First time poster- first project of this type.
Goal of my project is to have a PIR Sensor trigger a buzzer when ducks climb on my boat. Yes- I can buy commercial but wanted to get into this realm of making.
I have everything wired up and working as expected including figuring out the sketch for the arduino - but- it is killing the battery in mere hours. My goal is to have this sit on the back of the boat and be replenished by solar.
order;
Solar Panel → MPPT Controller →7.4v Lithium battery→RF Fob for remote on/ off →Arduino Uno Board→ 2 ea PIR Sensors→ 2 ea Piezo buzzers wired in series.
Leaving this "on" but without more than 1-2 triggers it killed the 7.4v battery in 2.5 hours and a test 9v in less than 4 hours.
I have been reading in the forum other posts on this but most refer to periodically putting the system to sleep- This may be an option and I mostly need this on dusk to dawn but thus saving power there, but best case is having this run 24/7.
I see the Arduino board has 5v working- but- is it consuming this all the time? Also understood this is probably overkill for what I need it to but it is a one off ( at this point) .
Looking for some kind folk to offer suggestion on how to trim consumption or help point out efficiencies that can be implemented so this can be self sustaining. I get that solar will have it's down days with weather etc, but I was thinking that the sensors should not be drawing much and keeping the other components going was going to be minimal.
Below is the list of the components-
Solar Panel- ASHATA 9V 3W Solar Panel-
https://www.amazon.com/dp/B07N4NTNFM?psc=1&ref=ppx_yo2ov_dt_b_product_details
Battery- EBL 7.4V 2200mAh Li-ion
https://www.amazon.com/dp/B087BYJ51T?psc=1&ref=ppx_yo2ov_dt_b_product_details
MPPT= DAOKI 12V Solar Charge Controller Board CN3791 Solar Charge Controller Board MPPT 1 LiPo Battery Panel Regulator Module JST PH2.0 A
https://www.amazon.com/dp/B091TRHT9M?psc=1&ref=ppx_yo2ov_dt_b_product_details
Remote- QIACHIP 433M Universal Wireless RF Remote Control Switch DC 6V 12V 24V 1CH Channel Relay Wireless Secure RF Remote Control Switches Transmitter and Receiver kit- Static current 3.6 mA ~ 5.5mA
https://www.amazon.com/dp/B083GRC5P7?psc=1&ref=ppx_yo2ov_dt_b_product_details
Board- Arduino UNO REV3-https://www.amazon.com/dp/B008GRTSV6?psc=1&ref=ppx_yo2ov_dt_b_product_details
Microcontroller Microchip ATmega328P
Operating Voltage 5V
USB Standard Type B
Digital I/O Pins 14
PWM Digital I/O Pins 6
Analog Input Pins 6
Flash Memory 32 KB
SRAM 2 KB
EEPROM 1 KB
Clock Speed 16 MHz
PIR Sensor- HiLetgo 3pcs AM312 Mini Pyroelectric PIR
https://www.amazon.com/dp/B07RT7MK7C?psc=1&ref=ppx_yo2ov_dt_b_product_details
Working voltage: DC 2.7-12V;
.Static power consumption: <0.1mA;
Buzzer - uxcell a12081600ux0477 12 mm Diameter 5 Piece DC 5V 2 Terminals Electronic Continuous Sound Buzzer- https://www.amazon.com/dp/B00B0Q4KKO?psc=1&ref=ppx_yo2ov_dt_b_product_details
Thanks for your attention and help.
