Récupérer JSON avec un ESP32
Bonjour,
j'essaie en vain de récupérer le JSON de cette adresse :
https://data.stib-mivb.be/api/explore/v2.1/catalog/datasets/waiting-time-rt-production/records?where=%22UZ-VUB%22&limit=100&refine=pointid%3A1755
Mon code :
#include <WiFi.h>
#include <HTTPClient.h>
#include <Arduino_JSON.h>
const char* ssid = "XXXXX";
const char* password = "XXXXXXXXX";
// THE DEFAULT TIMER IS SET TO 10 SECONDS FOR TESTING PURPOSES
// For a final application, check the API call limits per hour/minute to avoid getting blocked/banned
unsigned long lastTime = 0;
// Timer set to 10 minutes (600000)
//unsigned long timerDelay = 600000;
// Set timer to 10 seconds (10000)
unsigned long timerDelay = 10000;
String jsonBuffer;
  WiFi.begin(ssid, password);
  Serial.println("Connecting");
  while(WiFi.status() != WL_CONNECTED) {
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to WiFi network with IP Address: ");
  Serial.println("Timer set to 10 seconds (timerDelay variable), it will take 10 seconds before publishing the first reading.");
  // Send an HTTP GET request
  if ((millis() - lastTime) > timerDelay) {
    // Check WiFi connection status
    if(WiFi.status()== WL_CONNECTED){
      String serverPath = "https://data.stib-mivb.be/api/explore/v2.1/catalog/datasets/waiting-time-rt-production/records?where=%22UZ-VUB%22&limit=100&refine=pointid%3A1755";
      jsonBuffer = httpGETRequest(serverPath.c_str());
      Serial.println(jsonBuffer);
      JSONVar myObject = JSON.parse(jsonBuffer);
      // JSON.typeof(jsonVar) can be used to get the type of the var
      if (JSON.typeof(myObject) == "undefined") {
        Serial.println("Parsing input failed!");
        return;
      Serial.print("JSON object = ");
      Serial.println(myObject);
    else {
      Serial.println("WiFi Disconnected");
    lastTime = millis();
String httpGETRequest(const char* serverName) {
  WiFiClient client;
  HTTPClient http;
  // Your Domain name with URL path or IP address with path
  http.begin(client, serverName);
  // Send HTTP POST request
  int httpResponseCode = http.GET();
  String payload = "{}";
  if (httpResponseCode>0) {
    Serial.print("HTTP Response code: ");
    Serial.println(httpResponseCode);
    payload = http.getString();
  else {
    Serial.print("Error code: ");
  // Free resources
  http.end();
  return payload;
Mais le code me renvoi :
<html>
<head><title>400 The plain HTTP request was sent to HTTPS port</title></head>
<body>
<center><h1>400 Bad Request</h1></center>
<center>The plain HTTP request was sent to HTTPS port</center>
<hr><center>openresty</center>
</body>
</html>
J'ai ensuite essayé avec WifiSecureClient mais sans succès.
Je souhaite simplement récupérer ce JSON pour le parser et ensuite l'afficher sur un écran RGB.
D'avance merci
Bonjour
Comment ? Avec quel code ?
Avec WiFISecureClient () as-tu tenté la méthode setInsecure() ?
ESP32 HTTPS Requests without Certificate
https://randomnerdtutorials.com/esp32-https-requests/
un truc comme cela sans doute pour récupérer le json
#include <WiFi.h>
const char* ssid = "SECRET_SSID";
const char* wpd = "SECRET_PASS";
const char * url = "https://data.stib-mivb.be/api/explore/v2.1/catalog/datasets/waiting-time-rt-production/records?where=%22UZ-VUB%22&limit=100&refine=pointid%3A1755";
  WiFi.begin(ssid, wpd);
  Serial.println("Connexion au WiFi...");
    Serial.write('.');
  Serial.println("\nConnecté au WiFi");
  HTTPClient http;
  http.begin(url);
  int httpCode = http.GET();
  if (httpCode > 0) {
    String json = http.getString();
    Serial.println(json);
    Serial.print("Erreur lors de la requête HTTP: ");
    Serial.println(httpCode);
  http.end();
void loop() {}
Je te remercie !
Je n'ai plus qu'à trouver comment parser et l'envoyer à un écran.
quels champs voulez vous extraire ?
ArduinoJSON fait ça très bien pour vous
Je vais essayer de trouver tout seul pour la suite.
Merci quand même :wink:
Oui :slight_smile:
il y a l'assistant qui est bien pratique
