ESP-NOW transmit a structure
// ESP-NOW transmit a structure
Rui Santos
Complete project details at https://RandomNerdTutorials.com/esp-now-esp32-arduino-ide/
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files.
The above copyright notice and this permission notice shall be included in all
copies or substantial portions of the Software.
#include <esp_now.h>
#include <WiFi.h>
// REPLACE WITH YOUR RECEIVER MAC Address
uint8_t broadcastAddress[] = {0x24,0x62,0xAB,0xE0,0x64,0x54}; //{ 0x84, 0xCC, 0xA8, 0x7A, 0x56, 0x6C }; //{0x24,0x62,0xAB,0xE0,0x64,0x54};
esp_now_peer_info_t peerInfo;
// test structure
struct __attribute__((packed)) Data {
int16_t seq; // sequence number
int32_t distance;
float voltage;
char text[50];
} data = { 0, 56, 3.14159, "hello test" }; // sample data
// callback when data is sent
void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status) {
Serial.print("Last Packet Send Status:\t");
Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
// Init Serial Monitor
Serial.println("ESP-NOW transmitting a structure");
// Set device as a Wi-Fi Station
WiFi.mode(WIFI_STA);
Serial.print("ESP32 Board MAC Address: ");
Serial.println(WiFi.macAddress());
// Init ESP-NOW
if (esp_now_init() != ESP_OK) {
Serial.println("Error initializing ESP-NOW");
return;
// Once ESPNow is successfully Init, we will register for Send CB to
// get the status of Trasnmitted packet
esp_now_register_send_cb(OnDataSent);
// Register peer
memcpy(peerInfo.peer_addr, broadcastAddress, 6);
peerInfo.channel = 0;
peerInfo.encrypt = false;
// Add peer
if (esp_now_add_peer(&peerInfo) != ESP_OK) {
Serial.println("Failed to add peer");
return;
// Send data structure via ESP-NOW
Serial.printf("seq %d distaance %ld voltage %f text '%s'\n",
(int)data.seq, (long)data.distance, data.voltage, data.text);
esp_now_send(broadcastAddress, (uint8_t *)&data, sizeof(data));
data.seq++; // update data ready for next transmission
data.distance += 10;
data.voltage += 2.5;
data.text[9]++;
esp-now receive a structure
// ESP-NOW receive a structure
Rui Santos
#include <WiFi.h>
// test structure
int32_t distance;
float voltage;
char text[50];
} data;
// callback function that will be executed when data is received
void OnDataRecv(const uint8_t *mac, const uint8_t *incomingData, int len) {
static int16_t seqExpected = 0, errors=0;
Serial.printf("Bytes received: %d ", len);
if (len == sizeof(data)) {
memcpy((void *)&data, (void *)incomingData, len);
Serial.printf("seq %d distaance %ld voltage %f text '%s' errors %d\n",
(int)data.seq, (long)data.distance, data.voltage, data.text, errors);
if (data.seq != seqExpected) // check sequence number received
Serial.printf("Error! seq expected %d received %d errors %d\n", seqExpected, data.seq, ++errors);
seqExpected = data.seq; // set sequence number ready for next data
seqExpected++;
} else
Serial.printf("ERROR! packek size expected %d receive %d errors %d\n", sizeof(data), len, ++errors);
// Initialize Serial Monitor
Serial.println("ESP-NOW receive a structure");
// Init ESP-NOW
return;
// Once ESPNow is successfully Init, we will register for recv CB to
// get recv packer info
esp_now_register_recv_cb(OnDataRecv);
transmitter serial monitor output
ESP-NOW transmitter
ESP32 Board MAC Address: 08:3A:F2:B7:F8:F4
seq 0 distaance 56 voltage 3.141590 text 'hello test'
Last Packet Send Status: Delivery Fail
seq 1 distaance 66 voltage 5.641590 text 'hello tesu'
seq 2 distaance 76 voltage 8.141590 text 'hello tesv'
Last Packet Send Status: Delivery Success
seq 3 distaance 86 voltage 10.641590 text 'hello tesw'
seq 4 distaance 96 voltage 13.141590 text 'hello tesx'
seq 5 distaance 106 voltage 15.641590 text 'hello tesy'
receiver serial monitor output
ESP32 Board MAC Address: 84:CC:A8:7A:56:6C
Bytes received: 60 seq 2 distaance 76 voltage 8.141590 text 'hello tesv'
Error! seq expected 0 received 2
Bytes received: 60 seq 3 distaance 86 voltage 10.641590 text 'hello tesw'
Bytes received: 60 seq 4 distaance 96 voltage 13.141590 text 'hello tesx'
Bytes received: 60 seq 5 distaance 106 voltage 15.641590 text 'hello tesy'
Bytes received: 60 seq 6 distaance 116 voltage 18.141590 text 'hello tesz'
Bytes received: 60 seq 7 distaance 126 voltage 20.641590 text 'hello tes{'
the above worked OK at 5 to 6 metres thru a foil backed plasterboard wall
failed at 6/7 metres thru two foil backed pasterbaord walls, e.g.
Bytes received: 60 seq 8 distaance 136 voltage 23.141590 text 'hello tes|' errors 3
Bytes received: 60 seq 9 distaance 146 voltage 25.641590 text 'hello tes}' errors 3
Bytes received: 60 seq 10 distaance 156 voltage 28.141590 text 'hello tes~' errors 3
Bytes received: 60 seq 12 distaance 176 voltage 33.141590 text 'hello tes ' errors 3
Error! seq expected 11 received 12 errors 4
Bytes received: 60 seq 13 distaance 186 voltage 35.641590 text 'hello tes ' errors 4
Bytes received: 60 seq 14 distaance 196 voltage 38.141590 text 'hello tes ' errors 4
Bytes received: 60 seq 15 distaance 206 voltage 40.641590 text 'hello tes ' errors 4
Bytes received: 60 seq 16 distaance 216 voltage 43.141590 text 'hello tes ' errors 4
