Hi all,
I am looking for some advice regarding my programming.
I have multiple sensors recording various data points, temp, distance (utilising analog and dig interface).
I receive all the data, timestamped for later analysis.
However, when I review the text file I see that the new timestamped data and data that was recorded previously has been reprinted.
I am transferring the information via a String into a file, but cannot figure out why it is repeating the old information on every print to file instruction.
void dataLogger(float *temp, float *temp1, float *MCP9808, long *distance) {
tmElements_t tm;
if (RTC.read(tm)) {
dataString = "";
dataLogger2digits(tm.Hour);
dataString += ":";
dataLogger2digits(tm.Minute);
dataString += ":";
dataLogger2digits(tm.Second);
dataString += ",";
dataLogger2digits(tm.Day);
dataString += "/";
dataLogger2digits(tm.Month);
dataString += "/";
dataString += String(tmYearToCalendar(tm.Year));
dataString += ",";
dataString += String(*temp);
dataString += ",";
dataString += String(*temp1);
dataString += ",";
dataString += String(*MCP9808);
dataString += ",";
dataString += String(*distance);
//open the file
File dataFile = SD.open("datalog.txt",FILE_WRITE);
if (dataFile) {
dataFile.println(dataString);
dataFile.close();
//print to the serial port too
Serial.println(dataString); //Check to see if this is an easier way to print to Serial port
//If the file is not open, pop up an error message
else {
Serial.println("Error opening datalog.txt");
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include <LiquidCrystal.h>
#include "Adafruit_MCP9808.h"
#include <TimeLib.h>
#include <DS1307RTC.h>
#define trigPin 40
#define echoPin 41
#define DS1307_CTRL_ID 0x68 // Define constant for RTC I2C Address
File myFile;
const int chipSelect = 53; //Can be altered
int ticks = 0, old_tick_value = 0; // Variables to count square wave pulses
int TMP36 = 0,testTMP36 = 1, blueLED = 23, waterHigh = 33;
float supplyVoltage = 5;
String dataString = "";
float temp, temp1, MCP9808;
long duration, distance;
Adafruit_MCP9808 tempsensor = Adafruit_MCP9808();
LiquidCrystal lcd(8, 9, 10, 11, 12, 13);
Serial.println("\nInitializng SD card...");
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
while (1);
Serial.println("Card initialized");
// Attach Interrupt to pin D2
attachInterrupt(0,handleInt,FALLING);
// Set Square Wave at 1Hz
setSQW(0x10);
//Detect MCP9808 is found over I2C bus
//Address with tempsensor.begin(0x19) for exmple
//Check if tempsensor.begin(0x18) is correct
if (!tempsensor.begin(0x18))
Serial.println("Could not find MCP9808!!");
while (1);
//Intialize Temperature from internal and external TMP36 and Ultrasonic Sensor
temperatureTMP36(&temp, &temp1);
ultraSound(duration, &distance);
//Set up LCD number of columns and rows:
lcd.begin(16, 2);
//Test LCD screen
lcd.print("Sensor Test");
pinMode(blueLED, OUTPUT);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(waterHigh, OUTPUT);
//Read temp TMP36 and Ultrasound every 10 seconds to allow them to stabilize
if (ticks == 10) {
ticks = 0;
//Temperature from MCP9808
MCP9808 = tempsensor.readTempC();
//Distance obtained from Ultrasonic Sensor
//Send data to LCD screen
LCD(&temp, &MCP9808);
// Update serial monitor display if a second has elapsed
if (ticks != old_tick_value) {
old_tick_value = ticks;
//Read sensors and append to the string
dataLogger(&temp, &temp1, &MCP9808, &distance);
//printCurrentTime(temp, temp1, MCP9808, distance);
// Interrupt Handler
void handleInt() {
digitalWrite(blueLED, HIGH);
delay(100);
digitalWrite(blueLED, LOW);
ticks++;
// Setup RTC Module for 1 Hz square wave
void setSQW(uint8_t value) {
Wire.beginTransmission(DS1307_CTRL_ID);
Wire.write(7);
Wire.write(value);
Wire.endTransmission();
// Format numbers as 2-digit numbers for data logger
void dataLogger2digits(int number) {
if (number >= 0 && number < 10) {
dataString += "0";
dataString += String(number);
tmElements_t tm;
if (RTC.read(tm)) {
dataString += "\n";
dataString += ":";
dataString += ":";
dataString += ",";
dataString += "/";
dataString += "/";
dataString += ",";
dataString += ",";
dataString += ",";
dataString += ",";
//open the file
if (dataFile) {
dataFile.close();
else {
void temperatureTMP36(float *temp, float *temp1) {
float voltage, testVoltage, reading, testReading;
reading = analogRead(TMP36);
testReading = analogRead(testTMP36);
voltage = reading * supplyVoltage / 1024;
testVoltage = testReading * supplyVoltage / 1024;
//Convert from 10mV per degree with 500mV offset as per tecspecs
//Alteration to allow for calibration to be close to MCP9808;
*temp = (voltage - 0.5) * 100;
*temp1 = (testVoltage - 0.5) * 100;
return;
void ultraSound(long duration, long *distance) {
long period, measure;
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
*distance = (duration/2) / 29.1;
return;
void LCD(float *temp, float *MCP9808) {
P.S. Sorry if I haven't followed the posting procedure, first time asking a question on the forum and have attempted to follow the instructions.
DATALOG.TXT (498 KB)
