Redefinition of Class error
I'm having what seems to be a problem that should be easy to fix, but I'm too new to figure it out. I'll post the whole sketch but the error indicates that the issue is in an included library. --Sketch is too long so I had to cut most of it out.
-Arduino IDE 1.0.5
-Hardware
  -Arduino Mega 2560 R3
  -NEMA 14 0.9deg (400 step/rev) 11Ncm stepper motor
  -SilentStepStick stepper motor driver
  -Adafruit Ultimate GPS Breakout [ID:746]
  -Adafruit RGB backlight negative LCD 20x4 + extras (RGB on black) [ID:498]
  -Adafruit i2c / SPI character LCD backpack[ID:292]
FUNCTIONS
-Adjustable number of turns per day (TPD)
  -increments of 5
-Adjustable direction
  -clockwise
  -counterclockwise
  -both
-Adjustable turn frequency
  -turn the watch ever n number of minutes?
  -calculate number of turns per cycle, depending on cycle frequency
-Full wind
  -run continuously, to wind a watch from a dead stop. 800 turns.
-GPS receiver
  -get time for clock to display on screen.
-Turn counter
  -displays number of turns since midnight.
#include <TimerOne.h>
#include <Wire.h>
//INSERT THE NEXT 4 INCLUDES AFTER INCLUDING WIRE LIBRARY
//#include <buttons.h>
#include <LiquidTWI2.h>
#include <MENWIZ_LiquidTWI2.h>
#include <EEPROM.h>
#include <AccelStepper.h>
#include <Adafruit_GPS.h>
#include <SoftwareSerial.h>
#include <Time.h>
//                      CONSTANTS                       //
const int  ESCAPE_BUTTON      =    9; //Escape Button
const int  CONFIRM_BUTTON     =   10; //Confirm Button
const int  DOWN_BUTTON        =   12; //Down Button
const int  UP_BUTTON          =   11; //Up Button
const int  w1ACT              =    8; //button to activate/deactivate watch slot
const int  w1SLEEP            =   24; //Driver Sleep Pin
const int  w1LED              =   43; //feedback light on w1ACT
const long REV                = 6400; //number of steps in 1 revolution of motor
const long RPM                =    8; //Speed at which the motor will spin
const long MINUTES_IN_DAY     = 1440; //minutes in 24 hours
const int  w1FULL_WIND        =  800; //Revolutions to fully wind from stop
char* w1ACTIVE_STAT[]={"STATUS: OFF", "STATUS: ON"}; //Used for Status screen.
//                  GLOBAL VARIABLES                    //
int     w1TPD                =              650; //Turns per day
int     w1DIR                =                0; //0=CW, 1=CCW, 2=BOTH used in menu
int     w1DIRECTION          =                1; //Used in functions to determine direction
int     w1CYCLE_TIME         =               15; //Minutes between cycles
int     w1CYCLE_TIME_S       =  w1CYCLE_TIME*60; //Seconds between cycles
int     w1CYCLE_TIME_LAST    =     w1CYCLE_TIME; //Used to determine change in CYCLE_TIME
long    w1STEPS                                ; //Use in WIND_NOW() function & full wind, and loop cleanup
int     w1FULL_WIND_STATUS   =                0; //0=OFF, 1=unidirectional, 2=bidirectional
int     w1FULL_WIND_COUNT    =                1; //Used to determine when to switch direction
boolean w1ACTIVE             =                1; //Is this slot turned on or off?
boolean w1ACT_STATE          =                0; //Used for determining w1ACTIVE
boolean w1ACT_LAST_STATE     =                0; //Used for determining w1ACTIVE
int     w1TURN_COUNTER       =                0; //Counts number of turns so far, since midnight
long    w1COUNTER_START      =                0; //Used for turn counter to count steps
int     LAST_HOUR            =                0; //Used to reset turn counter
boolean DST                  =                1; //Is DST in effect or not?
boolean DST_LAST             =              DST;
int     ZONE_OFFSET          =               -5; //time zone offset
int     ZONE_OFFSET_LAST     =      ZONE_OFFSET; //time zone offset
boolean TIME_SET_FLAG        =            false; //Check if time has been synced to GPS
int     TIME_HOUR            =                0; //For clock on statusScreen screen
int     TIME_MIN             =                0;
int     TIME_SEC             =                0;
unsigned long SEC_COUNTER    =                0; //Used to see if a second has passed
//                    OBJECTS                           //
menwiz menu;
LiquidTWI2 lcd(0x20);
//CREATE ACCELSTEPPERS
AccelStepper w1STEPPER(1, 23, 22);  //1 pin=driver, 23=step pin, 22=direction pin
//GPS
HardwareSerial GPSSerial = Serial1;
Adafruit_GPS GPS(&GPSSerial);
//                       SETUP                          //
  Serial.begin(19200);
  SEC_COUNTER = now();
  // SET UP LCD
  lcd.setMCPType(LTI_TYPE_MCP23008);
  lcd.begin(20, 4);
  //CHECK IF SETTINGS ARE STORED IN MEMORY & LOAD IF SO
  if (EEPROM.read(0) == 1)
    w1TPD            = EEPROM.read(1) * 256 + EEPROM.read(2);
    w1DIR            = EEPROM.read(3);
    w1CYCLE_TIME     = EEPROM.read(4);
    ZONE_OFFSET      = EEPROM.read(5) - 12;
    DST              = EEPROM.read(6);
    DST_LAST         = DST;
  //CONFIG PINS NOT PART OF MENU NAV
  pinMode(w1ACT, INPUT_PULLUP);
  pinMode(w1LED, OUTPUT);
  digitalWrite(w1LED, w1ACTIVE);
  pinMode(w1SLEEP, OUTPUT);
  digitalWrite(w1SLEEP, HIGH);
  //ACCELSTEPPERS
  w1STEPPER.setMaxSpeed((REV*RPM)/60.0);  //APPROX 8RPM
  w1STEPPER.setAcceleration((REV*RPM)/60.0); //takes 1 sec to reach full speed
  //GPS
  GPS.begin(9600);
  GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCONLY);
  GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ);
The error reported is:
Arduino: 1.0.5 (Windows NT (unknown)), Board: "Arduino Mega 2560 or Mega ADK"
In file included from Winder_from_internet.ino.ino:36:
C:\Users\Tim\Documents\Arduino\libraries\Buttons/buttons.h:25: error: redefinition of 'class Button'
C:\Users\Tim\Documents\Arduino\libraries\Buttons/buttons.h:25: error: previous definition of 'class Button'
And the library contents are:
 *  buttons.h
 *  One-shot and hold functions for buttons.
 *  Created by Franky on 29/01/09.
 *  Licensed under LGPL (free to modify and use as you wish)
#include <inttypes.h>
#define OneShot 0
#define Memory 1
#define Timer 2
#define OneShotTimer 3
#define MemoryTimer 4
#define ON 1
#define OFF 0
#define Pressed 2
#define Released 3
#define Hold 4
typedef uint8_t byte;
class Button {
public:
	Button();
	Button(byte type);
	void assign(byte pin);
	byte check();
	byte check(byte mode_v);
	// Setters
	void setMode(byte type_v);
	void setTimer(unsigned int t);
	void setRefresh(unsigned int r);
	void turnOnPullUp();
	void turnOffPullUp();
private:
	byte pin;
	byte mode;
	unsigned long hold_timer;
	unsigned long refresh_timer;
	unsigned int hold_level;
	unsigned int hold_refresh;
	bool previous;
 Button modes:
 - OneShot: OneShot only, returns 2 values (ON/OFF)
 - Memory: Returns (Pressed/ON/Released/OFF)
 - Timer: Hold System (OFF/ON/Hold)
 - OneShotTimer: Combi OneShot & Timer (ON/Hold/OFF)
 - MemoryTimer: Combi Memory & Timer
 (Pressed/ON/Hold/Released/OFF)
Line 25 is class Button. I can't see any other definition of the Class "Button"
Can anybody help me fix this? I apologize if I've left anything out.
Add this to buttons.h...
https://www.google.com/search?q=c%2B%2B+header+guard
I had tried that before but just did it again and it worked. Maybe because I typed BUTTONS_h the first time.
Anyway, it worked.
After that I had the missing WContants.h problem but google helped me fix that one. The code now compiles.
This forum is a great resource!
