I'm working on a code that outputs PWM values in the range 0 to 255 based on the values of a depth sensor.
The 'setpoint' in the code is the depth at which i want the pwm output to be exactly zero.
The float pwm is the pwm output, i've made a formula to map the depth values to the pwm values.
The problem is that when I plug in a value for the setpoint manually, i.e., in the program, like 0.3 or 0.4 whatever, the motor runs fine. It stops at the setpoint value and increases/decreases speed according to the depth.
But when I include the char setpoint = Serial.read(); and replace the setpoint values with the variable setpoint which i'm reading from the serial monitor, the motor is not functioning according to the code at all.
I think the problem is with the setpoint = Serial.read() line. Does arduino not read the exact number i input in the serial monitor?
Like if i enter 0.3, will it read something else or 0.3 only?
#include <Wire.h>
#include "MS5837.h"
MS5837 sensor;
#define motor_pin1 5
#define motor_pin2 6
Wire.begin();
//MOTOR
pinMode (motor_pin1, OUTPUT);
pinMode (motor_pin2, OUTPUT);
analogWrite (motor_pin1, LOW);
analogWrite (motor_pin2, LOW);
// Initialize pressure sensor
// Returns true if initialization was successful
while (!sensor.init()) {
Serial.println("Init failed!");
Serial.println("Are SDA/SCL connected correctly?");
Serial.println("Blue Robotics Bar30: White=SDA, Green=SCL");
Serial.println("\n\n\n");
sensor.setModel(MS5837::MS5837_30BA);
sensor.setFluidDensity(997); // kg/m^3 (freshwater, 1029 for seawater)
sensor.read();
float depth = sensor.depth();
Serial.print(depth);
Serial.println(" m");
// if (Serial.available() > 0) {
float setpoint = Serial.read();
if (depth > setpoint) {
//mapping of below setpoint
float pwm = 255 + (-255)*((depth-0.5)/(setpoint-0.5));
analogWrite (motor_pin2, pwm);
analogWrite (motor_pin1, 0);
Serial.print("right ");
Serial.println(pwm);
else {
//mapping of above setpoint
int pwm = (255)*((depth-setpoint)/(-setpoint));
analogWrite (motor_pin2, 0);
analogWrite (motor_pin1, pwm);
Serial.print("left ");
