Reading an RF key fob
I recently bought a car and it came with just one key, now ordering a key for this vehicle is going to cost lot of money, approximately 900. I want to create a duplicate key with my with available shells at ebay and want to use the same rfid. I do not want to break the security in my car which is risky. And I do not want to use any deavitivation method or any unit that requires to place a key inside. So i got an idea of using my cell phone a key fob.
My plan is to keep the rfid at home and use a device to read the rfid using a nodemcu and when ever I want to access the car I will turn the key on, which will talk to my phone using the bluetooth connection and then access my server at my home, which then gets the rfid. I also have plans on storing a list of 30-40 ids in my phone, so thqt I can use them when I do not have internet connection.
Is there a way I can make my node mcu to read the rfid and transmit the same to car from my phone? Please suggest ideas.
Hari2m:
Normally (assuming they have a reasonable standard of security) those things should use a challenge/response type of communication. The only way to mimic that is to get the actual security key.
How is it that you plan to transmit the rfid by Bluetooth to your phone? I’m pretty sure that you will spend way more trying to set this up than you would just buying the key, if it was even possible. I admittedly don’t know much about how the coded keys actually function, but I’m pretty confident the auto manufacturers have built in enough security to prevent any sort of jury rigged system to go around it. Just buy the key or put up with having only one.
wvmarle:
What fo you mean by the challenge response system? Is it possible to read the hex on the key and mimic the same through software?
Challenge/response authentication
When these keyfobs were new, many cars could be stolen using simple replay attacks, but more modern cars are immune to that. So you really have to know how to respond - it's something like the car sends a code, the fob encrypts this with a pre-shared key and sends it back. Then the car knows whether the fob has the same encryption key, and if so opens the door.
Done properly it's nearly uncrackable.
is it possible to read a fob to know when it is around ?
wanting to do a motion sensor alarm system that will automatically sleep if a known fob is around
or at least alter the timer to allow for alarm to be deactivated in an untimely manner
ie) let you put the groceries somewhere before messing with alarm system
or will I be better off setting up the mobile phone to tell the alarm system when user is home via GPS?
Of course - just make sure that fob is within range of a reader.
