range finder with LED and buzzer
Hello all
I have a problem. I am making a range finder and if the distance is less than 10 cm a red LED should light up and the buzzer should make a noise, but I get an error message in my code. can anyone help me?
(if the adstand is larger than 10 cm, a green LED lights up)
thank you in advance
Kind regards
Cisse
[#include <LiquidCrystal.h>
LiquidCrystal lcd(1, 2, 4, 5, 6, 7);
const int trigPin = 9;
const int echoPin = 10;
long duration;
int distanceCm, distanceInch;
lcd.begin(16,2);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(12, OUTPUT);
pinMode(13, OUTPUT);
pinMode(11, OUTPUT);
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distanceCm= duration0.036/2;
distanceInch = duration
0.0133/2;
lcd.setCursor(0,0);
lcd.print("Distance: ");
lcd.print(distanceCm);
lcd.print(" cm");
delay(10);
lcd.setCursor(0,1);
lcd.print(distanceInch);
lcd.print("inch");
delay(10);
if(distanceCm ==<10) // here is the error message
digitalWrite(12, HIGH); // red LED turns on
digitalWrite(11, HIGH);// buzzer turns on
digitalWrite(13, LOW);// green LED turn off
else(
digitalWrite(12, LOW);// red LED turns off
noTone(13);// buzzer turns off
digitalWrite(13, HIGH);// green LED turn on
How can something be equal and less than?
Then you're going to have problems with () when you should have {}.
And no {} when you should have {}.
Please remember to use code tags when posting code.
the distance has to be minus 10 so I need to delete the "=="?
and can you pls explain what you mean with the {} and ()?
if(distanceCm <10) // here it looks like you want
digitalWrite(12, HIGH); // all these line to be part
digitalWrite(11, HIGH);// of the conditional block,
digitalWrite(13, LOW);// but they're not.
You need to enclose them in a pair of these { }
else(
Here you shouldn't use ( ), you should use { }
okay thanks for the help and I will remember not to just put the code in the text
hello
can someone help me with this error message?
pls also tell me if I do something else wrong.
this is te message:exit status 1
expected '(' before '{' token
long duration;
lcd.begin(16,2);
distanceCm= duration*0.036/2;
distanceInch = duration*0.0133/2;
lcd.setCursor(0,0);
lcd.print("  cm");
delay(10);
lcd.setCursor(0,1);
lcd.print("inch");
delay(10);
if{(distanceCm <10) // here is the error message
else{
if{(distanceCm <10)
What do I need to do?
You need to study the syntax for if()
thanks for the tip!! :wink:
