Hi.
I'm working on a Euro Truck Simulator 2 real dashboard, and I want to use the code that Silas Parker already published and modify it to my special needs (for instance, adding fuel, oil, water... gauges, which the telemetry plugin provides.
The below is Silas' original code (only modified to work with I2C lcd), and the last part of the code provides info to a 16x2 LCD screen, specifically MPH, KPH, gear and fuel. I find it hard to reverse-engineer how to get specific values of the lcd (such as the fuel level) and other values that are not printed in the lcd, but I know the plugin provides. I've tried printing the serial data into the serial monitor, but as soon as you add a Serial.print command, it seems to break everything and then neither the serial monitor nor the lcd display anything (I'm assuming it's messing with the serial connection somehow).
This is how the LCD looks like when it's working:
Copyright (c) 2013, Silas Parker
All rights reserved.
Redistribution and use in source and binary forms, with or without modification,
are permitted provided that the following conditions are met:
Redistributions of source code must retain the above copyright notice, this
list of conditions and the following disclaimer.
Redistributions in binary form must reproduce the above copyright notice,
this list of conditions and the following disclaimer in the documentation
and/or other materials provided with the distribution.
The name of Silas Parker may not be used to endorse or promote products
derived from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <Servo.h>
const int SPEEDO_PIN = A1;
const int RPM_PIN = A0;
const int LEFT_INDICATOR = A2;
const int RIGHT_INDICATOR = A3;
const int PARKING_BREAK = A4;
const int FUEL_WARNING = A5;
// Servo variables
Servo speedo;
Servo rpm;
#define PACKET_SYNC 0xFF
#define PACKET_VER 2
#define SERVO_DIR_NORMAL false
#define SERVO_DIR_INVERT true
int serial_byte;
LiquidCrystal_I2C lcd(0x27,20,4);
lcd.init();
lcd.backlight();
lcd.print("Self Test");
// Initialise servos
speedo.attach(SPEEDO_PIN);
speedo.write(180);
rpm.attach(RPM_PIN);
rpm.write(180);
// Initialise LEDs
pinMode(LEFT_INDICATOR, OUTPUT);
pinMode(RIGHT_INDICATOR, OUTPUT);
pinMode(PARKING_BREAK, OUTPUT);
pinMode(FUEL_WARNING, OUTPUT);
digitalWrite(LEFT_INDICATOR, 0);
digitalWrite(RIGHT_INDICATOR, 0);
digitalWrite(PARKING_BREAK, 0);
digitalWrite(FUEL_WARNING, 0);
speedo.write(0);
rpm.write(0);
digitalWrite(LEFT_INDICATOR, 1);
digitalWrite(RIGHT_INDICATOR, 1);
digitalWrite(PARKING_BREAK, 1);
digitalWrite(FUEL_WARNING, 1);
speedo.write(180);
rpm.write(180);
lcd.clear();
lcd.print("Wait");
// Wait a second to ensure serial data isn't from re-programming
lcd.clear();
lcd.print("Ready");
void read_serial_byte_set_servo(Servo& servo, bool invert)
serial_byte = Serial.read();
serial_byte = (serial_byte < 0) ? 0 : ((serial_byte > 180) ? 180 : serial_byte);
if (invert)
servo.write(180 - serial_byte);
servo.write(serial_byte);
void skip_serial_byte()
(void)Serial.read();
void digitalWriteFromBit(int port, int value, int shift)
digitalWrite(port, (value >> shift) & 0x01);
if (Serial.available() < 16)
return;
if (serial_byte != PACKET_SYNC)
return;
if (serial_byte != PACKET_VER)
lcd.clear();
lcd.print("PROTOCOL VERSION ERROR");
return;
read_serial_byte_set_servo(speedo, SERVO_DIR_INVERT); // Speed
read_serial_byte_set_servo(rpm, SERVO_DIR_INVERT); // RPM
skip_serial_byte(); // Brake air pressure
skip_serial_byte(); // Brake temperature
skip_serial_byte(); // Fuel ratio
skip_serial_byte(); // Oil pressure
skip_serial_byte(); // Oil temperature
skip_serial_byte(); // Water temperature
skip_serial_byte(); // Battery voltage
// Truck lights byte
digitalWriteFromBit(LEFT_INDICATOR, serial_byte, 5);
digitalWriteFromBit(RIGHT_INDICATOR, serial_byte, 4);
// Warning lights bytes
digitalWriteFromBit(PARKING_BREAK, serial_byte, 7);
digitalWriteFromBit(FUEL_WARNING, serial_byte, 3);
// Enabled flags
// Text length
int text_len = Serial.read();
// Followed by text
if (0 < text_len && text_len < 127)
lcd.clear();
for (int i = 0; i < text_len; ++i)
while (Serial.available() == 0) // Wait for data if slow
delay(2);
if (serial_byte < 0 && serial_byte > 127)
return;
if (serial_byte == '\n')
lcd.setCursor(0, 1);
lcd.print(char(serial_byte));
// delay(2);
