Read a Raw Byte with C++ on Linux from Library Port
I'm porting a C++ program from Visual Studio 2010 on Windows to Ubuntu 12.04. It uses this SerialClass.cpp and .h library to connect to the Arduino on Windows:
http://playground.arduino.cc/Interfacing/CPPWindows
I've removed all dependencies on this library except this call to ReadData:
  // read a raw byte
			if (SP->ReadData(incomingData + readResult,1) == 1)
				readResult++;
				continue;
I'm looking for a function, library, or a way to rewrite ReadData to do the same thing in Linux. Any advice? Thanks!
Here's ReadData from Serial.cpp:
    int Serial::ReadData(char *buffer, unsigned int nbChar)
    //Number of bytes we'll have read
    DWORD bytesRead;
    //Number of bytes we'll really ask to read
    unsigned int toRead;
    //Use the ClearCommError function to get status info on the Serial port
    ClearCommError(this->hSerial, &this->errors, &this->status);
    //Check if there is something to read
    if(this->status.cbInQue>0)
        //If there is we check if there is enough data to read the required number
        //of characters, if not we'll read only the available characters to prevent
        //locking of the application.
        if(this->status.cbInQue>nbChar)
            toRead = nbChar;
            toRead = this->status.cbInQue;
        //Try to read the require number of chars, and return the number of read bytes on success
        if(ReadFile(this->hSerial, buffer, toRead, &bytesRead, NULL) && bytesRead != 0)
            return bytesRead;
    //If nothing has been read, or that an error was detected return -1
    return -1;
Here is the original function in full (Windows):
And here's the one that I've been trying to rewrite for Linux:
