Just a minor one.
This will make somebody think that avrdude is kicked of before the port is found. It might however put people on the wrong foot if an upload would fail with a message that the upload port could not be found.
Thanks @sterretje . This issue is being tracked here:
opened 12:35AM - 26 Jan 22 UTC
topic: code
type: imperfection
topic: gRPC
When burning a bootloader, the IDE runs avrdude twice in sequence. At least, th… ey should be in sequence (not parallel) because they use the same programmer to interact with the board being programmed.
However, the console output window of the IDE shows the second command being issued before the output of the first command has completed. This is probably a bug in the buffering of avrdude's output (stderr, maybe stdout) on its way to display on the IDE's console window.
This is with IDE 1.8.19 on Windows 10 (with current updates). Only one instance of the IDE application and window was running. IDE preferences set to verbose.
Below is an example output. Note the second invocation of avrdude is followed by about 28 lines of additional output from the first command before the second command shows avrdude's startup Version message.
C:\Users\graham\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\graham\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega168p -cstk500v1 -PCOM7 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x04:m -Uhfuse:w:0b11011111:m -Ulfuse:w:0xE0:m
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\graham\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM7
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega168P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 512 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 16384 128 128 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e940b (probably m168p)
avrdude: erasing chip
avrdude: reading input file "0x3F"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.01s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3F:
avrdude: load data lock data from input file 0x3F:
avrdude: input file 0x3F contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.01s
avrdude: verifying ...
avrdude: 1 bytes of lock verified
avrdude: reading input file "0x04"
avrdude: writing efuse (1 bytes):
Writing | ***failed;
################################################## | 100% 0.07s
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0x04:
avrdude: load data efuse data from input file 0x04:
avrdude: input file 0x04 contains 1 bytes
avrdude: reading on-chip efuse data:
avrdude: WARNING: invalid value for unused bits in fuse "efuse", should be set to 1 according to datasheet
This behaviour is deprecated and will result in an error in future version
You probably want to use 0xfc instead of 0x04 (double check with your datasheet first).
avrdude: 1 bytes of efuse verified
avrdude: reading input file "0b11011111"
avrdude: writing hfuse (1 bytes):
C:\Users\graham\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\graham\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega168p -cstk500v1 -PCOM7 -b19200 -Uflash:w:C:\Users\graham\AppData\Local\Arduino15\packages\diy_atmega8_series\hardware\avr\2020.10.9/bootloaders/optiboot_atmega168p_16000000L_57600.hex:i -Ulock:w:0x3F:m
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0b11011111:
avrdude: load data hfuse data from input file 0b11011111:
avrdude: input file 0b11011111 contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xE0"
avrdude: writing lfuse (1 bytes):
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xE0:
avrdude: load data lfuse data from input file 0xE0:
avrdude: input file 0xE0 contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: 1 bytes of lfuse verified
avrdude done. Thank you.
Using Port : COM7
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 2
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: reading input file "C:\Users\graham\AppData\Local\Arduino15\packages\diy_atmega8_series\hardware\avr\2020.10.9/bootloaders/optiboot_atmega168p_16000000L_57600.hex"
avrdude: writing flash (16384 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 16384 bytes of flash written
avrdude: verifying flash memory against C:\Users\graham\AppData\Local\Arduino15\packages\diy_atmega8_series\hardware\avr\2020.10.9/bootloaders/optiboot_atmega168p_16000000L_57600.hex:
avrdude: load data flash data from input file C:\Users\graham\AppData\Local\Arduino15\packages\diy_atmega8_series\hardware\avr\2020.10.9/bootloaders/optiboot_atmega168p_16000000L_57600.hex:
avrdude: input file C:\Users\graham\AppData\Local\Arduino15\packages\diy_atmega8_series\hardware\avr\2020.10.9/bootloaders/optiboot_atmega168p_16000000L_57600.hex contains 16384 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% -0.00s
avrdude: 16384 bytes of flash verified
I can see from looking at the contents of the streams Arduino CLI sends to Arduino IDE 2.x via the gRPC interface they use for communication that the output is out of order there.
I see something like this was mentioned as a known defect during the initial implementation of multi-core support in arduino-builder (which later became Arduino CLI:
https://github.com/arduino/arduino-builder/issues/17#issuecomment-160946001
It lacks proper output management. At the moment, everything is thrown at stdout, meaning the output is likely to get clutter and logger messages will eventually contain syntax errors
