Read and write rfid tags mfrc522
hello, can someone help me out in getting the "readbackblock[j]" array output to integer
this code is used reading and writing to rfid tag
once, i get the output in integer, i need to increment and decrement the block value
the functions are in the code below the main code
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN);
MFRC522::MIFARE_Key key;
int block = 10;
byte blockcontent[16] = {"5000"};
byte readbackblock[18];
  SPI.begin();
  mfrc522.PCD_Init();
  Serial.println("Scan a MIFARE Classic card");
  for (byte i = 0; i < 6; i++) {
    key.keyByte[i] = 0xFF;//keyByte is defined in the "MIFARE_Key" 'struct' definition in the .h file of the library
  if ( ! mfrc522.PICC_IsNewCardPresent()) {
    return;
  if ( ! mfrc522.PICC_ReadCardSerial()) {
    return;
  Serial.println("card selected");
  Serial.println("Read before write");
  readBlock(block, readbackblock);
  Serial.print("read block: ");
  for (int j = 0 ; j < 16 ; j++)
    Serial.write (readbackblock[j]);
  Serial.println("");
  Serial.println("Write after Read");
  writeBlock(block, blockcontent);
  Serial.println("Read after Write");
    Serial.write (readbackblock[j]);//Serial.write() transmits the ASCII numbers as human readable characters to serial monitor
  Serial.println("");
  mfrc522.PICC_HaltA();
  mfrc522.PCD_StopCrypto1();
int writeBlock(int blockNumber, byte arrayAddress[])
  //this makes sure that we only write into data blocks. Every 4th block is a trailer block for the access/security info.
  int largestModulo4Number=blockNumber/4*4;
  int trailerBlock=largestModulo4Number+3;//determine trailer block for the sector
  if (blockNumber > 2 && (blockNumber+1)%4 == 0){Serial.print(blockNumber);Serial.println(" is a trailer block:");return 2;}//block number is a trailer block (modulo 4); quit and send error code 2
//  Serial.print(blockNumber);
//  Serial.println(" is a data block:");
  /*****************************************authentication of the desired block for access***********************************************************/
  byte status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, trailerBlock, &key, &(mfrc522.uid));
  //byte PCD_Authenticate(byte command, byte blockAddr, MIFARE_Key *key, Uid *uid);
  //this method is used to authenticate a certain block for writing or reading
  //command: See enumerations above -> PICC_CMD_MF_AUTH_KEY_A	= 0x60 (=1100000),		// this command performs authentication with Key A
  //blockAddr is the number of the block from 0 to 15.
  //MIFARE_Key *key is a pointer to the MIFARE_Key struct defined above, this struct needs to be defined for each block. New cards have all A/B= FF FF FF FF FF FF
  //Uid *uid is a pointer to the UID struct that contains the user ID of the card.
  if (status != MFRC522::STATUS_OK) {
         Serial.print("PCD_Authenticate() failed: ");
         Serial.println(mfrc522.GetStatusCodeName(status));
         return 3;//return "3" as error message
  //it appears the authentication needs to be made before every block read/write within a specific sector.
  //If a different sector is being authenticated access to the previous one is lost.
  /*****************************************writing the block***********************************************************/
  status = mfrc522.MIFARE_Write(blockNumber, arrayAddress, 16);//valueBlockA is the block number, MIFARE_Write(block number (0-15), byte array containing 16 values, number of bytes in block (=16))
  //status = mfrc522.MIFARE_Write(9, value1Block, 16);
           Serial.print("MIFARE_Write() failed: ");
           return 4;//return "4" as error message
  Serial.println("block was written");
int readBlock(int blockNumber, byte arrayAddress[])
         Serial.print("PCD_Authenticate() failed (read): ");
  /*****************************************reading a block***********************************************************/
  byte buffersize = 18;//we need to define a variable with the read buffer size, since the MIFARE_Read method below needs a pointer to the variable that contains the size...
  status = mfrc522.MIFARE_Read(blockNumber, arrayAddress, &buffersize);//&buffersize is a pointer to the buffersize variable; MIFARE_Read requires a pointer instead of just a number
          Serial.print("MIFARE_read() failed: ");
  Serial.println("block was read");
atoi() will convert your string "5000" to its integer value.
atoi will not work on 16 digit numbers :wink: One needs strtoull which does not exist in arduino land so you have to write it yourself.
@embedtronics_raj, google for Arduino strtoull, there is a stackoverflow post.
It would presumably be more sensible to divide up the number in question.
It is not as if you are going to perform mathematics on it, it is purely arbitrary data.
You may think that in order to increment/ decrement it you need to use the whole number but you only need to increment/ decrement one part of it.
