Ok got my board set up and attempted to to make it work. At this point I am willing to pay for a written code and map. I am using a uno board from DR. Duino. I would like for it to illuminate a led colored switch when turned on, then when that momentary switch is pressed it will turn off that led, illuminate a second led in the switch and turn on a relay. I already have the 2 colored switch and relay. Just can’t figure it out.
Post your wiring diagram code using the <CODE/>
tags so we can help you with this simple code, or ask some moderator to change your category topic.
Yes please.
Sorry set up from my phone this morning guess I missed that board.
I think you need a third state (what happens when you are done with the relay being on?). You can see the pattern in this code and complete what you need. The button reading is crude, and will only "work" with one button... look into a millis() timing to read several buttons.
byte buttonPin = 3; // arduino pin >> button pin 1 then button pin 2 >> ground
byte curSTATE = 0; // current state
byte totSTATE = 2; // total states
byte ledRED = 5, ledGRN = 6, relay = 7;
pinMode(buttonPin, INPUT_PULLUP); // HIGH when not pressed
pinMode(ledRED, OUTPUT);
pinMode(ledGRN, OUTPUT);
pinMode(relay, OUTPUT);
Serial.print("Button state: 0");
state_0();
readButton();
void readButton() {
if (digitalRead(buttonPin) == 0) { // read button for PRESSED
delay(50); // "button debounce" to wait for natural button press ringing
if (digitalRead(buttonPin) != 0) { // read button for RELEASED
curSTATE++;
if (curSTATE == totSTATE)
curSTATE = 0;
switch (curSTATE) {
case 0: state_0(); break;
case 1: state_1(); break;
Serial.print(curSTATE); // count button presses from 0 to totSTATE
void state_0() {
digitalWrite(ledRED, HIGH);
digitalWrite(ledGRN, LOW);
digitalWrite(relay, LOW);
void state_1 () {
digitalWrite(ledRED, LOW);
digitalWrite(ledGRN, HIGH);
digitalWrite(relay, HIGH);
Only using 1 button. Here is what I have sent to a couple that have replied via email.
Here is what I am doing:
I have a RC-522 RFID reader I can send the UID to be included in the code, duino uno board, 2 relay board doth no and nc, and the momentary switch with 2 LED. Yes I also have some resistors that came with a starter kit I purchased
I would like the rfid receiver to turn on the uno board when activated. When the uno board is turned on the button will illuminate red, when the momentary button is pushed it will then illuminate green and turn on a relay that will complete a separate circuit. If the momentary switch is pressed again it will then turn off the relay and the illumination will be red. Lastly if the rfid tag / signal is lost the system will shut off altogether.
I have attempted to do this myself. I do understand the working theory, but the code was just too much for me to grasp. So I am looking for the written code to complete this task as well as a map / diagram to get everything wired together on a project board.
What's the budget?
No budget really. If you want to send me an email we can discuss
Then this tread should not be in the "payed" category.
Got it taken care of! Thank you to all who offered.
Delta G: Its not that I wasnt willing to say, just didnt know what the service was worth. I would have spent 500 or so, but if the going rate was 1000 I would of had to regroup. Turns out all the quotes I got were 150-200. Which I went with one in the middle.
