Okay, so I tried to create a random string generator that will printout 5 random characters with this code.
delay(2000);
GenTxt();
void GenTxt(){
int generated=0;
while (generated<6)
byte randomValue = random(0, 26);
char letter = randomValue + 'a';
if(randomValue > 26)
letter = (randomValue - 26) ;
Serial.print(letter);
generated ++;
Serial.println("");
Then I noticed that this code give's me the same random string every time it restarts.
lrfkqy
uqfjkx
yqvnrt
ysfrzr
mzlygf
everytime arduino starts it will generate same string. Idk what is wrong. Is there any other way to random 5 character string?
Working as designed. The Arduino generates the same string of "random" numbers when reset. There are ways round this. Take a look at the randomSeed() function which allows you to seed the "random" number generator with a different start position.
One way often cited to randomise the output further is to use the value read from a floating analogue input as the parameter of randomSeed() but its effectiveness is also debated.
One way that I have used to produce a possibly more random value to use with randomSeed() is to wait in a loop for user input and to use the value of millis() at the time of user input as the randomSeed() parameter.
UKHeliBob:
Thanks, this actually helped me and now I have new idea. God Bless mate !
