Read the PC language status with arduino and display it with LED or LCD screen
Hi all
I'm new to arduino and i would like to build a kit which will display the current chosen language in my PC.
so basically every time i will press alt+shift to change the language, LED light ot a LCD display will tell me which language is active now.
any ideas?
thanks!
Yaron
Write a PC application that (possibly) runs in the background and interrogates the language settings. Send that data over the serial port to the Arduino and display it there.
Which OS?
thanks! windows 10
Can't speak for Windoze 10, but in Win 7 and earlier, you had the option to have this shown in the systray.
Hi
I would love getting help on reading the pc keyboard language (in a multi language os) with arduino.
Do I need also to write an app on the pc to send it to the arduino?
Thanks
Yaron
(deleted)
Oh beleive me I have searched google...
Anyone can contribute the pc code needed?
(deleted)
Is this the same question as Read the PC language status with arduino and display it with LED or LCD screen - Project Guidance - Arduino Forum?
Yaronc:
I would love getting help on reading the PC keyboard language (in a multi language os) with arduino.
Did you by any chance, read what I explained earlier?
Hi Paul
I read what u wrote. I know windows is displaying the language status in the system tray. I need this status to be sent over serial to the arduino.
I just don't know how to write this code...
Neither do I (or I suspect, anyone else here). You need to do a lot of research into the internals of Windoze keyboard language selection. That's the problem and why this is unfortunately the wrong place to ask. :astonished:
The Arduino bit - if any at all - is trivial.
thanks Paul, i guess u write. I should ask it a n windows programmers forum...
Yaronc:
First, the Arduino is a great way to learn "C". And you will need it for any code you will write for the PC. You will be communicating directly with the operating system.
Paul
It's a little tricky as the language settings are individual for the applications; clicking will only change the setting of the current foreground window. Some searching the web and I came up with the below console application written in C#. Two webpages are named in the code; those are the ones that I based the code on. Further obviously the MSDN C# pages on the web.
The below is compiled in Visual Studion 2017 community edition and test under Windows 7. It uses the Win32 API, hence the section with the imports in the beginning of the class.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Runtime.InteropServices;
using System.Timers;
namespace ArduinoLanguageDetector
    class Program
        // https://www.codeproject.com/Articles/824887/How-To-List-The-Name-of-Current-Active-Window-in-C
        [DllImport("user32.dll")]
        static extern IntPtr GetForegroundWindow();
        static extern int GetWindowText(IntPtr hWnd, StringBuilder text, int count);
        // https://yal.cc/csharp-get-current-keyboard-layout/
        static extern IntPtr GetKeyboardLayout(uint thread);
        static extern uint GetWindowThreadProcessId(IntPtr hwnd, IntPtr proccess);
        // global variables
        static Timer tmr = new Timer();
        static string oldInfo = "";
        static void Main(string[] args)
            // setup a timer
            tmr.Interval = 1000;
            tmr.Elapsed += detectLanguage;
            tmr.Start();
            // forever do nothing
            for (; ; );
        private static void detectLanguage(object sender, ElapsedEventArgs e)
            // size for application 'name'
            const int nChars = 256;
            // window handle
            IntPtr handle;
            // variables to store info
            StringBuilder Buff = new StringBuilder(nChars);
            string processId = "";
            string language = "";
            string application = "";
            // get the window handle for the current foreground window
            handle = GetForegroundWindow();
            // get the process ID of the current foreground window
            uint foregroundProcess = GetWindowThreadProcessId(handle, IntPtr.Zero);
            processId = foregroundProcess.ToString();
            try
                // determine language
                int keyboardLayout = GetKeyboardLayout(foregroundProcess).ToInt32() & 0xFFFF;
                System.Globalization.CultureInfo ci = new System.Globalization.CultureInfo(keyboardLayout);
                language = String.Format("{0} [{1}]", ci.Name, ci.DisplayName);
            catch(Exception ex)
                language = "???";
            // get the application name
            if (GetWindowText(handle, Buff, nChars) > 0)
                application = Buff.ToString();
                application = "unknown application";
            int lio = application.LastIndexOf(System.IO.Path.DirectorySeparatorChar);
            application = lio < 0 ? application : application.Substring(lio + 1);
            string info = String.Format("{0}\t{1}\t{2}",
                processId, language, application
            if (info != oldInfo)
                Console.WriteLine(info);
                oldInfo = info;
Example output
9396    en-ZA [English (South Africa)]  ArduinoLanguageDetector.exe
4688    en-ZA [English (South Africa)]  Debug
4688    en-GB [English (United Kingdom)]        Debug
8588    en-ZA [English (South Africa)]  FreeCell
0       en-ZA [English (South Africa)]  unknown application
Note:
Debug is the 'name' of a directory that is open in Windows Eplorer.
In the next step you can try to implement serial communication. Open the connection in Main() (before you start the timer) and send data in detectLanguage().
It should be possible to modify this to run as a Windows Service; not tried.
PS
It does not seem to detect the language settings of a console application; it might simply not be applicable, no idea.
Late PS
Code needs some additional hardening.
Thank for your effort sttereje !
I will learn your code and see what next
