Reading serial data
I've got some issues that might be an easy task to solve.
I want to read a serial data and check if there is a special character there or not.
If that special character is not present, it should send the data further on to another serial port.
The data I receive is in this format: ka 00 01
The code I'm just briefly testing with is this:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3); // RX, TX
Serial.begin(19200);
while (!Serial) {
; // wait for serial port to connect. Needed for Native USB only
// set the data rate for the SoftwareSerial port
mySerial.begin(19200);
void loop() //
if (mySerial.available())
Serial.write(mySerial.read());
if (Serial.available())
mySerial.write(Serial.read());
This only gives me back the first byte "ka" and not the rest.
I guess I need to store these bytes into a variable and send them out again.
Any inputs?
If those are bytes, the serial monitor doesn't display character 0 or character 1. They're likely being received, just not printed.
thanks.. I will try a different terminal and get back.
Maybe try:
  if (mySerial.available()) {
    char c = mySerial.read();
    Serial.write(c);
I think that will suffer from the same issue that the serial monitor won't render those characters. You could print them as ints though to confirm what was received:
    int c = mySerial.read();
    Serial.println(c);
Have a look at the examples in Serial Input Basics - simple reliable ways to receive data. There is also a parse example to illustrate how to extract numbers from the received text.
...R
Or Serial.println(c,HEX);
How is this:
1. Screen shot of receiver UNO
2. NANO TX Codes
SoftwareSerial mySerial(2, 3); // SRX, STX
  mySerial.begin(9600);
  mySerial.println("ka 00 01");
3. UNO RX Codes
  byte n = mySerial.available();
  if( n != 0)
    char x = mySerial.read();
    Serial.print(x);
