Hello every body .Hope that every thing good. I am new here; so I need your help please
I want to do a program which modify the temperature in ramp. So i used :
- 2 thermocouples K and the thermocouple’s library MAX6675
- the Arduino Card MEGA 2750 and a coil’s contact wich will be excited by the courant of the ARDUINO card. this contact will increase the courant and communicate it to a heating resistence .This one will vary the temperature.
- So this is the program that i made and i would like to know ; how i can modify it to get a RAMP TEMPERATURE , which is stabilised at 320 celsius degree.
#include"max6675.h" // Ze call the termocouple’s library
//we difine the different pin of the thermocouple ‘’Four’’ to Arduino
int ktcSO=8;// Output pin that carries each bit
int ktcCS=9;// Input pin that tells the Arduino board that it is time for the thermocouple to read and send the data
int ktcCLK=10;// Pin that indicates when a new data bit is entered
// We do the same for the ‘’creuset’’ thermocouple
int ktcaSO=11;
int ktcaCS=12;
int ktcaCLK=13;
// The pins are associated with their thermocouple respectively
Max6675 ktc(ktcSO,ktcCS,ktcCLK);
MAX6675 ktca(ktcaSO,ktcaCS,ktcaCLK);
// We start the connection
pinMode(7,OUTPUT);// We define pin 7 To transmit information to the system
delay(50);
Serial.println("CLEARSHEET");// We delete the Excel table
Serial.println("LABEL,Temp Four, Temp creuset,Timer");// We define the 2 columns of the table Temp Four and Temp creuse
exxcel();
four();
void excel(){
Serial.println((String)"DATA,"+ktc.readCelsius()+","+ktca.readCelsius()+","+"TIMER");
// The temperature of the thermocouples is added to each column; ktc.readCelsius reads the temperature
delay(2000);//
void four (){
// If the oven temperature is less than 320 (changeable), the output is set to the LOW state, which turns on the heating collar.
if(ktc.readCelsius()<=320){
digitalWrite(7,HIGH);
delay(10);//
// If the oven temperature is above 320 (changeable), the output is set to the LOW state, which turns off the heating collar
if(ktc.readCelsius()>=320){
digitalWrite(7,LOW);
delay(10);//
ramp temperatur.pdf (165 KB)
