Record audio with Nano 33 BLE Sense through terminal
I guess the Serial.print takes too much time so you end up missing/dropping a lot of samples each time you call it. Try changing the code so you accumulate samples in a buffer (array) and then print the whole buffer in one single Serial.print when you are done collecting samples (whenyou have either reached a timeout or the size of the buffer).
