Read and save IMEI from serial port
Hello Gents, need your help
I have Mega2560 and SIM900 Shield connected on Serial2. My task is to catch IMEI from AT (AT+GSN) response. How I can do it?
I created this code, but it is not correct for this task/
// Buffer function
 void IMEI_get () {
sendATcommand("AT+GSN", "OK", "ERROR", 500);
 for (i=0;i < 64;i++){
  if (Serial2.available()) {
  c = Serial2.read();
  IMEI = String(IMEI + c);
 if (IMEI.length()>=64){
 Serial.println(IMEI);
 IMEI ="";
To quote an often used statement "it's probably in the code you didn't post".
Paul
char char_buffer;
String string_buffer = "";
int buffer_space = 1000;
int onModulePin = 9;
int8_t answer;
String IMEI;
 int i =1;
 char c;
Serial2.begin(9600);
delay(2000);
   Serial.println("Reading IMEI...");
   void modem_power_on();
   IMEI_get ();
   void modem_power_off();
   Serial.println("IMEI=" + IMEI);
// SendATcommand function
byte sendATcommand(String ATcommand, String answer1, String answer2, unsigned int timeout){
   byte reply = 1;
   String content = "";
   char character;
   //Clean the modem input buffer
   while(Serial2.available()>0) Serial2.read();
   //Send the atcommand to the modem
   Serial2.println(ATcommand);
   delay(100);
   unsigned int timeprevious = millis();
   while((reply == 1) && ((millis() - timeprevious) < timeout)){
     while(Serial2.available()>0) {
       character = Serial2.read();
       content.concat(character);
       Serial.print(character);
       delay(10);
     //Stop reading conditions
     if (content.indexOf(answer1) != -1){
       reply = 0;
     }else if(content.indexOf(answer2) != -1){
       reply = 2;
     }else{
       //Nothing to do...
   return reply;
// Modem ON fuction
void modem_power_on(){
    uint8_t answer=0;
    // проверяем запущен ли уже модем
    answer = sendATcommand("AT", "OK", "ERROR", 2000);
    if (answer == 1)
        digitalWrite(onModulePin,HIGH);
        delay(3000);
        digitalWrite(onModulePin,LOW);
        while(answer == 1){     // Отправляем запрос каждые 2 сек и ждем ответа модема
// Modem OFF function
void modem_power_off(){
    uint8_t answer=0;
    if (answer == 0)
        delay(3000);
        while(answer == 0){     // Отправляем запрос каждые 2 сек и ждем ответа модема
// Get IMEI function
 void IMEI_get () {
  c = Serial2.read();
 IMEI ="";
   IMEI_get ();
Guess what that code doesn't do.
Guess also what the code not in loop() doesn't do.
I can almost guarantee that every time you call Serial2.available, it will return zero.
previous error (function call) was corrected... thank you
char char_buffer;
int8_t answer;
String IMEI;
 int i =1;
 char c;
delay(2000);
   modem_power_on();
   IMEI_get ();
   modem_power_off();
   byte reply = 1;
   char character;
   delay(100);
       delay(10);
       reply = 0;
       reply = 2;
     }else{
       //Nothing to do...
   return reply;
// Modem ON fuction
    uint8_t answer=0;
    if (answer == 1)
        delay(3000);
    uint8_t answer=0;
    if (answer == 0)
        delay(3000);
 void IMEI_get () {
  c = Serial2.read();
 IMEI ="";
TolpuddleSartre:
it seems that this is so... every time I got "IMEI = "
So, what I wrote was true.
"Yay!" me.
Robin2 has a good serial input basics tutorial.
It works for Serial2 as well as for Serial.
#Example5 is more like my task, but I don't understand how to apply it in setup section (not in loop).
loop() repeats forever, not just 64 times.
yes, but in my case I need only once send AT+GSN and only once parse response.
So, loop enough times to fill your IMEI.
Suppose that, in your for loop, you only incremented i when you actually read a character. How many times would the loop iterate, then?
How do you KNOW that you will get exactly 64 characters back?
I can't figure out what that code should look like. Could you be so kind to help me?
You apparently need to read 64 characters.
A for loop will run as quickly as possible, through all non-blocking iterations.
So, a for loop is not what you want.
You need to loop until you have received 64 characters.
I wrote a clue there.
Perhaps a bit too subtle...
   byte i=0;
   while(i < 64)
      if(Serial2.available() > 0) // available() does not return true or false
         someArray[i++] = Serial2.read();
