Hello! I'm developing a 3 button on/off system using an attiny84 for channel switching with low signal relays. I'm having some trouble getting the 3rd button to remember the state. The behavior is as follows:
Channel 1: works as intended.
Channel 2: works but also links to channel 3.
Channel 3: wont update unless channel 2 is updated.
Here is my code so far.
#include <EEPROM.h>
/* ATTINY24/44/84 PINS */
/* VCC 1|O |14 GND */
/* SWTIP (SW1) 2| |13 RELAY1 PIN1- */
/* SWRING (SW2) 3| |12 RELAY1 PIN10+ */
/* RESET 4| |11 RELAY1 PIN1- */
/* LED1 5| |10 RELAY1 PIN10+ */
/* LED2 6| |9 RELAY2 PIN1- */
/* LED3 7| |8 RELAY2 PIN10+ */
/*+ = BYPASS */
/*- = ENGAGE */
// arduino pins
//# define buttonPin 0
//# define buttonPin2 1
//# define ledPin 2
//# define ledPin2 3
//# define ledPin3 4
//# define engage 5
//# define bypass 6
//# define engage2 7
//# define bypass2 8
//# define engage3 9
//# define bypass3 10
// attiny pins (clockwise)
# define buttonPin 10
# define buttonPin2 9
# define ledPin 8
# define ledPin2 7
# define ledPin3 6
# define engage 0
# define bypass 1
# define engage2 2
# define bypass2 3
# define engage3 4
# define bypass3 5
int effectstate;
int effectstate2;
int effectstate3;
int buttonState = HIGH;
int buttonState2 = HIGH;
int lastButtonState = HIGH;
int lastbuttonState2 = HIGH;
//timing
long lastDebounceTime = 0;
long debounceDelay = 50;
long pressedat = 0;
long pressedat2 = 0;
long longpress = 500;
long relaytime = 40;
//sw pins
pinMode(buttonPin, INPUT_PULLUP);
pinMode(buttonPin2, INPUT_PULLUP);
//wait for pullup
delay(25);
//led pins
pinMode(ledPin, OUTPUT);
pinMode(ledPin2, OUTPUT);
pinMode(ledPin3, OUTPUT);
//relay pins
pinMode(engage, OUTPUT);
pinMode(bypass, OUTPUT);
pinMode(engage2, OUTPUT);
pinMode(bypass2, OUTPUT);
pinMode(engage3, OUTPUT);
pinMode(bypass3, OUTPUT);
//read eeprom state
checkeffectstate();
checkeffectstate2();
checkeffectstate3();
unsigned long now = millis();
int reading = digitalRead(buttonPin);
int reading2 = digitalRead(buttonPin2);
if (reading != lastButtonState) {
lastDebounceTime = now;
if (reading2 != lastbuttonState2) {
//sw3
if ((now - lastDebounceTime) > debounceDelay) {
if (reading != buttonState) {
if (reading2 != buttonState2) {
buttonState = reading;
buttonState2 = reading2;
if (buttonState == LOW && buttonState2 == LOW) {
togglestate3();
pressedat2 = now;
pressedat = now;
if ((now - pressedat) > longpress) {
if ((now - pressedat2) > longpress) {
togglestate3();
//sw2
if (buttonState2 == LOW) {
togglestate2();
pressedat2 = now;
togglestate2();
//sw1
if (buttonState == LOW) {
togglestate();
pressedat = now;
togglestate();
EEPROM.update(0, effectstate);
EEPROM.update(2, effectstate2);
EEPROM.update(4, effectstate3);
lastButtonState = reading;
lastbuttonState2 = reading2;
void togglestate() {
effectstate = !effectstate;
if (effectstate) {
digitalWrite(ledPin, HIGH);
digitalWrite(engage, HIGH);
delay(relaytime);
digitalWrite(engage, LOW);
digitalWrite(ledPin, LOW);
digitalWrite(bypass, HIGH);
delay(relaytime);
digitalWrite(bypass, LOW);
void togglestate2() {
effectstate2 = !effectstate2;
if (effectstate2) {
digitalWrite(ledPin2, HIGH);
digitalWrite(engage2, HIGH);
delay(relaytime);
digitalWrite(engage2, LOW);
digitalWrite(ledPin2, LOW);
digitalWrite(bypass2, HIGH);
delay(relaytime);
digitalWrite(bypass2, LOW);
void togglestate3() {
effectstate3 = !effectstate3;
if (effectstate3) {
digitalWrite(ledPin3, HIGH);
digitalWrite(engage3, HIGH);
delay(relaytime);
digitalWrite(engage3, LOW);
digitalWrite(ledPin3, LOW);
digitalWrite(bypass3, HIGH);
delay(relaytime);
digitalWrite(bypass3, LOW);
void checkeffectstate() {
effectstate = EEPROM.read(0);
//effect1 on
if (effectstate) {
delay(relaytime);
//effect1 off
delay(relaytime);
void checkeffectstate2() {
effectstate2 = EEPROM.read(2);
//effect2 on
if (effectstate2) {
delay(relaytime);
//effect2 off
delay(relaytime);
void checkeffectstate3() {
effectstate3 = EEPROM.read(4);
//effect3 on
if (effectstate3) {
delay(relaytime);
//effect3 off
delay(relaytime);
I included the arduino pin definitions to troubleshoot and to see how the code works. I'm accomplishing the 3rd button press by linking two diodes tied to it between switches 1/2. Here is the schematic.
For now I'm using LEDs to monitor the relay pulses. You can omit them to save time.
Any ideas?
