I have this project I'm working on that I seem to be running into memory issues. It's like the majority of the code is going into a "Global Variable" section which is only 2KB in size and if I add too much, it simply runs out and fails to work properly.
At present, the global variables use 1498 bytes of dynamic memory. The sketch uses 15,542 bytes of program space with a max of 32,256 Bytes.
The project is supposed to consist of 8 relays that will be toggleable via the network. I'm using a Ethernet Shield on top of a Arduino Uno. Now currently, I can only get 5 of the 8 outputs to work. I have the others commented out. If I uncomment the 6th one, it will upload but the 6th output will not work. As if there's not enough memory to run it. If I load all 8, it malfunctions and none of them work. With all 8 loaded, it's using 90% of my dynamic memory according to the sketch program.
I will attach my code and if someone can tell me how to optimise the code to use less memory and work as I need it to, that'd be awesome. Also, if there is a way I could possibly use a microsd card to load the html and css from while keeping within the memory constraints or simply pull the majority of the code from an external server, I'd like that too.
I do not want to have to buy bigger arduino just because my code is too big or something when it seems to upload just fine. It just doesn't work when the memory is somehow too full. I do have a teensy++ 2.0 I could use, I'd just have to somehow adapt the SPI header to the teensy.
Thanks
#include <SPI.h>
#include <Ethernet.h>
byte relay0 = 2;
byte relay1 = 3;
byte relay2 = 4;
byte relay3 = 5;
byte relay4 = 6;
//byte relay5 = 7;
//byte relay6 = 8;
//byte relay7 = 9;
byte mac[] = {0xDE,0xAD,0xBE,0xEF,0xFE,0xED}; //physical mac address
byte ip[] = {10,10,1,150}; // ip in lan (that's what you need to use in your browser. ("192.168.1.178")
byte gateway[] = {10,10,1,1}; // internet access via router
byte subnet[] = {255,255,254,0}; //subnet mask
EthernetServer server(80); //server port
String readString;
pinMode(relay0, OUTPUT);
pinMode(relay1, OUTPUT);
pinMode(relay2, OUTPUT);
pinMode(relay3, OUTPUT);
pinMode(relay4, OUTPUT);
//pinMode(relay5, OUTPUT);
//pinMode(relay6, OUTPUT);
//pinMode(relay7, OUTPUT);
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip, gateway, subnet);
// Create a client connection
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.println(readString); //print to serial monitor for debuging
client.println("HTTP/1.1 200 OK"); //send new page
client.println("Content-Type: text/html");
client.println();
client.println("<HTML>");
client.println("<HEAD>");
client.println("<meta name='apple-mobile-web-app-capable' content='yes' />");
client.println("<meta name='apple-mobile-web-app-status-bar-style' content='black-translucent' />");
client.println("<link rel='stylesheet' type='text/css' href='http://www.thelonegeek.net/projects/hardware/arduino-ethernet/ethernetcss.css' />");
client.println("<TITLE>Arduino Relays</TITLE>");
client.println("</HEAD>");
client.println("<BODY>");
client.println("<H1>Arduino Relays - Using leds for some tests.</H1>");
client.println("<hr />");
client.println("<H2>Arduino with Ethernet Shield</H2>");
client.println("
client.println("<a href=\"/?button1on\"\">Turn On Relay 1</a>");
client.println("<a href=\"/?button1off\"\">Turn Off Relay 1</a>
client.println("
client.println("
client.println("<a href=\"/?button2on\"\">Turn On Relay 2</a>");
client.println("<a href=\"/?button2off\"\">Turn Off Relay 2</a>
client.println("
client.println("
client.println("<a href=\"/?button3on\"\">Turn On Relay 3</a>");
client.println("<a href=\"/?button3off\"\">Turn Off Relay 3</a>
client.println("
client.println("
client.println("<a href=\"/?button4on\"\">Turn On Relay 4</a>");
client.println("<a href=\"/?button4off\"\">Turn Off Relay 4</a>
client.println("
client.println("
client.println("<a href=\"/?button5on\"\">Turn On Relay 5</a>");
client.println("<a href=\"/?button5off\"\">Turn Off Relay 5</a>
client.println("
client.println("
client.println("<a href=\"/?button6on\"\">Turn On Relay 6</a>");
client.println("<a href=\"/?button6off\"\">Turn Off Relay 6</a>
client.println("
client.println("
client.println("<a href=\"/?button7on\"\">Turn On Relay 7</a>");
client.println("<a href=\"/?button7off\"\">Turn Off Relay 7</a>
client.println("
client.println("
client.println("<a href=\"/?button8on\"\">Turn On Relay 8</a>");
client.println("<a href=\"/?button8off\"\">Turn Off Relay 8</a>
client.println("
client.println("</BODY>");
client.println("</HTML>");
delay(1);
//stopping client
client.stop();
//controls the Arduino if you press the buttons
if (readString.indexOf("?button1on") > 0) {
digitalWrite(relay0, HIGH);
if (readString.indexOf("?button1off") > 0) {
digitalWrite(relay0, LOW);
if (readString.indexOf("?button2on") > 0) {
digitalWrite(relay1, HIGH);
if (readString.indexOf("?button2off") > 0) {
digitalWrite(relay1, LOW);
if (readString.indexOf("?button3on") > 0) {
digitalWrite(relay2, HIGH);
if (readString.indexOf("?button3off") > 0) {
digitalWrite(relay2, LOW);
if (readString.indexOf("?button4on") > 0) {
digitalWrite(relay3, HIGH);
if (readString.indexOf("?button4off") > 0) {
digitalWrite(relay3, LOW);
if (readString.indexOf("?button5on") > 0) {
digitalWrite(relay4, HIGH);
if (readString.indexOf("?button5off") > 0) {
digitalWrite(relay4, LOW);
if (readString.indexOf("?button6on") > 0) {
digitalWrite(relay5, HIGH);
if (readString.indexOf("?button6off") > 0) {
digitalWrite(relay5, LOW);
if (readString.indexOf("?button7on") > 0) {
digitalWrite(relay6, HIGH);
if (readString.indexOf("?button7off") > 0) {
digitalWrite(relay6, LOW);
if (readString.indexOf("?button8on") > 0) {
digitalWrite(relay7, HIGH);
if (readString.indexOf("?button8off") > 0) {
digitalWrite(relay7, LOW);
//clearing string for next read
readString = "";
