The project consits of many files, but this is the main page.
The arduino loop function use the function: processFrame();
// Created by indrek on 1.05.2016.
// set EXAMPLE to EXAMPLE_UART in setup.h to activate
#include "setup.h"
#if EXAMPLE == 3
#include "Arduino.h"
#include "CameraOV7670.h"
// select resolution and communication speed:
// 1 - 115200bps 160x120 rgb
// 2 - 115200bps 160x120 grayscale
// 3 - 500000bps 160x120 rgb
// 4 - 500000bps 160x120 grayscale
// 5 - 500000bps 320x240 rgb
// 6 - 500000bps 320x240 grayscale
// 7 - 1Mbps 160x120 rgb
// 8 - 1Mbps 160x120 grayscale
// 9 - 1Mbps 320x240 rgb
// 10 - 1Mbps 320x240 grayscale
// 11 - 1Mbps 640x480 grayscale
// 12 - 2Mbps 160x120 rgb
// 13 - 2Mbps 160x120 grayscale
// 14 - 2Mbps 320x240 rgb
// 15 - 2Mbps 320x240 grayscale
// 16 - 2Mbps 640x480 rgb
// 17 - 2Mbps 640x480 grayscale
#define UART_MODE 5
const uint8_t VERSION = 0x10;
const uint8_t COMMAND_NEW_FRAME = 0x01 | VERSION;
const uint8_t COMMAND_DEBUG_DATA = 0x03 | VERSION;
const uint16_t UART_PIXEL_FORMAT_RGB565 = 0x01;
const uint16_t UART_PIXEL_FORMAT_GRAYSCALE = 0x02;
// Pixel byte parity check:
// Pixel Byte H: odd number of bits under H_BYTE_PARITY_CHECK and H_BYTE_PARITY_INVERT
// Pixel Byte L: even number of bits under L_BYTE_PARITY_CHECK and L_BYTE_PARITY_INVERT
// H:RRRRRGGG
const uint8_t H_BYTE_PARITY_CHECK = 0b00100000;
const uint8_t H_BYTE_PARITY_INVERT = 0b00001000;
// L:GGGBBBBB
const uint8_t L_BYTE_PARITY_CHECK = 0b00001000;
const uint8_t L_BYTE_PARITY_INVERT = 0b00100000;
// Since the parity for L byte can be zero we must ensure that the total byet value is above zero.
// Increasing the lowest bit of blue color is OK for that.
const uint8_t L_BYTE_PREVENT_ZERO = 0b00000001;
const uint16_t COLOR_GREEN = 0x07E0;
const uint16_t COLOR_RED = 0xF800;
void processGrayscaleFrameBuffered();
void processGrayscaleFrameDirect();
void processRgbFrameBuffered();
void processRgbFrameDirect();
typedef void (*ProcessFrameData)(void) ;
#if UART_MODE==1
const uint16_t lineLength = 160;
const uint16_t lineCount = 120;
const uint32_t baud = 115200;
const ProcessFrameData processFrameData = processRgbFrameBuffered;
const uint16_t lineBufferLength = lineLength * 2;
const bool isSendWhileBuffering = true;
const uint8_t uartPixelFormat = UART_PIXEL_FORMAT_RGB565;
CameraOV7670 camera(CameraOV7670::RESOLUTION_QQVGA_160x120, CameraOV7670::PIXEL_RGB565, 34);
#endif
#if UART_MODE==2
const ProcessFrameData processFrameData = processGrayscaleFrameBuffered;
const uint16_t lineBufferLength = lineLength;
const uint8_t uartPixelFormat = UART_PIXEL_FORMAT_GRAYSCALE;
CameraOV7670 camera(CameraOV7670::RESOLUTION_QQVGA_160x120, CameraOV7670::PIXEL_YUV422, 17);
#endif
#if UART_MODE==3
const uint32_t baud = 500000;
CameraOV7670 camera(CameraOV7670::RESOLUTION_QQVGA_160x120, CameraOV7670::PIXEL_RGB565, 8);
#endif
#if UART_MODE==4
CameraOV7670 camera(CameraOV7670::RESOLUTION_QQVGA_160x120, CameraOV7670::PIXEL_YUV422, 4);
#endif
#if UART_MODE==5
const uint16_t lineLength = 320;
const uint16_t lineCount = 240;
CameraOV7670 camera(CameraOV7670::RESOLUTION_QVGA_320x240, CameraOV7670::PIXEL_RGB565, 32);
#endif
#if UART_MODE==6
CameraOV7670 camera(CameraOV7670::RESOLUTION_QVGA_320x240, CameraOV7670::PIXEL_YUV422, 16);
#endif
#if UART_MODE==7
const uint32_t baud = 1000000;
const bool isSendWhileBuffering = false;
CameraOV7670 camera(CameraOV7670::RESOLUTION_QQVGA_160x120, CameraOV7670::PIXEL_RGB565, 5);
#endif
#if UART_MODE==8
CameraOV7670 camera(CameraOV7670::RESOLUTION_QQVGA_160x120, CameraOV7670::PIXEL_YUV422, 2);
#endif
#if UART_MODE==9
CameraOV7670 camera(CameraOV7670::RESOLUTION_QVGA_320x240, CameraOV7670::PIXEL_RGB565, 16);
#endif
#if UART_MODE==10
CameraOV7670 camera(CameraOV7670::RESOLUTION_QVGA_320x240, CameraOV7670::PIXEL_YUV422, 8);
#endif
#if UART_MODE==11
const uint16_t lineLength = 640;
const uint16_t lineCount = 480;
const ProcessFrameData processFrameData = processGrayscaleFrameDirect;
const uint16_t lineBufferLength = 1;
CameraOV7670 camera(CameraOV7670::RESOLUTION_VGA_640x480, CameraOV7670::PIXEL_YUV422, 39);
#endif
#if UART_MODE==12
const uint32_t baud = 2000000;
CameraOV7670 camera(CameraOV7670::RESOLUTION_QQVGA_160x120, CameraOV7670::PIXEL_RGB565, 2);
#endif
#if UART_MODE==13
#endif
#if UART_MODE==14
const uint32_t baud = 2000000; // may be unreliable
CameraOV7670 camera(CameraOV7670::RESOLUTION_QVGA_320x240, CameraOV7670::PIXEL_RGB565, 12);
#endif
#if UART_MODE==15
CameraOV7670 camera(CameraOV7670::RESOLUTION_QVGA_320x240, CameraOV7670::PIXEL_YUV422, 6);
#endif
#if UART_MODE==16
const ProcessFrameData processFrameData = processRgbFrameDirect;
CameraOV7670 camera(CameraOV7670::RESOLUTION_VGA_640x480, CameraOV7670::PIXEL_RGB565, 39);
#endif
#if UART_MODE==17
CameraOV7670 camera(CameraOV7670::RESOLUTION_VGA_640x480, CameraOV7670::PIXEL_YUV422, 19);
#endif
uint8_t lineBuffer [lineBufferLength]; // Two bytes per pixel
uint8_t * lineBufferSendByte;
bool isLineBufferSendHighByte;
bool isLineBufferByteFormatted;
uint16_t frameCounter = 0;
uint16_t processedByteCountDuringCameraRead = 0;
void commandStartNewFrame(uint8_t pixelFormat);
void commandDebugPrint(const String debugText);
uint8_t sendNextCommandByte(uint8_t checksum, uint8_t commandByte);
void sendBlankFrame(uint16_t color);
inline void processNextGrayscalePixelByteInBuffer() __attribute__((always_inline));
inline void processNextRgbPixelByteInBuffer() __attribute__((always_inline));
inline void tryToSendNextRgbPixelByteInBuffer() __attribute__((always_inline));
inline void formatNextRgbPixelByteInBuffer() __attribute__((always_inline));
inline uint8_t formatRgbPixelByteH(uint8_t byte) __attribute__((always_inline));
inline uint8_t formatRgbPixelByteL(uint8_t byte) __attribute__((always_inline));
inline uint8_t formatPixelByteGrayscaleFirst(uint8_t byte) __attribute__((always_inline));
inline uint8_t formatPixelByteGrayscaleSecond(uint8_t byte) __attribute__((always_inline));
inline void waitForPreviousUartByteToBeSent() __attribute__((always_inline));
inline bool isUartReady() __attribute__((always_inline));
// this is called in Arduino setup() function
void initializeScreenAndCamera() {
// Enable this for WAVGAT CPUs
// For UART communiation we want to set WAVGAT Nano to 16Mhz to match Atmel based Arduino
//CLKPR = 0x80; // enter clock rate change mode
//CLKPR = 1; // set prescaler to 1. WAVGAT MCU has it 3 by default.
Serial.begin(baud);
if (camera.init()) {
sendBlankFrame(COLOR_GREEN);
sendBlankFrame(COLOR_RED);
delay(3000);
void sendBlankFrame(uint16_t color) {
uint8_t colorH = (color >> 8) & 0xFF;
uint8_t colorL = color & 0xFF;
commandStartNewFrame(UART_PIXEL_FORMAT_RGB565);
for (uint16_t j=0; j<lineCount; j++) {
for (uint16_t i=0; i<lineLength; i++) {
waitForPreviousUartByteToBeSent();
UDR0 = formatRgbPixelByteH(colorH);
UDR0 = formatRgbPixelByteL(colorL);
// this is called in Arduino loop() function
void processFrame() {
commandStartNewFrame(uartPixelFormat);
noInterrupts();
processFrameData();
interrupts();
frameCounter++;
commandDebugPrint("Frame " + String(frameCounter)/* + " " + String(processedByteCountDuringCameraRead)*/);
//commandDebugPrint("Frame " + String(frameCounter, 16)); // send number in hexadecimal
void processGrayscaleFrameBuffered() {
camera.waitForVsync();
commandDebugPrint("Vsync");
camera.ignoreVerticalPadding();
for (uint16_t y = 0; y < lineCount; y++) {
lineBufferSendByte = &lineBuffer[0];
camera.ignoreHorizontalPaddingLeft();
uint16_t x = 0;
while ( x < lineBufferLength) {
camera.waitForPixelClockRisingEdge(); // YUV422 grayscale byte
camera.readPixelByte(lineBuffer[x]);
lineBuffer[x] = formatPixelByteGrayscaleFirst(lineBuffer[x]);
camera.waitForPixelClockRisingEdge(); // YUV422 color byte. Ignore.
if (isSendWhileBuffering) {
processNextGrayscalePixelByteInBuffer();
x++;
lineBuffer[x] = formatPixelByteGrayscaleSecond(lineBuffer[x]);
x++;
camera.ignoreHorizontalPaddingRight();
// Debug info to get some feedback how mutch data was processed during line read.
processedByteCountDuringCameraRead = lineBufferSendByte - (&lineBuffer[0]);
// Send rest of the line
while (lineBufferSendByte < &lineBuffer[lineLength]) {
void processNextGrayscalePixelByteInBuffer() {
if (isUartReady()) {
UDR0 = *lineBufferSendByte;
lineBufferSendByte++;
void processGrayscaleFrameDirect() {
uint16_t x = 0;
while ( x < lineLength) {
camera.readPixelByte(lineBuffer[0]);
lineBuffer[0] = formatPixelByteGrayscaleFirst(lineBuffer[0]);
UDR0 = lineBuffer[0];
x++;
lineBuffer[0] = formatPixelByteGrayscaleSecond(lineBuffer[0]);
x++;
uint8_t formatPixelByteGrayscaleFirst(uint8_t pixelByte) {
// For the First byte in the parity chek byte pair the last bit is always 0.
pixelByte &= 0b11111110;
if (pixelByte == 0) {
// Make pixel color always slightly above 0 since zero is a command marker.
pixelByte |= 0b00000010;
return pixelByte;
uint8_t formatPixelByteGrayscaleSecond(uint8_t pixelByte) {
// For the second byte in the parity chek byte pair the last bit is always 1.
return pixelByte | 0b00000001;
void processRgbFrameBuffered() {
isLineBufferSendHighByte = true; // Line starts with High byte
isLineBufferByteFormatted = false;
for (uint16_t x = 0; x < lineBufferLength; x++) {
processNextRgbPixelByteInBuffer();
// send rest of the line
while (lineBufferSendByte < &lineBuffer[lineLength * 2]) {
void processNextRgbPixelByteInBuffer() {
// Format pixel bytes and send out in different cycles.
// There is not enough time to do both on faster frame rates.
if (isLineBufferByteFormatted) {
tryToSendNextRgbPixelByteInBuffer();
formatNextRgbPixelByteInBuffer();
void tryToSendNextRgbPixelByteInBuffer() {
void formatNextRgbPixelByteInBuffer() {
if (isLineBufferSendHighByte) {
*lineBufferSendByte = formatRgbPixelByteH(*lineBufferSendByte);
*lineBufferSendByte = formatRgbPixelByteL(*lineBufferSendByte);
isLineBufferByteFormatted = true;
isLineBufferSendHighByte = !isLineBufferSendHighByte;
void processRgbFrameDirect() {
for (uint16_t x = 0; x < lineLength; x++) {
lineBuffer[0] = formatRgbPixelByteH(lineBuffer[0]);
lineBuffer[0] = formatRgbPixelByteL(lineBuffer[0]);
// RRRRRGGG
uint8_t formatRgbPixelByteH(uint8_t pixelByteH) {
// Make sure that
// A: pixel color always slightly above 0 since zero is end of line marker
// B: odd number of bits for H byte under H_BYTE_PARITY_CHECK and H_BYTE_PARITY_INVERT to enable error correction
if (pixelByteH & H_BYTE_PARITY_CHECK) {
return pixelByteH & (~H_BYTE_PARITY_INVERT);
return pixelByteH | H_BYTE_PARITY_INVERT;
// GGGBBBBB
uint8_t formatRgbPixelByteL(uint8_t pixelByteL) {
// Make sure that
// B: even number of bits for L byte under L_BYTE_PARITY_CHECK and L_BYTE_PARITY_INVERT to enable error correction
if (pixelByteL & L_BYTE_PARITY_CHECK) {
return pixelByteL | L_BYTE_PARITY_INVERT | L_BYTE_PREVENT_ZERO;
return (pixelByteL & (~L_BYTE_PARITY_INVERT)) | L_BYTE_PREVENT_ZERO;
void commandStartNewFrame(uint8_t pixelFormat) {
UDR0 = 0x00; // New command
UDR0 = 4; // Command length
uint8_t checksum = 0;
checksum = sendNextCommandByte(checksum, COMMAND_NEW_FRAME);
checksum = sendNextCommandByte(checksum, lineLength & 0xFF); // lower 8 bits of image width
checksum = sendNextCommandByte(checksum, lineCount & 0xFF); // lower 8 bits of image height
((lineLength >> 8) & 0x03) // higher 2 bits of image width
| ((lineCount >> 6) & 0x0C) // higher 2 bits of image height
| ((pixelFormat << 4) & 0xF0));
UDR0 = checksum;
void commandDebugPrint(const String debugText) {
if (debugText.length() > 0) {
UDR0 = 0x00; // New commnad
UDR0 = debugText.length() + 1; // Command length. +1 for command code.
checksum = sendNextCommandByte(checksum, COMMAND_DEBUG_DATA);
for (uint16_t i=0; i<debugText.length(); i++) {
checksum = sendNextCommandByte(checksum, debugText[i]);
UDR0 = checksum;
uint8_t sendNextCommandByte(uint8_t checksum, uint8_t commandByte) {
UDR0 = commandByte;
return checksum ^ commandByte;
void waitForPreviousUartByteToBeSent() {
while(!isUartReady()); //wait for byte to transmit
bool isUartReady() {
return UCSR0A & (1<<UDRE0);
#endif
