So for those of you who read my other post, I was having trouble getting readings for the Ultrasonic sensors from radio shack on the arduino. I came to realize that the 5V and GRD pins on the arduino board itself were defective and every time I plugged them in, my readings would go back to 0in,0cm. However, now I am using a lab power source and the D7 pin on the arduino is still connected to the SIG pin on the sensor. I receive a few believable readings in the serial port, but it only lasts a few seconds before every reading turns into 57inch, no matter how far or close I put the sensor to a solid object. A copy of the two codes that I have been testing are printed below. Any help on this would sure make life a whole lot better.
Thank you
Code #1
const int pingPin = 7;
// initialize serial communication:
pinMode(pingPin, OUTPUT);
// establish variables for duration of the ping,
// and the distance result in inches and centimeters:
long duration, inches, cm;
// The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
// Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
digitalWrite(pingPin, LOW);
delayMicroseconds(2);
digitalWrite(pingPin, HIGH);
delayMicroseconds(5);
// The same pin is used to read the signal from the PING))): a HIGH
// pulse whose duration is the time (in microseconds) from the sending
// of the ping to the reception of its echo off of an object.
pinMode(pingPin, INPUT);
duration = pulseIn(pingPin, HIGH);
// convert the time into a distance
inches = microsecondsToInches(duration);
cm = microsecondsToCentimeters(duration);
Serial.print(inches);
Serial.print("in, ");
Serial.print(cm);
Serial.print("cm");
long microsecondsToInches(long microseconds)
// According to Parallax's datasheet for the PING))), there are
// 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
// second). This gives the distance travelled by the ping, outbound
// and return, so we divide by 2 to get the distance of the obstacle.
// See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds)
// The speed of sound is 340 m/s or 29 microseconds per centimeter.
// The ping travels out and back, so to find the distance of the
// object we take half of the distance travelled.
return microseconds / 29 / 2;
Code #2
#include "Arduino.h"
class Ultrasonic
public:
Ultrasonic(int pin);
void DistanceMeasure(void);
long microsecondsToCentimeters(void);
long microsecondsToInches(void);
private:
int _pin;//pin number of Arduino that is connected with SIG pin of Ultrasonic Ranger.
long duration;// the Pulse time received;
Ultrasonic::Ultrasonic(int pin)
_pin = pin;
/Begin the detection and get the pulse back signal/
void Ultrasonic::DistanceMeasure(void)
pinMode(_pin, OUTPUT);
digitalWrite(_pin, LOW);
digitalWrite(_pin, HIGH);
digitalWrite(_pin,LOW);
pinMode(_pin,INPUT);
duration = pulseIn(_pin,HIGH);
/The measured distance from the range 0 to 400 Centimeters/
long Ultrasonic::microsecondsToCentimeters(void)
return duration/29/2;
/The measured distance from the range 0 to 157 Inches/
long Ultrasonic::microsecondsToInches(void)
return duration/74/2;
Ultrasonic ultrasonic(7);
pinMode(7, OUTPUT);
long RangeInInches;
long RangeInCentimeters;
ultrasonic.DistanceMeasure();// get the current signal time;
RangeInInches = ultrasonic.microsecondsToInches();//convert the time to inches;
RangeInCentimeters = ultrasonic.microsecondsToCentimeters();//convert the time to centimeters
Serial.println("The distance to obstacles in front is: ");
Serial.print(RangeInInches);//0~157 inches
Serial.println(" inch");
Serial.print(RangeInCentimeters);//0~400cm
Serial.println(" cm");
