So... I have 4 serial pairs on the MEGA, I figured I might as well use another one than 0&1 to leave it in case I need it on the computer.
If I'm correct (newbie here), because the MEGA has 4 serial pairs I don't need bit-banging or a soft serial library.
So I just need connecting the TX from the device to an RX on the MEGA and we're good right?
And from then on, I don't really know where to start!
If I take the basic serial example, i'd need something like :
Well except that I have to translate it to code of course...
int incomingByte = 0; // for incoming serial data
Serial.begin(2400);
if (Serial.available() > 0) { //should I really check if I'm only reading??
incomingByte = Serial.read();
// now I need to compare this to 252 and 253. If one byte is 252 and the following 253 then frame starts.
// I need to count the right number of bytes and read the byte I'm interested in.
// then send it a variable and done!!!
Does anyone have an example I could follow? Looked for it on the forum and elsewhere but couldn't find anything simple enough for me to understand...
Any of those examples can be used on the additional hardware serial ports on the mega2560 as below:
Serial.begin(2400); // use serial port 0
Serial1.begin(2400); // use serial port 1
Serial2.begin(2400); //use serial port 2
Serial3.begin(2400); //use serial port 3
So just edit all of the serial.xxx commands in the example sketches to use the serial port you wish.
This will check if the incoming byte is 252 and will "save" the next 50 bytes in one buffer:
const int frameLength=50;
char buff[frameLength];
if (incomingByte == 252) {
for (int i=0;i<frameLength-1; i++) {
buff[i] = Serial.read();
If you need to check the 253 too, you need to do:
while (Serial.available() <= 0);
if (Serial.read() == 253) {
for (int i=0;i<frameLength-2; i++) {
This is the easy and very dirty way. It can be done better.
The Arduino code in the demo here is designed to receive all the bytes between given start and end marker bytes. You can easily modify it to suit your own markers. It is also desined to allw bytes to be included in a message that are the same value as the end markers - if you don't need that you can simplify the code.
So I tried both methods (from Robin and Luisilva) to no avail... I guess I'm doing something wrong, I'm gonna post my code here in the next message.
But first, can someone guide me on why I can't seem to get a reading even in the Arduino serial monitor?
The setup is the following : I'm feeding the Fadec some infos by using the arduino as a signal & servo signal generator (so that I have something to read) and I'm then plugging the TX wire from the FADEC onto a RS232=>USB converter.
They do exchange some informations but for example, here is what I'm reading on the console :
(Sorry about the attached printscreen, can't seem to copy/paste in the monitor.)
I'm @2400bauds, as specified... I honestly don't know where to go frome here...
Also can you provide a sample of the sort of input data that the Arduino is expecting to get.
What is FADEC?
And I don't understand this
So the FADEC is an engine (gas turbine in this case) control unit. The one I'm trying to extract data from is a R/C unit.
So I'm just simulating a RPM signal with a 50% duty PWM signal and a servo signal in order to enable it to run.
So here is one of my code ( I just deleted the other one by mistake and will reconstruct it tonight) :
#include <Servo.h>
#include <SoftwareSerial.h>
SoftwareSerial fadec (8,9);
Servo myservo; // create servo object to control a servo
double incomingByte;
int temp=1100;
myservo.attach(2); // attaches the servo on pin 9 to the servo object
Serial.begin(2400);
Serial.println("Salut");
fadec.begin(2400);
myservo.write(50); // enables FADEC to be in running mode
delay(5); // waits for the servo to get there
analogWrite(3,127); //simulates RPM signal (~29KRPM)
while (fadec.available() <= 0);
if (fadec.read() == 253) {
if (fadec.available() > 0) { //should I really check if I'm only reading??
buff[i] = fadec.read();
Serial.println(buff[i]);
Serial.println("test");
if (millis()-temp>1000)
Serial.println(buff[40]);
Serial.println(millis());
temp=millis();
Why is incomingByte not defined as a byte. And double is a floating point type which won't be good at byte/integer comparisons
How does incomingByte get to be 252?
What is the role of 252 and 253? - if they are start and end markers for input data you might look at how that is handled in the Arduino code in this Thread.
I thought you are using a Mega with multiple hardware serial ports - why bother with Software Serial?
Of course I forgot the code (it's below).
I also changed buff from char to byte.
Oh and I did check the example you provided and also tried to make it work but with no results so far... I'll include the code when I get it a bit presentable.
And finally yes, I'm using a MEGA but I'm testing on an uno ...
#include <Servo.h>
byte incomingByte;
byte buff[frameLength];
long temp=1100;
Serial.begin(2400);
fadec.begin(2400);
incomingByte = fadec.read();
//Serial.println(buff[40]);
//Serial.println("test");
Serial.println(buff[39]);
Serial.println(buff[48]);
Serial.println(buff[49]);
temp=millis();
I'm not sure my code has much to offer if the 252 and 253 are both at the start.
I think your logic is a little bit off as it won't easily handle the situation where something other than 253 appears as the second byte. I don't think your WHILE is in the right place. I think it should come after the check for the 253.
I've been reading everything I can (understand...) about serial but I still don't get several things :
when serial.available returns more than one (which means bytes have already arrived), how do I know what I'm reading afterwards? I see a lot of codes looking like this :
if(serial.available>0)
for(i=0,i<x,i++)
{char*=serial.read()}* } Now how do I know which byte I'm reading? I'm not seeing any relation between the i that's incrementing the position on the array (and also why always char?) and the serial.read() So how do I know I'm reading this byte and not another one? Also, when I'm done reading, does the buffer automatically erase it's memory and starts where it left off? If not we're skipping data everytime we stop reading, am I right? Thanks for the help, Marc
Below is very simple code that converts the bytes being received into various formats that are printable for inspection.
//zoomkat serial echo test 7-31-2011
char c; // incoming serial data
Serial.begin(9600); // set serial port at desired value
Serial.println("serial echo test 0021"); // echo test
if (Serial.available() > 0) { // check for serial buffer input
c = Serial.read(); // read the incoming byte:
Serial.println(c); // print the input
//select an output format
Serial.println(c, DEC); // print as an ASCII-encoded decimal
Serial.println(c, HEX); // print as an ASCII-encoded hexadecimal
Serial.println(c, OCT); // print as an ASCII-encoded octal
Serial.println(c, BIN); // print as an ASCII-encoded binary
//Serial.println(); // print new line for better reading
Serial.read() always reads the bytes in the order they have been received so if the PC sends (in this order) A B C the first Serial.read() will give you the A, the second one the B etc.
In case you are wondering the input buffer is a byte array organized as what is referred to as a circular buffer so it appears to have no start or finish - just two references to the head and tail. Serial.read() reads from the tail and moves it on one place. When the tail is the same as the head it means the buffer is empty. Then some input will arrive and will be written at the head and the head will move on one place. If too much input arrives (so that the head catches up with the tail) data will probably be lost.
