I have absolutely no clue to this and the library is missing the provision.
How do I read a string from the serial port?
I know about Serial.read() but it only reads one character at a time and I do not know how to pack this into a string.
I saw some code earlier where someone did just that it kept testing & adding characters until and EOL (end of line) character was recieved. Have looked at so many posts trying to read all the new stuff coming in I don't think I could find it. Try searching for EOL, see what comes back.
There are a gazillion examples around (albeit mostly on the old forum I admit).
Try something like this
Serial.begin (9600);
char myString[100];
char *ms_ptr = myString;
// oops, this was wrong if (Serial.read() > 0) {
if (Serial.available() > 0) {
*ms_ptr = Serial.read();
ms_ptr++;
*ms_ptr = '\0';
This will never stop reading chars though. Normally you also have a test for a end of string character at which point you break out of the loop and do some work with the string.
EDIT: oops, Serial.read -> Serial.available
Rob
Graynomad:
There are a gazillion examples around (albeit mostly on the old forum I admit).Try something like this
char myString[100];
ms_ptr++;
*ms_ptr = '\0';
This will never stop reading chars though. Normally you also have a test for a end of string character at which point you break out of the loop and do some work with the string. ______ Rob
I tried this
char myString[100];
void readstring(){
ms_ptr++;
*ms_ptr = '\0';
} // null terminate the string
void setup(){
Serial.begin(300);
Serial.println("Serial initiated");
void loop(){
if(Serial.available()){readstring();}
Serial.println(myString);
And typed "Hello World!" and hit enter and got:
Serial initiated
e
l
o
l
Some simple code you can tinker with.
// zoomkat 8-6-10 serial I/O string test
// type a string in serial monitor. then send or enter
// for IDE 0019 and later
String readString;
Serial.println("serial test 0021"); // so I can keep track of what is loaded
while (Serial.available()) {
delay(10);
if (Serial.available() >0) {
char c = Serial.read();
readString += c;}
if (readString.length() >0) {
Serial.println(readString);
readString="";
I had a typo in my example, but also you are not accumulating a string, just getting a character at a time
Rob
@zoomcat:
That works great!
Thank you.
I had a type in my example, try
Not quite sure what this means.
