Receiving an arduino variable on an webserver and toggling javascript checkbox
Greetings, i would like to request help on a problem that i have had a for a while now. Im sucessfully communicating my Arduino UNO with a NodeMCU ESP8266-01 via SerialSoftware. There, i send a char which enables a LED on my NodeMCU, what i wanna do is grab this variable via javascript and use it to toggle 3 checkboxes, simply make the 3 of them get checked. Here's what i've tried:
    client.println("<!DOCTYPE html>");
            client.println("<html>");
            client.println("<head>");
            client.println("<title>Smartcine</title>");
            client.println("</head>");
            client.println("<body>");                      //<------ALTERADO
            client.println("
            client.println("
            client.println("<input type=\"text\" value=\"10\" id=\"countdown\" / > ");
            client.println("<input type=\"button\" value=\"Start\" onclick=\"startTimer(\'countdown\')\"/>");
            client.println("<input type=\"button\" value=\"Stop\" onclick=\"stopTimer(\'countdown\')\"/>
            client.println("<input type=\"checkbox\" name=\"smartcine\" value=\"led-01\"/>led-01
            client.println("<input type=\"checkbox\" name=\"smartcine\" value=\"led-02\"/>led-02
            client.println("<input type=\"checkbox\" name=\"smartcine\" value=\"led-03\"/>led-03
            client.println("<script type=\"text/javascript\">");
            client.println("var intervalID;");
            client.println("function startTimer(Id){");
            client.println("var cbox = document.getElementsByName('smartcine');");
            client.println("var control = document.getElementById(Id);");
            client.println("var seconds = control.value;");
            client.println("seconds = seconds - 1;");
            if (led1) { // nodeMcu variable that reads from serial and enables a led and becomes true, in which case it sshould be true;
              client.println("cbox[0].checked = true;");
              client.println("cbox[1].checked = true;");
              client.println("cbox[2].checked = true;");
            client.println("if(seconds == 0 && cbox[0].checked && cbox[1].checked && cbox[2].checked){");
            client.println("control.value = 'done';");
            client.println("document.write('<iframe width=\"420\" height=\"345\" src=\"https://www.youtube.com/embed/fJ9rUzIMcZQ?autoplay=1\"></iframe>');");
            client.println("return 1;");
            client.println("}");
            client.println("else");
            client.println("{");
            client.println("control.value = seconds;");
            client.println("if(seconds > 0 && (!cbox[0].checked || !cbox[1].checked || !cbox[2].checked)){");
            client.println("window.alert('erro, ligue os leds primeiro!');");
            client.println("control.value = 10;");
            client.println("return false;");
            client.println("intervalID = setTimeout(function(){startTimer(\"countdown\")}, 1000);");
            client.println("function stopTimer(){");
            client.println("clearTimeout(intervalID);");
            client.println("</script>");
            client.println("</body>");
            client.println("</html>");
This is how i read from serial to check if im receiving the required char value to toggle my led
  // INÍCIO DO SERVIÇO DE SERVIDOR
  WiFiClient  client = server.available();
  if (Serial.available() > 0)
    char data = Serial.read();
    if (data == '1')
      digitalWrite(4, HIGH);
      led1 = true;
    if (data == '0')
      digitalWrite(4, LOW);
      led1 = false;
In order to simply my post and make it easy to understand, i've uploaded on pastebin the whole code here: #include <ESP8266WiFi.h>#include <WiFiClient.h>#include <ESP8266WebServer.h> - Pastebin.com
Just to make it clear what i am trying to do: I want to read the boolean state from led1 with javascript and use it to trigger those 3 checkboxes, and i really have no idea how to do it.
How is this an Arduino problem?
PaulS:
Hi thanks for replying. Isn't it a programming question? i am using arduino after all.
To run javascript? I don't think so.
