Reading UDP packets
I'm playing with the UDP Send Receive String example found here; https://www.arduino.cc/en/Tutorial/UDPSendReceiveString
With the code provided I can (obviously) successfully send and receive chars.
I'm trying to go a step further now and perform different tasks (starting with simply printing a different line to serial monitor) depending on what data is received in the UDP packet.
My arduino code looked like this;
#include <Ethernet.h>
//DEFINITIONS-----------------------------------------
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED}; //mac adress
IPAddress ip(2, 0, 0, 100); //ip address
unsigned int localPort = 8888; //udp port to listen for packets on
char packetBuffer[UDP_TX_PACKET_MAX_SIZE];
EthernetUDP Udp; //creates Udp instance
char f1 = 10; //char to compare packetBuffer to
char f2 = 24; //char to compare packetBuffer to
  Ethernet.init(10); //sets CS pin for ethernet shield
  Ethernet.begin(mac, ip); //initializes ethernet with mac and ip addresses
  Serial.begin(9600); //initializes serial connection. Waits for serial to be available (native usb only).
  while (!Serial) {
  //Checks for presence of Ethernet shield. Halts if no ethernet hardware present.
  if (Ethernet.hardwareStatus() == EthernetNoHardware) {
    Serial.println("Ethernet shield was not found. Sorry, can't run without hardware. :(");
    while (true) {
      delay(1);
  //Checks for presence of etherner link.Halts if no link present.
  if (Ethernet.linkStatus() == LinkOFF) {
    Serial.println("Ethernet cable is not connected.");
  Udp.begin(localPort); //begins udp on port specified above.
  int packetSize = Udp.parsePacket();
  if (packetSize) {                     //if data available, prints following;
    Serial.println("----------------------------------------------");
    Serial.print("Received packet of size ");
    Serial.println(packetSize);
    Serial.print("From ");
    IPAddress remote = Udp.remoteIP();
    for (int i = 0; i < 4; i++) {
      Serial.print(remote[i], DEC);
      if (i < 3) {
        Serial.print(".");
    Serial.print(", port ");
    Serial.println(Udp.remotePort());
    Udp.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE);
    Serial.print("packetBuffer = ");
    Serial.println(packetBuffer);
    if (packetBuffer == f1) {
      Serial.println("Contents:");
      Serial.println("10 received via UDP!");
    } else if (packetBuffer == f2) {
      Serial.println("Contents");
      Serial.println("24 received via UDP!");
      Serial.println("SOMETHING WENT WRONG");
    Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
    Udp.write("acknowledged", 13);
    Udp.endPacket();
And my Processing 3 code to send UDP looked like this;
import hypermedia.net.*;
UDP udp; //define the UDP object
udp = new UDP (this, 6000); //create new datagram connection on port 6000
udp.log(true); //print out the connection activity (optional)
udp.listen(true); //wait for incoming message
void draw() {
void keyPressed() {
  int buffer = 24;
  String ip = "2.0.0.100"; //remote IP address to send string to
  int port = 8888; //destination port
  udp.send("24", ip, port); //the message to send
void receive( byte[] data ) { //default handler
//void receive( byte[] data, String ip, int port ) { // extended handler
  for(int i=0; i < data.length; i++)
  print(char(data[i]));
  println();
When sending either "10" or "24" to the arduino I always get my "Something went wrong message".
I assume this is something to do with the processing sketch sending the 10/24 as chars encoded in ascii, but I'm not sure how to account for that in the arduino code. When I try to change the packetBuffer from char to byte I get an error saying
"no matching function for call to 'println(byte [24])' "
Any help would be much appreciated! Thank you
You are comparing the buffer address to your incoming bytes, You should be comparing the contents of your buffer (specifically, the first byte)
    if (packetBuffer[0] == f1) {
    } else if (packetBuffer[0] == f2) {
You are NOT sending the char 10 or the char 24. You are sending the string "10" or the string "24".
packetBuffer isn't a string, so you can't use strcmp() to see if you got "10" or "24".
You could easily make it a string, so you could. Research what a string, in C, is, and you'll discover that it is a NULL terminated array of chars. Add a NULL to the char array, and the array will become a string.
Now, strcmp() doesn't expect an array of bytes, but you can use a cast, to pretend that the byte array is actually a char array.
