Race car data logger
I'd like to put together a project to collect GPS location (GPS Shield), acceleration/gyro data (9 Axis Motion Shield) and write this data to an SD or MicroSD card (SD Proto Shield) at at least a 10 hz rate. Does the GPS Shield provide this rate, and can I make all three of these Shields work together with a main board, and which would be a good suggestion? Are there some incompatibility issues to overcome?
Know that common GPS circuits are not very precise. A 10 meter deviation can be expected.
Is the project still interesting?
Why 10 times per second? How will the data be evaluated later?
Since GPS only registers location, you would have to calculate all the other values.
You shouldn't have any problems recording the data as long as you choose a microcontroller that can do the job.(e.g., the UNO/Nano may fall short with GPS recording at 10Hz)
Regarding the incompatibility between shields, I haven't worked with any (I always use modules) so I don't know.
The GPS will just be used to present a graphic of the track driven on. This will be time-correlated with the rest of the data, so that one can see data points with respect to where on the track the data occurred. Ideally other points would be collected as the project progresses, such as throttle position, braking, steering input, etc.
What kind of track? Note that the GPS coordinates can be 10 meter wrong. Is that okey?
Autocross. Absolute accuracy is not as critical as relative accuracy. If the coordinates are 10m off from the real world, but are accurate with respect to each other, that satisfies the requirement.
You can't count on a stable amount of "off position".
I remember a guy plotting the position every some time unit and got a circle filled with ca 10 meter radius.
What is GPS RTK? - SparkFun Learn .
A GPS receiver capable of RTK takes in the normal signals from the Global Navigation Satellite Systems along with a correction stream to achieve 1cm positional accuracy. GNSS includes satellites from GPS (USA), GLONASS (Russia), Beidou (China), and Galileo (Europe). On top of these signals an RTK receiver takes in an RTCM correction stream and then calculates your location with 1cm accuracy in real time. The rate varies between receivers but most will output a solution at least once per second; some receivers can output this higher precision solution up to 20 times a second.
20 Hz
So what relative position accuracy do you actually want\need ?
You will find they will be random in relation to other positions. I have seen that land survey using GPS requires integration of positions for at least 1/2 hour.
