Reed Switch, calculating RPM and Hz
I am calculating the RPM and Hz using Reed switch and Magnet. The result is not accurate as what i expected.
When my magnet pass through the Reed switch one time in a second and it will display 4-6 Hz.
I hope someone will help me. Thanks alot.
This is the my result : average (4-6Hz)
RPM = 240 Hz= 4
RPM = 360 Hz= 6
RPM = 360 Hz= 6
RPM = 360 Hz= 6
RPM = 240 Hz= 4
RPM = 360 Hz= 6
RPM = 360 Hz= 6
This is my code :
// read RPM
int half_revolutions = 0;
int rpm = 0;
unsigned long lastmillis = 0;
void setup(){
attachInterrupt(0, rpm_fan, RISING);
void loop(){
if (millis() - lastmillis == 1000 ){ //Uptade every one second, this will be equal to reading frecuency (Hz).
detachInterrupt(0);//Disable interrupt when calculating
rpm = half_revolutions * 60; // Convert frecuency to RPM, note: this works for one interruption per full rotation. For two interrups per full rotation use half_revolutions * 30.
Serial.print("RPM =\t"); //print the word "RPM" and tab.
Serial.print(rpm); // print the rpm value.
Serial.print("\t Hz=\t"); //print the word "Hz".
Serial.println(half_revolutions); //print revolutions per second or Hz. And print new line or enter.
half_revolutions = 0; // Restart the RPM counter
lastmillis = millis(); // Uptade lasmillis
attachInterrupt(0, rpm_fan, FALLING); //enable interrupt
// this code will be executed every time the interrupt 0 (pin2) gets low.
void rpm_fan(){
half_revolutions++;
Reeds bounce.
Please use code tags.
This line can give you trouble as you could miss the exact 1000. Use if (millis() -lasmillis >= 1000);.
