Hello people,
I'm new here and have been playing around with Arduino for a few months now. I am using the freetronics etherTen based on the Uno board and Wiznet W1500 chip, Here's the link to the board.
I am connecting to a TCP server and exchanging messages in a Line Based ASCII protocol. The format of the messages is Qs436=0;0;0;0 with a CR and LF The messages can come in at any time. Maximum message length is 60 bytes but the average is about 12.
The first part of the message is a variable coming from the server, 436 in the example above but this could be Qh58, This is followed by a selection of fields separated by ';', in the case Qs436=0;0;0;0 I need to put these 4 values into an array and do some calculations on later to drive hardware connected to the Arduino.
To parse the incoming message lines, I should inspect the first character (Q). A Q always means that there will be a category (h, i, or s) and an equals sign (=) followed by a value. The value is always an integer when the category is h or i, and a string otherwise.
I need some advice on how to implement this. My code so far does not include the array, I am unsure
- how to get the stream to match my if statements
- then put the data into an array in the right data types
Thanks in advance
Here is my code
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,0,160 );
IPAddress subnet(255, 255, 255, 0);
IPAddress server(192, 168, 0, 10);
EthernetClient client;
const int led = 3; // the number of the LED pin
int t1psx;
int t2psx;
int t3psx;
int t4psx;
pinMode(led, OUTPUT);
Ethernet.begin(mac, ip);
do { client.connect(server, 10748);
while (!client.connected());
delay(100);
Serial.println("connecting...");
if (client.connected()) {
Serial.println("connected");
client.println("name=Audrino THQ");
else {
Serial.println("connection failed");
// the loop routine runs over and over again forever:
void loop(){
if (client){
while(client.connected()){
if (client.available()){
char c = client.read();
Serial.print(c);
if (c == 'Qh58'){
if (client.find ("=")){
int ATenabled = client.parseInt();
if (ATenabled == 1){
digitalWrite(led, HIGH);
Serial.println("AT = 1");
if (ATenabled == 0){
digitalWrite(led, LOW);
Serial.println("AT = 0");
if (c == 'Qs436'){
if (client.find("=")){
t1psx = client.parseInt();
Serial.print("Qs436=");
Serial.println(t1psx);
delay(10);
