Reading Pyranometer voltage
Hello,
I'm doing a meteorological station with some sensors.
One of them is a pyranometer, a sensor that measures the global solar radiation, and here's the problem.
The pyranometer sensor output has a maximum of 10mV, has a coaxial cable, the shield is positive and the center condutor is negative, and has a resistor across the leads of the cable.
Questions:
Is it right to connect one wire (positive) to analog (and other to ground) and measure the voltage in?
How can i measure values between 0mV and 10mV, if arduino has a 4.9mV "length unit"?
Is it necessary to amplify the signal?
Thanks
Yes, and probably to invert too.
Use OPA as amplifier, JFET input stage. LF351 should be o'k for your application. Search a data sheet, it includes schematic drawings and app. notes.
