Hi forum
I would like to react on a published MQTT message.
I have actually found guides for this but somehow they do not work for me.
In a nutshell I am subscribing to a topic with
void onMqttMessage(char* topic, char* payload, AsyncMqttClientMessageProperties properties, size_t len, size_t index, size_t total)
and then check for this topic with
if(strcmp(topic, MQTT_SUB) == 0 )
Unfortunately I am getting a compilation error: "'topic' was not declared in this scope", although for some people this seemed to work.
Any help would be welcome.
Here is the whole code in case needed:
#include <ESP8266WiFi.h>
#include <Ticker.h>
#include <AsyncMqttClient.h>
#define WIFI_SSID "ABC"
#define WIFI_PASSWORD "ABC"
#define MQTT_HOST IPAddress(xx, xx, xx, xx)
#define MQTT_PORT 1883
#define MQTT_SUB "ipcheck"
AsyncMqttClient mqttClient;
Ticker mqttReconnectTimer;
WiFiEventHandler wifiConnectHandler;
WiFiEventHandler wifiDisconnectHandler;
Ticker wifiReconnectTimer;
void connectToWifi() {
Serial.println("Connecting to Wi-Fi...");
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
void onWifiConnect(const WiFiEventStationModeGotIP& event) {
Serial.println("Connected to Wi-Fi.");
connectToMqtt();
void onWifiDisconnect(const WiFiEventStationModeDisconnected& event) {
Serial.println("Disconnected from Wi-Fi.");
mqttReconnectTimer.detach(); // ensure we don't reconnect to MQTT while reconnecting to Wi-Fi
wifiReconnectTimer.once(2, connectToWifi);
void connectToMqtt() {
Serial.println("Connecting to MQTT...");
mqttClient.connect();
void onMqttConnect(bool sessionPresent) {
Serial.println("Connected to MQTT.");
Serial.print("Session present: ");
Serial.println(sessionPresent);
uint16_t packetIdSub = mqttClient.subscribe(MQTT_SUB, 2);
Serial.print("Subscribing at QoS 2, packetId: ");
Serial.println(packetIdSub);
void onMqttDisconnect(AsyncMqttClientDisconnectReason reason) {
Serial.println("Disconnected from MQTT.");
if (WiFi.isConnected()) {
mqttReconnectTimer.once(2, connectToMqtt);
void onMqttPublish(uint16_t packetId) {
Serial.print("Publish acknowledged.");
Serial.print(" packetId: ");
Serial.println(packetId);
void onMqttMessage(char* topic, char* payload, AsyncMqttClientMessageProperties properties, size_t len, size_t index, size_t total) {
Serial.println("Publish received.");
Serial.print(" topic: ");
Serial.println(topic);
Serial.println("Payload");
Serial.println(payload);
Serial.print(" qos: ");
Serial.println(properties.qos);
Serial.print(" dup: ");
Serial.println(properties.dup);
Serial.print(" retain: ");
Serial.println(properties.retain);
Serial.print(" len: ");
Serial.println(len);
Serial.print(" index: ");
Serial.println(index);
Serial.print(" total: ");
Serial.println(total);
wifiConnectHandler = WiFi.onStationModeGotIP(onWifiConnect);
wifiDisconnectHandler = WiFi.onStationModeDisconnected(onWifiDisconnect);
mqttClient.onConnect(onMqttConnect);
mqttClient.onDisconnect(onMqttDisconnect);
mqttClient.onPublish(onMqttPublish); //Löschen?
mqttClient.setServer(MQTT_HOST, MQTT_PORT);
mqttClient.onMessage(onMqttMessage);
connectToWifi();
if(strcmp(topic, MQTT_SUB) == 0 ) //match
Serial.println("Message received");
