Redeclared as different kind of symbol - ESP32 dev board
It will not compile:
volatile float y1 = 0;
volatile float y2 = 0;
void setup() {}
void loop() {}
I am using an ESP32 development board. Is there a list somewhere of reserved words?*
I added this library:
  1. File → Preferences, paste in Additional Boards Manager URLs:
    https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json
  2. Tools → Board: “[…]” → Boards Manager, search for esp32 and install.
*If so, it might be here: GitHub - espressif/arduino-esp32: Arduino core for the ESP32
(I don't know how to navigate or where it would be found.)
adamelli:
If you look at the full error message. It tells you where this specific declaration is:
sketch_nov18a:1:16: error: 'volatile float y1' redeclared as different kind of symbol
In file included from C:\Users\per\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\cores\esp32/esp32-hal.h:34:0,
                 from C:\Users\per\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\cores\esp32/Arduino.h:35,
                 from C:\Users\per\AppData\Local\Temp\arduino_build_837701\sketch\sketch_nov18a.ino.cpp:1:
C:\Users\per\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/newlib/math.h:475:15: note: previous declaration 'double y1(double)'
 extern double y1 _PARAMS((double));
exit status 1
You can see that on my computer it's at line 475 of the file C:\Users\per\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/newlib/math.h
The file will be in a different location on your computer.
Thanks!
(I realize now, I get tunnel vision looking at those error messages--usually don't understand most of it.)
