hi there, i am very very new to arduino and other programming languages, like for 1 week. i have a project for graduating, and i have to fix my problem in 3 days.
i have yamamoto 24V, 80 pulse DC motor. Its encoder is h9700. (https://i.stack.imgur.com/PqaKy.png) what should i do to know rpm of my motor with using arduino? i'd be so so happy if someone tell me how can i connect wires correctly. my proffesor told us, we can use arduino to read encoder directly, but i am not sure. i believe this community will save me.
#define interruptPin 2
volatile int Counts = 400; // count per revolution
volatile unsigned long timeX = 1;
volatile unsigned long LastTime;
volatile int PulseCtrX;
unsigned long MicroS_in_One_Minute = 60000000;
void TachometerInterruptSetup(){
static int Ctr;
unsigned long Time;
Ctr++;
if (Ctr >= Counts) { // decrease the number pulses used.
Time = micros();
timeX += (Time - LastTime); // this time is accumulative ovrer those "Counts" readings
LastTime = Time;
PulseCtrX ++; // will usually be 1 unless something else delays the sample
Ctr = 0;
// attach interrupt to encoder with 400 pulses per revolution
attachInterrupt(digitalPinToInterrupt(interruptPin), TachometerInterruptSetup, FALLING);
// Other code to handle tachometer input
if (PulseCtrX) {
static unsigned long SpamTimer;
if ((millis() - SpamTimer) >= (100)) {
SpamTimer = millis();
Serial.print(MicroS_in_One_Minute / timeX);
Serial.println("RPM");
PulseCtrX = 0;
use VCC and GND and attach pin2 to channel A forget channel b unless you need to measure distance.
change: volatile int Counts = 400; // count per revolution
to match how many pulses per revolution your encoder generates on channel A
