readBytesUntil() for String Data
Using LoRa communication, string_buf of LoRa client has the following data.
string_buf has data: 23.5, 88, 1002, 12500
But when I compile my sketch, I got an error message like “ 'class String' has no member named 'readBytesUntil' “.
I know that the readBytesUntil function cannot be used because the string_buf of my sketch is not a Stream Class.
I studied the Stream class in the Arduino reference (Stream - Arduino Reference), but I couldn't figure out how to make the string data as a Stream class.
How do I modify my sketch to use the ”readBytesUntil(',', myData[0],20)” function?
#include <RH_RF95.h>
#include <Stream.h>
#define RFM95_INT     18  // "A"  // MEGA 18, UNO 2
#define RFM95_CS      53  // "B" // MEGA 53, UNO 10
#define RFM95_RST     40  // "C"  // MEGA assigned 40(임의로 변경 가능), uno 9(Module의 reset pin과 연결)
#define RF95_FREQ 915.0
RH_RF95 rf95(RFM95_CS, RFM95_INT);
int LED = 9;
int i = 0;
char myData[4][20] = {0};
char string_buf[4][5] = {0};
  while (!Serial) {
    // while (!Serial) ; // Wait for serial port to be available
    delay(1);
  delay(100);
  Serial.println("RX Serial ok");
  if (!rf95.init())
    Serial.println("rf95_RX init failed");
    Serial.println("rf95_RX init OK");
  //   rf95_serial.begin(9600);
  //   Serial.println(rf95_serial.available());
  Serial.println("Receiving Data from Server");
  char buf[RH_RF95_MAX_MESSAGE_LEN];
  //uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];
  uint8_t len = sizeof(buf);
  String buf_String[RH_RF95_MAX_MESSAGE_LEN];
  if (rf95.waitAvailableTimeout(4000))
    // Should be a reply message for us now
    if (rf95.recv(buf, &len))// buf has "23.5,88,1002,12500"received from RF95_TX;
      RH_RF95::printBuffer("printBuffer_buf_Data,buf,len: ", buf, len);
      Serial.print("(char*)buf: ");
      Serial.println((char*)buf);
      String string_buf = (char*)buf;
      Serial.print("String string_buf=(char*)buf: ");
      Serial.println(string_buf);
      // string_buf has data : "23.5,88,1002,12500"
      string_buf.readBytesUntil(',', myData[0], 20);
        float X1 = atof(myData[0]);
        //Serial.println(X1,1);
        //int X2 = atoi(myData[1]);
        //Serial.println(X2);
        //int X3 = atoi(myData[2]);
        //Serial.println(X3);
        //int X4 = atoi(myData[3]);
        //Serial.println(X4);
        digitalWrite(LED, HIGH);
        Serial.print("RSSI: ");
        Serial.println(rf95.lastRssi(), DEC);
      delay(100);
      Serial.println("recv failed");
    Serial.println("No reply, is rf95_server running?");
  delay(400);
Look at readStringUntil()
@juspark, in future, please post your code inline instead of as an attachment. You will reach a bigger audience. I've done it for you this time.
#include<SoftwareSerial.h>
#include <Stream.h>
//SoftwareSerial rf95_serial(50,51);//(RX,TX)MISO(Master In Slave Out) pin50=RX, MOSI(Master Out Slave In) pin51=TX
//uint8_t myData[]="23.5,88,1002,12500,";
int LED = 9;
int i=0;
char myData[4][20]={0};
char string_buf[4][5]={0};
//String inString ="";
 while (!Serial) {
    delay(1);
  delay(100);
if (!rf95.init())
     // String string_buf has data String: "23.5,88,1002,12500"
     string_buf.readBytesUntil(',',myData[0],20);
     float X1= atof(myData[0]);
    delay(100);
  delay(400);
Thank You
It is easier to use the String functions than to make a String into a Stream and using the Stream functions.
   int commaIndex = string_buf.indexOf(',');
  if (commaIndex != -1)
    myData[0] = string_buf.substring(0, commaIndex);
To: johnwasser
Thank you very much.
Editing my sketch as you recommended, I have solved the problem I had been struggling with it for about 2 weeks.
A part of the modified code is like the capture picture below.
