Random delay for blinking LED giving an error
Ok so I am just starting up with this whole thing and I figured that randomizing the delay on a blinking LED would be fairly simple but I keep getting an error message that reads
"/tmp/768476775/sketch_jul6a/sketch_jul6a.ino:14:9: error: expected ';' before 'break'
delay break; // wait for a second
exit status 1"
Ii says that there is a ";" in front of the variable where it shouldn't be but I couldn't figure it ut after twiddling with it for a while so I figured I'd ask here.
Code:
// the setup function runs once when you press reset or power the board
  // initialize digital pin LED_BUILTIN as an output.
  pinMode(LED_BUILTIN, OUTPUT);
  int break = long random(0,1000);
// the loop function runs over and over again forever
  int break = long random(0,10000);
  digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
Hope I'm not missing anything too obvious, Thanks in advance.
break is a keyword and you are trying to use it as a variable. Change that to something else like dly for instance.
delay requires a number or variable inside parenthesis. Example delay(dly);
That should allow you to make progress.
No.
It says that a ";" was expected. That means that the compiler "thought" that there should be a ";" but it was missing. That was a result of getting the compiler really confused.
Just follow the advice that was given by PickyBiker to rename your variable and to use parentheses and you will get going again.
Thanks, I ended up getting rid of the variable since it was throwing another error, but your advice did fix the original problem.
