Hi ,I am having sd card in ethernet shield of text file containing:
DE:AD:BE:EF:FE:ED
192.168.10.11
255.255.255.0
192.168.10.3
59.144.127.16
192.168.10.105
6666
MAC,IP,SM,GW,DNS,SERVER IP,PORT NUMBER
I can read till server ip …but having problem in reading port number because it is long in data type …how to write function read that port number?
this is my code:
#include "SdFat.h"
SdFat SD;
#include<SPI.h>
#include<Ethernet.h>
byte mymac[6];
byte myip[4];
byte mynm[4];
byte mygw[4];
byte mydns[4];
byte server[4];
EthernetClient client;
pinMode(10, OUTPUT);
digitalWrite(10, HIGH);
delay(2000);
if (!SD.begin(4)) {
Serial.println( F("SD fail") );
else Serial.println( F("SD ok") );
File fh = SD.open("nw_set2.txt", FILE_READ);
char netbuffer[32];
if (!fh)
{ Serial.println( F("SD open fail") );
return;
int chpos = 0;
int lineno = 0;
while (fh.available())
char ch = fh.read();
if (ch == '\n') {
chpos = 0;
switch (lineno) {
case 0:
if (getmac(netbuffer, mymac)); //Serial.println(F("mac ok"));
case 1:
if (getip(netbuffer, myip)); //Serial.println(F("ip ok"));
case 2:
if (getip(netbuffer, mynm)); //Serial.println(F("sm ok"));
case 3:
if (getip(netbuffer, mygw)); //Serial.println(F("gw ok"));
case 4:
if (getip(netbuffer, mydns)); //Serial.println(F("dns ok"));
case 5:
if (getip(netbuffer, server)); //Serial.println(F("server is ok"));
lineno++;
else if (ch == '\r') {
//do nothing
else if (chpos < 31) {
netbuffer[chpos] = ch;
chpos++;
netbuffer[chpos] = 0;
fh.close();
Serial.print( F("\r\nmac") );
printArrayTo( Serial, mymac, sizeof(mymac), ':' );
Serial.print( F("\r\nip") );
printArrayTo( Serial, myip, sizeof(myip), '.' );
Serial.print( F("\r\nNM") );
printArrayTo( Serial, mynm, sizeof(mynm), '.' );
Serial.print( F("\r\ngw") );
printArrayTo( Serial, mygw, sizeof(mygw), '.' );
Serial.print( F("\r\ndns") );
printArrayTo( Serial, mydns, sizeof(mydns), '.' );
Serial.print( F("\r\nserver") );
printArrayTo( Serial, server, sizeof(server), '.' );
//Serial.println( F("\r\nStrating ethernet") );
Ethernet.begin(mymac, myip, mydns, mygw, mynm);
//Serial.println(Ethernet.localIP());
Serial.println( F("connecting...") );
delay(5000);
if (client.connect(server, 6666)) {
Serial.println( F("connected") );
Serial.println( F("connection failed") );
void printArrayTo( Stream & out, byte *array, size_t size, char delim )
for (size_t i = 0; i < size; i++) {
// print one number
out.print( *array++ );
// print the delimiter, but not after the last byte
if (i < size - 1)
out.print( delim );
byte getmac(char* macbuf, byte* thismac) {
byte thislen = strlen(macbuf);
byte thisoctet = 1;
thismac[0] = strtol(&macbuf[0], NULL, 16);
for (int x = 0; x < thislen; x++) {
if (macbuf[x] == ':') {
thismac[thisoctet] = strtol(&macbuf[x + 1], NULL, 16);
thisoctet++;
if (thisoctet == 6)return (1);
else return (0);
byte getip(char* ipbuf, byte* thisip) {
byte thislen = strlen(ipbuf);
byte thisoctet = 1;
thisip[0] = atoi(&ipbuf[0]);
if (ipbuf[x] == '.') {
thisip[thisoctet] = atoi(&ipbuf[x + 1]);
thisoctet++;
if (thisoctet == 4)return (1);
else return (0);
