Error")){
return false;
//build GET command, ThingSpeak takes Post or Get commands for updates, I use a Get
cmd = GET;
cmd += tenmpF;
cmd += FIELD2;
cmd += humid;
//continue to add data here if you have more fields such as a light sensor
//cmd += FIELD3;
//cmd += <field 3 value>
cmd += "\r\n";
Serial.print(cmd);
}else{
return true;
}else{
return false;
boolean connectWiFi(){
//set ESP8266 mode with AT commands
Serial.println("AT+CWMODE=1");
delay(2000);
//build connection command
String cmd="AT+CWJAP=\"";
cmd+=SSID;
cmd+="\",\"";
cmd+=PASS;
cmd+="\"";
//connect to WiFi network and wait 5 seconds
delay(5000);
//if connected return true, else false
return true;
}else{
return false;
void LightGreen(){
digitalWrite(RED_LED, LOW);
digitalWrite(GREEN_LED, HIGH);
void LightRed(){
digitalWrite(GREEN_LED, LOW);
digitalWrite(RED_LED, HIGH);
//if an error has occurred alternate green and red leds
void Error(){
while(true){
LightRed();
delay(2000);
LightGreen();
delay(2000);
Hmm pretty sure it gets that far - as have been logging throughout - full serial monitor code is printing out the wifi connection (ie my SSID/Pass etc) and progressing through.
I can paste the generated API string into thingspeak and it logs fine, so formatting appears ok
Full code is:
#include<stdlib.h>
#include "DHT.h"
#define SSID "<MY NETWORK NAME>"//your network name
#define PASS "<MY NETWORK PASS>"//your network password
#define IP "thingspeak.com" // thingspeak.com
#define DHTTYPE DHT22 // Change to DHT22 if that's what you have
#define DELAY_TIME 30000 //time in ms between posting data to ThingSpeak
String GET = "GET /update?key=<MY API STRING>&field1=";
bool updated;
//this runs once
delay(5000);
if (Serial.find("OK")) {
if (!connected) {
Error();
Serial.println("Failed to connect to wifi");
Error();
dht.begin();
LightRed();
return;
if (updated) {
LightGreen();
LightRed();
delay(DELAY_TIME);
bool updateTemp(String tenmpF, String humid) {
cmd += IP;
cmd += "\",80";
//connect
delay(2000);
if (Serial.find("Error")) {
return false;
cmd = GET;
cmd += tenmpF;
cmd += FIELD2;
cmd += humid;
//cmd += FIELD3;
cmd += "\r\n";
Serial.print(cmd);
Serial.println("Data Sent!");
return true;
Serial.println("Data Fail!");
return false;
boolean connectWiFi() {
delay(2000);
String cmd = "AT+CWJAP=\"";
cmd += SSID;
cmd += "\",\"";
cmd += PASS;
cmd += "\"";
delay(5000);
return true;
return false;
void LightGreen() {
void LightRed() {
void Error() {
while (true) {
LightRed();
delay(2000);
LightGreen();
delay(2000);
Please go back and edit your post so that the code is placed inside code tags, to make it forum compatible. Also please post the actual serial debug message stream.
SORRY!! Slap taken!
I've pasted serial monitor code below (just redacted the sensitive bits)
AT+CWMODE=1
AT+CWJAP="<SSID>","<NETWORK PASS>"
AT+CIPSTART="TCP","api.thingspeak.com",80
GET /update?key=<API KEY>&field1=71.96&field2=35.90
AT+CIPSEND=60
AT+CIPCLOSE
Data Fail!
That can not be right - the second line in setup() just sends an "AT" with a newline. That does not show up in your output.
Yes, sorry that was cut off - had to reset because I was forgetting to disconnect the wires in the serial ports 1 & 2.
I don't think your configuration is useful for debugging - you can't see the responses from the ESP.
Yes, complete copy and paste from the tutorial - agree it's tricky to interpret, hence I'm asking!
Any suggestions how to view the responses from the ESP? Should I be printing out the responses at certain points?
