Recent updates to compiler causes errors
Hello,
Has there been a recent change in the compiler or linker?
My code does no longer compile. Very strange.
For example:
A long range of reference errors appear now. The code compiled without errors a week ago.
Thanks
/Jonas
I cant check it out for you as there appears to be some custom libraries used.
Is there a need for two oled libs ?
What board are you compiling for ?
What oled type is it ?
Please also post the errors but ensure you use code tags ( </> )
Create is constantly evolving but AFAIK is still retaining its core functionality.
It can certainly handle the much older PDE files and only tends to spit at libs if they are incorrect in some way.
Would you take a quick look through this and then come back and fill in any missing pieces.
