Receiving and writing data over I2C does not work
I have tried to send and receive some data over I2C. It works perfectly, if I send data inside the loop and receive the data on the other side with Wire.onReceive() and send some new data inside the loop.
But now, I have tried to send the received data directly back to the master instead of write inside the loop a new sending command. Why this does not work? With the attached code it sends and receives nothing anymore!
Master sender:
#include <Wire.h>
const byte serialBuffer = 10;
char receivedData[serialBuffer];
char sentData[serialBuffer];
boolean newData = false;
byte DPangle = 13;
byte A = 0;
byte B = 0;
byte C = 0;
byte D = 0;
byte BUT = 0;
    Wire.begin(10);
    //Wire.setClock(300000);
    Wire.onReceive(readCommand);
    Serial.begin(38400);
    //readCommand(Wire);
    //command('G',122, 9);
    //command('E',2, 9);
    command('#',DPangle, 9);
    //command('F',189, 9);
    //command('H',51, 9);
void command(const char command, const byte value, const byte address){
  sprintf(sentData, "\n%c%d\r", command,value); //generates a formatted string output with the format <character|decimal> from the char command and value with start- and end-marker and stores it to buffer
  const size_t characters {strlen(sentData)};
  //Serial.print("length: "); Serial.println(characters);
  Wire.beginTransmission(address);
  Wire.write(sentData, characters);
  Wire.endTransmission();
  delay(12);
void readCommand(int bytes){
  readIncomingData();
  storeReceivedData();
void readIncomingData(){
  static boolean InProgress = false;
  static byte i = 0;
  char startMarker = '\n';
  char endMarker = '\r';
  char rc;
  while (Wire.available() > 0 && newData == false){
    rc = Wire.read();
      if (InProgress == true){
        if (rc != endMarker){
          receivedData[i] = rc;
          i++;
          if (i >= serialBuffer){
            i = serialBuffer - 1;
        else {
          receivedData[i] = '\0'; // terminate the string
          InProgress = false;
          i = 0;
          newData = true;
      else if (rc == startMarker){
        InProgress = true;
void storeReceivedData(){
  char var;
  int y = 0;
  if (newData == true){
    var = receivedData[0];
    y = atoi(&receivedData[1]);  //making the integer part
      for(byte i=0; i < serialBuffer; i++){
    switch(var){
      case 'A' : A = y;
      case 'B' : B = y;
      case 'C' : C = y;
      case 'D' : D = y;
      case '@' : BUT = y;
    Serial.print("A = ");
    Serial.println(A);
    Serial.print("B = ");
    Serial.println(B);
    Serial.print("C = ");
    Serial.println(C);
    Serial.print("D = ");
    Serial.println(D);
    Serial.print("BUT = ");
    Serial.println(BUT);
    newData = false;
Slave receiver:
#include <Wire.h>
int E = 0;
int F = 0;
int G = 0;
int H = 0;
int BUT = 0;
    Wire.begin(9);
    //command('@',255, 10);
    //command('C',122, 10);
    //command('A',05, 10);
    //command('D',242, 10);
  delay(12);
  readIncomingData();
  static byte i = 0;
  char rc;
    rc = Wire.read();
          i++;
        else {
          InProgress = false;
          i = 0;
          newData = true;
        InProgress = true;
  char var;
  int y = 0;
    switch(var){
      case 'E' : E = y;
      case 'F' : F = y;
      case 'G' : G = y;
      case 'H' : H = y;
      case '#' : BUT = y;
                 command('A',BUT,10);
    Serial.print("E = ");
    Serial.println(E);
    Serial.print("F = ");
    Serial.println(F);
    Serial.print("G = ");
    Serial.println(G);
    Serial.print("H = ");
    Serial.println(H);
    newData = false;
if you define variables inside a function.
This variable is only accessible inside this function.
To make a variable accessible from everywhere you have to declare the variable outside of the function.
This is called a global declared variable
best regards Stefan
We don't send readable ASCII over the I2C bus, we use the variables themself (binary data).
That means that all your atoi() and sprintf() are not needed. All the code to read the string, to detect the end of the string, adding a zero-terminator, the while-loops, all that code is not needed.
The I2C bus is not a serial stream of data. It is packages of data.
The onReceive and onRequest handlers are called from a interrupt. Treat them as interrupts routines. Keep them very short and very fast. Avoid using any Serial functions. It is not possible to do a I2C session while in the onReceive or onRequest handler. That does not work as you already noticed.
When two Arduino boards are able to send data, then they both can be Master on the I2C bus. That will go wrong some day. It is better to keep one Arduino board as Master and everything else as Slave.
Where I have variables that are used global? Could you show it to me please?
The function command() inside readIncomingData() uses only the global declared variable BUT. The other parameters are given directly as numbers/letters.
The problem was, that I have received sometimes not all the data or wrong values. For that reason I have put the start- and end-marker. Now I had not any faults during transmission.
Can you show me what is not needed or could be deleted to make it shorter?
The serial output is only during the test routines to see what is sent and received.
Do you mean something like that?
#include <Wire.h>
int E = 0;
int F = 0;
int G = 0;
int H = 0;
int BUT = 0;
    Wire.begin(9);
    Serial.println(E);
    Serial.println(F);
    Serial.println(G);
    Serial.println(H);
  Wire.write(command);
  Wire.write(value);
  Wire.write('\0');
  delay(12);
  char var;
    var = Wire.read();
    switch(var){
      case 'E' : E = var;
      case 'F' : F = var;
      case 'G' : G = var;
      case 'H' : H = var;
      case '#' : BUT = var;
The I2C bus has a START and STOP condition, there is not need to add extra start end stop bytes. The I2C bus is also not a fault tolerant bus, you should make it reliable.
Do you use wires or cables (what cables, how long, and so on) ? Which Arduino boards do you use ? Do you use pullup resistors ? Can you show of photo of the wiring ?
Yes, like that. There is no need to send a "\0". The I2C bus uses binary packages of data.
I have a working Master and Slave sketch for you.
I made a few fixes:
  1. Sometimes you use an indent of 2 spaces and sometimes 4. I use 2 spaces.
  2. A baudrate is 115200 is often used, although in many examples the very slow baudrate of 9600 is used.
  3. I'm not naming the variables A, B, C, D, BUT. I name them A, B, C, D, E, and then I don't even use that, because I put them in an array.
  4. I didn't like to request a byte with a command when there are only 5 bytes. So I request 5 bytes.
Master sketch
#include <Wire.h>
byte DPangle = 13;
byte receivedData[5];
  Serial.begin(115200);        // 9600 is old slow default, 115200 is often used today
  Serial.println("The Master (Controller) sketch has started");
  Wire.begin();                // Master mode only
  int x = random( 0, 5);
  if( x == 0)
  else if( x == 1)
    command('E',2, 9);
  else if( x == 2)
  else if( x == 3)
    command('H',51, 9);
  requestData( receivedData, sizeof(receivedData), 9);     // request data from I2C address 9
  for( int i=0; i< (int)sizeof( receivedData); i++)
    Serial.print( (char)('A' + i));
    Serial.print( " = ");
    Serial.print( receivedData[i]);
    Serial.print( ", ");
  delay( 250);
// sending two bytes
bool command( char command, byte value, byte address)
  Wire.write(value);
  int error = Wire.endTransmission();
  return( error == 0);
// request all the bytes, 5 bytes at this moment
bool requestData( byte *pData, byte bytes, byte address)
  bool success = false;
  int n = Wire.requestFrom( address, bytes);
  if( n == bytes)
    Wire.readBytes( pData, bytes);
    success = true;
  return( success);
Slave sketch
#include <Wire.h>
volatile byte dataReceived[2];
volatile bool newData;
byte dataToSend[5] = { 12, 114, 46, 8, 220};
  Serial.begin( 115200);
  Serial.println("The Slave (Target) sketch has started");
  Wire.begin(9);
  Wire.onReceive( receiveEvent);
  Wire.onRequest( requestEvent);
  if(newData)
    Serial.print( "Command = ");
    Serial.print( dataReceived[0]);
    Serial.print( ", value = ");
    Serial.print( dataReceived[1]);
    newData = false;
void receiveEvent(int howMany)
  if(howMany == 2)          // expecting two bytes
    dataReceived[0] = (byte) Wire.read();  // read first byte
    dataReceived[1] = (byte) Wire.read();  // read second byte
    newData = true;
void requestEvent()
  // return the 5 bytes
  Wire.write( dataToSend, sizeof( dataToSend));
Perhaps I should have send 5 bytes instead of 2 bytes. It is only 5 bytes. The buffer inside the Wire library is 32 bytes, so up to 32 bytes can be send or received with basic Arduino boards, such as the Arduino Uno.
Thanks a lot! That is a very simple method, but does not receive it correctly. On the serial monitor I get this output:
Command = 72, value = 189
Command = 35, value = 51
Command = 70, value = 13
Command = 72, value = 122
Command = 69, value = 51
Command = 72, value = 13
Command = 71, value = 2
Command = 69, value = 122
Command = 35, value = 2
Command = 71, value = 51
Command = 71, value = 122
Command = 70, value = 122
Command = 72, value = 51
Command = 72, value = 2
Command = 69, value = 13
Command = 70, value = 51
Command = 35, value = 122
For example, the sommand 72 should be every time the same value, but it is not!
Is it really that easy to send and receive data over I2C? My sketch works without issues and is not slower I think, is not it?!
What I do not understand is the return(error == 0);, what does it make? Only when error is equal to 0 it returns error?
I run the sketches in Tinkercad on two Arduino Uno boards and there it is alright.
Since the values are always a value that belongs to a other number, it is not noise on the I2C bus. It must be something in software or with a timing mismatch.
Have you changed something ? For example removing the 'volatile' keyword or removing the delay(250) in the Master ? Both can be fixed. Do you use something else than a Arduino Uno ?
A if-statement has a condition that is either true or false. For example: if(error == 0) then the variable error is compared to zero. It is possible to grab that condition and use it in other situations.
So this is the condition on its own, it is true or false: (error == 0)
That means it can be used to translate a variable into a condition and have that condition be true or false. This returns true if error is zero or else false: return(error == 0)
This is the same:
// The function command returns true if it was successful
  Wire.write(value);
  if( error == 0)
    return( true);
    return( false);
By using the return value in a if-statement, you can do this:
if( command('G',122, 9))
  Serial.println( "Command was successfully sent");
  Serial.println( "O no, could not deliver the data");
Year! Thanks a lot! I have forgotten the dataReceived[] array to store the data...
And I think for starting with my project, I can send only in one direction. That is totally enough!
Here are my codes with error messages if it is not successfull.
Master:
#include <Wire.h>
//bool newData;
byte error;
int A = 0;
int B = 0;
int C = 0;
int D = 0;
int BUT = 0;
    Wire.begin(10);
    //Wire.onReceive(readCommand);
  /*if(newData == true){
    Serial.println(A);
    Serial.println(B);
    Serial.println(C);
    Serial.println(D);
    newData = false;
    command('#',34, 9);
    command('H',185, 9);
    command('E',1, 9);
    command('G',212, 9);
  if(error != 0){
    if(error == 1){
      Serial.print("Command error: ");
      Serial.print(error);
      Serial.println(" Data too long to fit in transmit buffer!");
    else if(error == 2){
      Serial.println(" Received NACK on transmit of address!");
    else if(error == 3){
      Serial.println(" Received NACK on transmit of data!");
    else if(error == 4){
      Serial.println(" Other error!");
  Wire.write(value);
/*void readCommand(int bytes){
  char var;
  if(bytes == 2){
    var = Wire.read();
    switch(var){
      case 'A' : A = var;
      case 'B' : B = var;
      case 'C' : C = var;
      case 'D' : D = var;
      case '@' : BUT = var;
    newData = true;
Slave:
#include <Wire.h>
bool newData;
int E = 0;
int F = 0;
int G = 0;
int H = 0;
int BUT = 0;
    Wire.begin(9);
    Serial.println(E);
    Serial.println(F);
    Serial.println(G);
    Serial.println(H);
    newData = false;
    /*command('@',255, 10);
    command('D',242, 10);*/
/*bool command(const char command, const byte value, const byte address){
  Wire.write(value);
  return(error);
  if(bytes == 2){
    dataReceived[0] = Wire.read();
    dataReceived[1] = Wire.read();
    switch(dataReceived[0]){
      case 'E' : E = dataReceived[1];
      case 'F' : F = dataReceived[1];
      case 'G' : G = dataReceived[1];
      case 'H' : H = dataReceived[1];
      case '#' : BUT = dataReceived[1];
    newData = true;
What I did not understand is the volatile for the array of dataReceived. Why to declare a volatile byte and not only a byte?
Have you told which Arduino boards you use ?
When a compiler uses a global variable in the Arduino loop(), then it might optimize it in a way that it keeps the variable in a register and does not use the original variable in its memory location.
A interrupt can happen at any time, and the interrupt routine could change a global variable.
By using the 'volatile' keyword, the compiler will always use the original memory location of the variable.
Since the loop() runs over and over again, and dataReceived is an array, using the 'volatile' keyword is more theoretical. You need specific code and very bad luck for the 'volatile' to make a difference.
Oh sorry, I have forgotten it! An Arduino Uno and/or Mega. Does this make a difference?
Okay, that sounds interesting. I will let it be a volatile now, but how to know which variable should be better a volatile or not?
Any variable changed within an interrupt service routine and accessed in the main program should be declared volatile.
Wire.onReceive() is an interrupt.
All right! Now I have understood it correctly I think. Thanks a lot for that claryfication!
