Reading Serial Port
Hello, I am connecting my Arduino to my Raspberry Pi via USB. I got one thing to work, where the LED on the Uno would blink the amount of times depending on what I typed into a program on Raspberry Pi.
The Arduino code was this:
const int ledPin = 13;
void setup(){
  pinMode(ledPin, OUTPUT);
void loop(){
  if (Serial.available())  {
     blink(Serial.read() - '0');
void blink(int numberOfTimes){
  for (int i = 0; i < numberOfTimes; i++)  {
    digitalWrite(ledPin, HIGH);
    delay(100);
    digitalWrite(ledPin, LOW);
    delay(100);
I would type the following into the Raspberry Pi program:
>>> import serial
>>> ser = serial.Serial('/dev/ttyACM0', 9600)
And then:
>>> ser.write('3')
And then the Arduino would blink three times.
So then, I thought about turning a certain LED on/off depending on what was said in the Pi program.
So I made this code:
int red = 3;
int green = 5;
int yellow = 6;
  pinMode(3, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  digitalWrite((Serial.read()), HIGH);
My idea was that the arduino would read the serial port, and if I typed 'red', then it would turn the red LED on, but I get no response...
What could I do to make this work?
There's a whole thread on serial basics.
Hint: most of the time, Serial.read will return -1.
You have no pin -1.
AWOL:
You have no pin -1.
hmm... So would I do something like:
digitalWrite((Serial.read() + 1), HIGH);
Thanks, and I will dig for that thread!
No, you wouldn't do that either, mostly because that would screw up the serial interface.
Okay, I think I found the thread. How does this look?
  if (Serial.available() > 0) {
Let's say you hit the '1' key.
You probably don't have a pin 49 either, unless you're on a Mega.
Ah...
  if (14 > Serial.available() > 0) {
Edit: Still no luck.
Now you're just making stuff up.
Slow down.
Read the whole of the serial basics post.
I mean all of it.
AWOL:
Slow down.
I mean all of it.
Okay, I tend to get a little ahead of myself sometimes(a lot). :blush:
Okay, so from the tutorial and this code:
char receivedChar;
boolean newData = false;
 Serial.println("<Arduino is ready>");
 pinMode(3, OUTPUT);
 pinMode(5, OUTPUT);
 pinMode(6, OUTPUT);
 recvOneChar();
 showNewData();
void recvOneChar() {
 receivedChar = Serial.read();
 newData = true;
void showNewData() {
 if (newData == true) {
 Serial.print("This just in ... ");
 Serial.println(receivedChar);
 newData = false;
When I typed "ser.write(' **insert character here ** ')", on the Raspberry end, the character appeared in the Serial Monitor on the Arduino end.
Then, I tried modifying it as so:
char receivedChar;
 recvOneChar();
 showNewData();
 newData = true;
 digitalWrite((receivedChar), HIGH);
 newData = false;
I still get a response from the Serial Monitor, but none from the LEDs.
You are still not grasping the difference between an ASCII char '1' = 49, '2' = 50 '3' = 51. and the actual numbers 1,2,3.
You can get back to the numbers with
 digitalWrite((receivedChar-48), HIGH);
or alternatively if it makes more sense to you
 digitalWrite((receivedChar - '0'), HIGH);
cattledog:
Aha! I just needed to put two and two together. Now it works like a charm. Thank you both for your assistance and guidance!
