Reading chars and storing into an array (!)
Hi!
I'm playing with DTMF tones, using a MT8870 I decode tones to digital signals (binary code) and with some arduino code I parse it.
At this moment my loop function is:
	irqState = digitalRead(STD); //Get the first trigger tone
	if (irqState == 1) {
		char code = mapKey();
		Serial.println(code);
		delay(100);
The thing is: I receive each decoded tone by triggering the irqState, So if I send 123 (three tones) I get 123, that is very nice!!! But now I want to 'store' it into an array to compare it later (to do some remote control stuff).
How can I do this?
Sorry for my english :~
http://arduino.cc/en/Reference/Array
http://www.thebox.myzen.co.uk/Tutorial/Arrays.html
//Lets say you have an array:
char dtmf [20]
int i = 0;
setup()
//some code
loop()
// some code
          if (irqState == 1)
                dtmf[++i]= mapKey();
                delay(100);
// lets say an # starts iteration code thought dtmf[0] to dtmf[maximum] to process through the values
// don't forget to set i = 0 when you are ready to start capturing again.
} // END of loop
When i starts at 0, where are you storing the first value, Larry? Not in the 0 spot, where it belongs.
Larry,
your solution works like a boss in my project, thanks!!!
I would think you'd want to start by placing the first item at 'dtmf[0]' and not 'dtmf[1]'
Try ...
dtmf[i++]= mapKey();
Yep! I did that change to start in 0 position.
Thanks
