Hey everyone,
I have a number of bitmap sequences I'd like to display using an OLED color display (adafruit SSD1351) that I'm reading off of an SD card. Because the card doesn't read directories, I've had to use the char function to define these sequences. There will be an opening sequence, and a play button to randomize an outcome sequence. I'm fairly new to arduino, and I've been google to help me out with most of the code. But I'm getting an error stating 'cannot convert 'char**' to 'char*' for argument '1' to 'void bmpDraw(char*, uint8_t, uint8_t)'
Appologies if this is a complete noob post! Thanks for your help.
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1351.h>
#include <SD.h>
#include <SPI.h>
#define sclk 13
#define mosi 11
#define cs 10
#define rst 9
#define dc 8
#define SD_CS 4
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
Adafruit_SSD1351 tft = Adafruit_SSD1351(cs, dc, rst);
File bmpFile;
const int buttonPin = 2;
int bmpWidth, bmpHeight;
uint8_t bmpDepth, bmpImageoffset;
int buttonState = 0;
char* alien01Image [] = {
"05.bmp", "12.bmp"
char* alien02Image [] = {
"06.bmp", "13.bmp"
char* alien03Image [] = {
"07.bmp", "14.bmp"
char* alien04Image [] = {
"08.bmp", "15.bmp"
char* alien05Image [] = {
"09.bmp", "16.bmp"
char* alien06Image [] = {
"10.bmp", "17.bmp"
char* alien07Image [] = {
"11.bmp", "18.bmp"
char** alienImage [] = {
alien01Image, alien02Image, alien03Image, alien04Image, alien05Image, alien06Image, alien07Image
void setup(void) {
pinMode(cs, OUTPUT);
digitalWrite(cs, HIGH);
pinMode(buttonPin, INPUT);
// initialize the OLED
tft.begin();
Serial.println("init");
tft.fillScreen(BLUE);
Serial.print("Initializing SD card...");
if (!SD.begin(SD_CS)) {
Serial.println("failed!");
return;
Serial.println("SD OK!");
// This function opens a Windows Bitmap (BMP) file and
// displays it at the given coordinates. It's sped up
// by reading many pixels worth of data at a time
// (rather than pixel by pixel). Increasing the buffer
// size takes more of the Arduino's precious RAM but
// makes loading a little faster. 20 pixels seems a
// good balance.
// read the pushbutton input pin:
buttonState = digitalRead(buttonPin);
bmpDraw("00.bmp", 16, 0);
delay(0);
bmpDraw("01.bmp", 16, 0);
delay(0);
if (buttonState ==HIGH) {
bmpDraw("02.bmp", 30, 37);
delay(0);
bmpDraw("03.bmp", 16, 0);
delay(0);
bmpDraw("04.bmp", 16, 0);
delay(0);
bmpDraw("05.bmp", 39, 11);
delay(0);
bmpDraw("06.bmp", 39, 11);
delay(0);
bmpDraw("07.bmp", 39, 11);
delay(0);
bmpDraw("08.bmp", 39, 11);
delay(0);
bmpDraw("09.bmp", 39, 11);
delay(0);
bmpDraw("10.bmp", 39, 11);
delay(0);
bmpDraw("11.bmp", 39, 11);
delay(0);
bmpDraw("12.bmp", 39, 11);
delay(0);
bmpDraw("13.bmp", 39, 11);
delay(0);
int imgNum = random(0,6);
bmpDraw(alienImage[imgNum], 0 , 0);
delay(0)
#define BUFFPIXEL 20
void bmpDraw(char *filename, uint8_t x, uint8_t y) {
File bmpFile;
int bmpWidth, bmpHeight; // W+H in pixels
uint8_t bmpDepth; // Bit depth (currently must be 24)
uint32_t bmpImageoffset; // Start of image data in file
uint32_t rowSize; // Not always = bmpWidth; may have padding
uint8_t sdbuffer[3*BUFFPIXEL]; // pixel buffer (R+G+B per pixel)
uint8_t buffidx = sizeof(sdbuffer); // Current position in sdbuffer
boolean goodBmp = false; // Set to true on valid header parse
boolean flip = true; // BMP is stored bottom-to-top
int w, h, row, col;
uint8_t r, g, b;
uint32_t pos = 0, startTime = millis();
if((x >= tft.width()) || (y >= tft.height())) return;
Serial.print("Loading image '");
Serial.print(filename);
Serial.println('\'');
// Open requested file on SD card
if ((bmpFile = SD.open(filename)) == NULL) {
Serial.print("File not found");
return;
// Parse BMP header
if(read16(bmpFile) == 0x4D42) { // BMP signature
Serial.print("File size: "); Serial.println(read32(bmpFile));
(void)read32(bmpFile); // Read & ignore creator bytes
bmpImageoffset = read32(bmpFile); // Start of image data
Serial.print("Image Offset: "); Serial.println(bmpImageoffset, DEC);
// Read DIB header
Serial.print("Header size: "); Serial.println(read32(bmpFile));
bmpWidth = read32(bmpFile);
bmpHeight = read32(bmpFile);
if(read16(bmpFile) == 1) { // # planes -- must be '1'
bmpDepth = read16(bmpFile); // bits per pixel
Serial.print("Bit Depth: "); Serial.println(bmpDepth);
if((bmpDepth == 24) && (read32(bmpFile) == 0)) { // 0 = uncompressed
goodBmp = true; // Supported BMP format -- proceed!
Serial.print("Image size: ");
Serial.print(bmpWidth);
Serial.print('x');
Serial.println(bmpHeight);
// BMP rows are padded (if needed) to 4-byte boundary
rowSize = (bmpWidth * 3 + 3) & ~3;
// Crop area to be loaded
w = bmpWidth;
h = bmpHeight;
if((x+w-1) >= tft.width()) w = tft.width() - x;
if((y+h-1) >= tft.height()) h = tft.height() - y;
for (row=0; row<h; row++) { // For each scanline...
tft.goTo(x, y+row);
// Seek to start of scan line. It might seem labor-
// intensive to be doing this on every line, but this
// method covers a lot of gritty details like cropping
// and scanline padding. Also, the seek only takes
// place if the file position actually needs to change
// (avoids a lot of cluster math in SD library).
if(flip) // Bitmap is stored bottom-to-top order (normal BMP)
pos = bmpImageoffset + (bmpHeight - 1 - row) * rowSize;
else // Bitmap is stored top-to-bottom
pos = bmpImageoffset + row * rowSize;
if(bmpFile.position() != pos) { // Need seek?
bmpFile.seek(pos);
buffidx = sizeof(sdbuffer); // Force buffer reload
// optimize by setting pins now
for (col=0; col<w; col++) { // For each pixel...
// Time to read more pixel data?
if (buffidx >= sizeof(sdbuffer)) { // Indeed
bmpFile.read(sdbuffer, sizeof(sdbuffer));
buffidx = 0; // Set index to beginning
// Convert pixel from BMP to TFT format, push to display
b = sdbuffer[buffidx++];
g = sdbuffer[buffidx++];
r = sdbuffer[buffidx++];
tft.drawPixel(x+col, y+row, tft.Color565(r,g,b));
// optimized!
//tft.pushColor(tft.Color565(r,g,b));
} // end pixel
} // end scanline
Serial.print("Loaded in ");
Serial.print(millis() - startTime);
Serial.println(" ms");
} // end goodBmp
bmpFile.close();
if(!goodBmp) Serial.println("BMP format not recognized.");
// These read 16- and 32-bit types from the SD card file.
// BMP data is stored little-endian, Arduino is little-endian too.
// May need to reverse subscript order if porting elsewhere.
uint16_t read16(File f) {
uint16_t result;
((uint8_t *)&result)[0] = f.read(); // LSB
((uint8_t *)&result)[1] = f.read(); // MSB
return result;
uint32_t read32(File f) {
uint32_t result;
((uint8_t *)&result)[2] = f.read();
((uint8_t *)&result)[3] = f.read(); // MSB
return result;
