Reading Garbage from the EEPROM.
I am creating a pond controller with an arduino nano That communicates over bluetooth to a mit app inventor app. I have the app send the start and stop times for the 4 electrical ports and then the arduino saves them to eeprom so if the power goes out it saves the programed times. Every loop i call EEPROM.update and give it the new data points, but when I read them back they are completely different numbers.
#include <EEPROM.h>
#include <Wire.h>
#include "RTClib.h"
#define Output1 4
#define Output2 5
#define Output3 6
#define Output4 7
#define R 10
#define G 11
#define B 9
#define DeBug 8
int Update;
int P1State = 2;
int P2State = 2;
int P3State = 2;
int P4State = 2;
int P1;
int P2;
int P3;
int P4;
int RR;
int GG;
int BB;
int Start1;
int End1;
int Start2;
int End2;
int Start3;
int End3;
int Start4;
int End4;
const byte numChars = 32;
char receivedChars[numChars];
char tempChars[numChars];
boolean newData = false;
RTC_DS1307 RTC;
  Wire.begin();
  RTC.begin();
  pinMode (DeBug, INPUT);
  pinMode (Output1, OUTPUT); //Sets Port 1-4 As Outputs
  pinMode (Output2, OUTPUT);
  pinMode (Output3, OUTPUT);
  pinMode (Output4, OUTPUT);
  pinMode (R, OUTPUT); //Sets RGB Pins As Outputs
  pinMode (G, OUTPUT);
  pinMode (B, OUTPUT);
  pinMode (13, OUTPUT);
  digitalWrite(Output1,HIGH);
  digitalWrite(Output2,HIGH);
  digitalWrite(Output3,HIGH);
  digitalWrite(Output4,HIGH);
  if (! RTC.isrunning()) {
    Serial.println("RTC is NOT running!");
    // following line sets the RTC to the date & time this sketch was compiled
RTC.adjust(DateTime(__DATE__, "10:59:30"));
  EEPROM.get(1, Start1);
  EEPROM.get(2, End1);
  EEPROM.get(3, Start2);
  EEPROM.get(4, End2);
  EEPROM.get(5, Start3);
  EEPROM.get(6, End3);
  EEPROM.get(7, Start4);
  EEPROM.get(8, End4);
  Serial.println("Start Up Done");
  DateTime now = RTC.now();
  recvWithStartEndMarkers();
  if (newData == true) {
    strcpy(tempChars, receivedChars);
    // this temporary copy is necessary to protect the original data
    //   because strtok() used in parseData() replaces the commas with \0
    parseData();
    showParsedData();
    newData = false;
  Serial.print("Hour-");
  Serial.print(now.hour());
  Serial.print(" Minute-");
  Serial.print(now.minute());
  Serial.print(" Second-");
  Serial.println(now.second());
Serial.print("Start1-");
Serial.println(Start1);
Serial.print("Start1.1-");
Serial.println(EEPROM.get(1,P1State));
Serial.print("Start2-");
Serial.println(Start2);
Serial.print("Start2.1-");
Serial.println(EEPROM.get(3,P2State));
Serial.print("Start3-");
Serial.println(Start3);
Serial.print("Start3.1-");
Serial.println(EEPROM.get(5,P3State));
Serial.print("Start4-");
Serial.println(Start4);
Serial.print("Start4.1-");
Serial.println(EEPROM.get(7,P4State));
EEPROM.update(1, Start1);
EEPROM.update(2, End1);
EEPROM.update(3, Start2);
EEPROM.update(4, End2);
EEPROM.update(5, Start3);
EEPROM.update(6, End3);
EEPROM.update(7, Start4);
EEPROM.update(8, End4);
   if (now.hour() == Start1 && now.minute() < 1) {
    Serial.print("aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa");
   if (now.hour() == End1 && now.minute() < 1) {
        Serial.print("End1");
digitalWrite(Output1,LOW);
  if (now.hour() == Start2 && now.minute() < 1) {
   if (now.hour() == End2 && now.minute() < 1) {
digitalWrite(Output2,LOW);
  if (now.hour() == Start3 && now.minute() < 1) {
   if (now.hour() == End3 && now.minute() < 1) {
digitalWrite(Output3,LOW);
  if (now.hour() == Start4 && now.minute() < 1) {
   if (now.hour() == End4 && now.minute() < 1) {
digitalWrite(Output4,LOW);
  if (P1 == 1) {
    digitalWrite(Output1, LOW);
    P1State = 1;
  else {
    digitalWrite(Output1, HIGH);
    P1State = 2;
  if (P2 == 1) {
    digitalWrite(Output2, LOW);
    P2State = 1;
  else {
    digitalWrite(Output2, HIGH);
    P2State = 2;
  if (P3 == 1) {
    digitalWrite(Output3, LOW);
    P3State = 1;
  else {
    digitalWrite(Output3, HIGH);
    P3State = 2;
  if (P4 == 1) {
    digitalWrite(Output4, LOW);
    P4State = 1;
  else {
    digitalWrite(Output4, HIGH);
    P4State = 2;
  analogWrite(R, RR);
  analogWrite(G, GG);
  analogWrite(B, BB);
  if (digitalRead(DeBug) == HIGH) {
    Serial.print("This just in ... ");
    Serial.println(receivedChars);
  delay(100);
void recvWithStartEndMarkers() {
  static boolean recvInProgress = false;
  static byte ndx = 0;
  char startMarker = '<';
  char endMarker = '>';
  char rc;
  while (Serial.available() > 0 && newData == false) {
    rc = Serial.read();
    if (recvInProgress == true) {
      if (rc != endMarker) {
        receivedChars[ndx] = rc;
        ndx++;
        if (ndx >= numChars) {
          ndx = numChars - 1;
      else {
        receivedChars[ndx] = '\0'; // terminate the string
        ndx = 0;
        newData = true;
    else if (rc == startMarker) {
      recvInProgress = true;
void parseData() {      // split the data into its parts
  char * strtokIndx; // this is used by strtok() as an index
  strtokIndx = strtok(tempChars, ",");     // get the first part - the string
  P1 = atoi(strtokIndx); // copy it to messageFromPC
  strtokIndx = strtok(NULL, ","); // this continues where the previous call left off
  P2 = atoi(strtokIndx);     // convert this part to an integer
  P3 = atoi(strtokIndx);     // convert this part to an integer
  P4 = atoi(strtokIndx);     // convert this part to an integer
  RR = atoi(strtokIndx);     // convert this part to an integer
  GG = atoi(strtokIndx);     // convert this part to an integer
  BB = atoi(strtokIndx);     // convert this part to an integer
  Start1 = atoi(strtokIndx);     // convert this part to an integer
  End1 = atoi(strtokIndx);     // convert this part to an integer
  Start2 = atoi(strtokIndx);     // convert this part to an integer
  End2 = atoi(strtokIndx);     // convert this part to an integer
  Start3 = atoi(strtokIndx);     // convert this part to an integer
  End3 = atoi(strtokIndx);     // convert this part to an integer
  Start4 = atoi(strtokIndx);     // convert this part to an integer
  End4 = atoi(strtokIndx);     // convert this part to an integer
 Serial.print(P1State);
  Serial.print(",");
  Serial.print(P2State);
  Serial.print(",");
  Serial.print(P3State);
  Serial.print(",");
  Serial.print(P4State);
  Serial.print(",");
void showParsedData() {
  //Serial.print(BB);
I made a output on the serial monitor to show what it gets from the phone and what it reads from eeprom.
Start1-12
Start1.1-1292
Start2-6
Start2.1-3334
Start3-18
Start3.1-6162
Start4-0
Start4.1-0
Start1-12
Start1.1-1292
Start2-6
Start2.1-3334
Start3-18
Start3.1-6162
Start4-0
Start4.1-0
Start1 is from phone and start1.1 is from the eeprom.
(deleted)
StartX and EndX are integers (as pointed out by spycatcher2k). EEPROM.update() writes a single byte, not an int. Use EEPROM.put() to write an integer. And space it correctly :wink:
Thank you to both of you that was my problem.
